Question about GE JGRP17 Gas Single Oven
Hot steam from oven
When i open my oven door i get a burst of hot steam
  • GE Master
  • 2,651 Answers
Your oven does not generate steam, only pulls moisture out of what you you place inside of it, poultry being the highest moisture content, i would look into what you are cooking
Posted on Nov 18, 2008
Why can't I turn the temp higher than 375 or it trips the breaker?
One of the things that is causing this is the element. When it gets too hot it expands and is shorting out somewhere.
Jun 17, 2015 | Ovens
How do i clean the inside glass of a kuppersbusch oven ?
Hello, Make sure the oven is warm, not hot. Open the door and spray the glass with vinegar and water and wipe with newspaper.
Dec 11, 2014 | Kuppersbusch Ovens
Hi, does the oven work okay on hot air? Steam function uses the steam burner and hot air burner so there is alot of possible causes.
Mar 21, 2014 | Combi Ovens
GE oven controls lock after opening door and steam from cooked food comes out
you may find there is some insulating material missing internally as I would imagine steam affecting the front of the control panel
Nov 14, 2013 | GE JTP70 Electric Single Oven
Unable to remove blown Blanco oven light bulb-stuck fast
I boiled the kettle, added the hot water to a tray and placed it in the oven, shut the door then left it for 10 minutes so it steams up the oven (make sure power is off first). Do the same again. Then get a multi grip spanner and place a kitchen rag over the cover and turn to the left. It does take a bit of force depending on how stiff it is, but the steam will loosen the cover. The steam also cleans the oven quite a bit too!!
Mar 04, 2013 | Blanco Ovens
Seams to be a lot of steam/ vapour in main oven. when you open door cluds of steam escape. This is the 4000 twinline all electric model.
I have an electric oven and the same problem: loads of steam when I open the door. Plus roasting is a problem, the pan fills up with water and needs to be drained so things are stewing and not roasting. Have spent ages trying to to find a solution so would also appreciate any advice.
Oct 17, 2010 | Ovens
Tricity bendix double oven
My oven's fan is working but no heat what so ever what shall i do
May 07, 2008 | Ovens
Oven door getting too hot
other than checking the door seal itself, make sure its intact and door closes properly. make sure door' doesnt spring back open after closing does the opening along sid look to be even all the way up the side. maybe the oven door opens more than 90 degrees?? if it does id look into replacing the door hinges
Mar 14, 2008 | Ovens
GE JGRP17 Gas Single Oven Logo
194 people viewed this question
Top GE Ovens Experts
William Miller
William Miller
Dan Webster
Dan Webster
Are you a GE Oven Expert? Answer questions, earn points and help others
