Question about Buffalo Technology Computers & Internet
Find and Connect a UPS compatible
This Buffalo NAS seems to be compatible only with UPS APC SU500J which is currently impossible to obtain outside Japan. Therefore Sub-D 9pin connector should use the communication protocol "smart comments" but I didn't find any information about this protocol !?
The user manual also describe Sub-D9 pin assignment and PIN 2 is describe as "APC_Line_Fail", PIN 3 as "APC_UPS_SHUTDOWN", PIN 5 as GND and PIN 7 as +12V. I have connected an other UPS model (whithout communication) to protect power supply of NAS. But I'd like to shutdown NAS anyway when UPS battery is empty. Can you help me to find solution to communicate with NAS ? Do you think I need to send specific ASCII code to NAS or is it only change of Electric level on PIN's which trigger the shutdown process ? Thank you to everybody.
  • 3 Answers
SOURCE: Can't assign ip configuration to NAS 208
Run Fastora Assist, it should detect your NAS even if no IP address is assigned to the NIC(s). Make sure to connect all NIC(s).
Posted on Jan 10, 2008
map9966
  • 2351 Answers
SOURCE: Front panel connections
Hi sjcrofts,
The most common problem for most people is knowing what wire color is positive & which wire color is negative. The colors blue, red, green, light blue, light red & light green are normally positive. The color white & black are negative. Your board uses only 2-pin connectors. The 3-pin power connector can be turned into a 2-pin connector to work with the M848ALU pins.
(Page 13, PANEL1). How to? Take the three pin connector, on the back side of the connector you'll see a small tab that holds the wire into the connector. Use a needle & pull tab up while pulling the wire out at the same time. The wire should slide out. Insert the wire back into the connector next to the other wire. You do not need to hook up the SUS led which stands for suspend.
Pin 1 is positive & the manual shows this by adding the _P = positive.
Pin 3 which is to the right of pin 1, is negative for the hard drive led. Pins 9 & 10 are not used.
Good luck sjcrofts!
Mike
Posted on Nov 30, 2008
SOURCE: need wiring and 9pin connector diagram
Dell (Altec Lansing) A425 Subwoofer Pinouts
This is a standard female DB-9 serial port.
Here are the pinouts.
Pin 1 = Left Speaker Out +
Pin 2 = Left Speaker Out - (Common Ground)
Pin 3 = Left Line In +
Pin 4 = Right Line In +
Pin 5 = Left/Right line In - (Common Ground)
Pin 6 = Right Speaker Out +
Pin 7 = Right Speaker Out - (Common Ground)
Pin 8 = Power A
Pin 9 = Power B
Jumper (short) Power A to B to turn on.
If you want a volume control you need to put one on the inputs. You will buy buy a stereo volume control or potentiometer.
Here is some info on how to do this.
http://g4tv.com/screensavers/features/43665/Pump-Up-The-Volume.html
Cheers!
Posted on Mar 24, 2009
  • 336 Answers
SOURCE: Need SPDIF pinouts identified.
When looking at the board, bottom towards you assuming that the 3 pins are parallel to the pci/e slots, the left pin should be the +5V vcc the middle pin is the spdif out and the right pin is the ground. Also the 3 pins are probably not exactly the same distance from each other (equally spaced) the 2 pins that are closest together are the spdif and the ground, spdif is always the middle pin. This info is based on 2 different asus motherboard install guides. I hope this helps you.
Posted on Aug 12, 2009
Creative Con
  • 55 Answers
SOURCE: need pin assignment for model: m2n61-ax
If this is a Dell Inspirion 531 here is the owner maual with all the components
http://support.dell.com/support/edocs/systems/inspd531/en/OM/45605A00MR.pdf
Posted on Oct 10, 2009
Battert tab broke when attempting to remove (replace) batteries. Cannot get old batteries out of Smart UPS1000. Front-most battery appears to have swelled.
You'll need to remove the cover and battery cage from the unit. I've run into this before, just take your time and be careful there are likely some sharp edges inside.
When the batteries overheat and swell, they press against the metal in the unit and get wedged in.
I found a related post about APC 3000s.
Dec 09, 2012 | APC Smart-UPS 1000VA UPS System
APC Back-UPS Pro 1000: The original smart cable from the UPS to the computer is a serial cable. I'm looking for a serial to usb cable to replace it (the macPro that it will protect does not have a serial...
This older model APC does not support USB and it is inlikely that even if you found a cable that would connect them that the electronics in this unit would play nice with USB. Might be time to consider an upgrade, although these are a great units they just do not have the compatibility with newer computers.
Mar 29, 2011 | APC UPS: BP1000 Back-Ups Pro (UPSAPC08AS)...
It is possible to attach the 120 AH battery with APC 1000 va UPS
YES IT IS POSSIBLE TO CONNECT A LARGER BATTER TO THE APC UPS. IT WILL ONLY NEED MORE TIME TO CHARGE THE BATTERY.
Apr 10, 2010 | APC Smart-UPS 1000VA UPS System
Hello! I've problem with my APC Back-UPS 420 Pro.Often, when power on, after few minutes lighting OVERLOAD LED and so go on, while power off. Impossible working.
Hi friend,
You need to contat nearest hardware shop they will solve your problem because you UPS IC not working properly. otherwise you will lost your hole UPS.
Dec 17, 2009 | APC Back-UPS Pro 420 UPS System
Ups not working on generator power
you will try to change the fuse in ups
Aug 24, 2009 | APC Back-UPS CS 500VA UPS System
Reason of the three-phase UPS system stoped by cross current
The APC 1400 is a single phase device...I'm not sure what it is that transpired can you explain a little more in detail please
May 19, 2009 | NEC APC Smart-UPS 1400 (050-01803-000) UPS...
UPS Switching off while working
Hi kumaraswamy5,
it seems that either the UPS is connected to an outled which isn't grounded properly or the battery inside of the UPS needs a replacement.
On APC's website you can find the compatible batteries for your device and where to order them. Replacing the batteries is very easy so don't be afraid of that!
Greetings from Germany,
noris017
PS: Please don't forget to rate this advice after you've tested it out! Thanks in advance and have a nice day!
Feb 25, 2009 | APC (BE500U-WEB) (BE500UWEB) UPS System
To increase backup in apc symmentra ups
old school hollywood baseball old school hollywood baseball old school hollywood baseball old school hollywood baseball old school hollywood baseball
Feb 04, 2009 | APC Symmetra Tune-UPS technical support -...
Question about APC Smart-UPS 1400
This is the battery you need to replace http://www.batterywholesale.com/battery-store/proddetail.html?prodID=619
Ther are a few places to get one
Nov 03, 2007 | NEC APC Smart-UPS 1400 (050-01803-000) UPS...
Computers & Internet Logo
51 people viewed this question
Top Buffalo Technology Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Buffalo Technology Computer and Internet Expert? Answer questions, earn points and help others
