Question about Nokia 8270
Not Charging Evrytime i go to charge the phone a message comes up saying 'charging' but straight after that it says 'not charging'. I have tried different chargers too. I assume there is a problem with the charging mechanism, is there any cheap solution? Can i fix it myself?
  • Pete Kiraly Dec 06, 2006
    I forgot to mention that i tried a new battery and the same problem occured - waste of bloody cash that was!
  • 28 Answers
U take a sand paper try to scrup at tiny metal that it join battery and phone.maybe you battery connetion is rusty.clean it
Posted on Jun 13, 2007
My galaxy S does not charge anymore. The charging signal does not appear. I tried different things without solving the problem. Here what I tried: a different battery, a different cable, wall charging and...
Hey,william its probably because the female port might have been damaged.So you should contact the customer care and get this fixed because doing it yourself shall result in bricking your phone..
Aug 17, 2014 | Samsung SGH Cell Phones
I cannot get my straight talk phone to come on after charging it
Hello, sounds like either your power cord/charger isn't working or your battery in your phone is bad. Try taking the battery out for at least 2 mins or more and put back in and try charging. If no of this works, and u bought the phone from straight talk, call cust support for straight talk or the manufacturer of the phone, they will walk you thru trouble shooting and get your phone fixed for you.
May 19, 2014 | Computers & Internet
I have a straight talk phone, android ZTE will not charge? ?
I am sorry to hear that your unable to charging your phone, did you try with different battery or charger, if you have tried and the phone still not charging than in this case you need to contact straight talk they will be able to fix the phone for you. The contact hot-line of straight talk is number 877-430-2355.
May 24, 2013 | Straight Talk ZTE Merit 990 GSM Android...
Iphone charging
Are you charging with usb? Sometimes it doesnt get enough pwer over usb so you may use the ac plug instead. If you experience that too, just leave it connected to the pc thru usb for sometime. Pls turn it off first. it could come up anyway.
May 02, 2013 | Apple iPhone 3G
Iphone will not charge..... message says charging is not supported with this accessory.
First Option:
mostly nokia chargers doesn't make problems...
just try the following..
connect ur mobile with a system (usb cable)...
found out whether it is charging or not...
if the same prblm appears then there is a prblm in ur cell phone or power jack(socket)...
if it charged with usb cable buy a new charger
Please change Phone Bettery and check the charging
IF Charging Problem not Solved So
Second Option:
Your Phone charging IC Fault So Please change charging IC
And charging Problem will Solved Quickly
Oct 21, 2012 | Apple iPhone4 4G iPhone 4
First Option:
Second Option:
Oct 21, 2012 | Apple iPhone Smartphone
Pantech ease battery
try a different battery and make sure the display indicates its charging
Oct 27, 2011 | Pantech P2020 Ease Crystal Screen...
How do I charge my Verizon Motorola Droid using the USB cable and my computer. I've plugged it into my computer, but it doesn't show that it's charging.
Plugging it into your computer should be no different then using a charger...it still uses the USB cable.
Here are a few things to check...
do not try a USB port that is off your keyborad or anything that does not come straight off of the motherboard...the phone pulls too much power and it will not work...
Try a different USB cable... some will not allow charging but will still tranfer data...
Also check and see if it asks you to install drivers for your phone...if it does, you will need to have them installed to charge the phone...
My best guess is that you need a different cable...
heatman101
May 12, 2011 | Cell Phones
Sometimes when i charge my phone it gives me a message saying "charger not supported." then in two days when i try it it works. Is there a way i can fix this faster instead of waiting two days?
It is because of the difference in voltage between different chargers... Also you will be facing similar kind of issues when the charging IC in your phone has become faulty...
Try charging your phone with a different charger and if you are getting the same message again, then the IC might be faulty in your phone...
Or if you are able to charge properly with another charger, then it is definitely an issue with the charger, better buy a different charger...
Feb 22, 2011 | Nokia Cell Phones
After charger is inserted , charging lights come on and battery indicater shows that is charging . After some time , an hour or so , a charging error message appears and says to stop charging . I purchased...
this problem was relating to your phones charging ic to solve this problem please change the charging IC WITH THE HELP OF A HARDWARE MECHANIC
Oct 22, 2010 | Cell Phones
Nokia 8270 Logo
35 people viewed this question
Top Nokia Cell Phones Experts
270rexton
270rexton
