Question about Motorola Mobility H700 Wireless Headset
People are having trouble hearing me with the h700
When talking with people, I can turn the hearing volume up and down quite easily. They are having trouble hearing me. Is there a way of adjusting the volume out.
  • akokkalis Nov 18, 2008
    i can hear very good but they cant hear me.
  • wylietcoyote Mar 04, 2009
    I have the same issue, I have a Black Berry Curve and it was working fine with the H700C until about 2 weeks ago and now i can hear the caller but that cant hear me. I have deleted the and reconnected the head set it doesnt work, It almost like the mic on the headset is on mute. (i checked the phone is not on mute)
Canuck703 Has the same problem people can't hear me but I can hear them really good on my motorola h700. Please help
Posted on Mar 04, 2009
  • canuck 700 Mar 08, 2009
    People can't hear me talking to them but i can hear them just fine. I messed with the volume but still doesn't matter. Please help thank you.
When I open the earpiece I can hear the person when I talk but when I talk into it noone hears me
If you have already checked the volume on the earpiece, there is probably a short in the wiring somewhere. If it is under or just over a year old contact Motorola about a replacement under the manufacture's warranty. Have a great day.
Dec 07, 2010 | Motorola Mobility H700 Wireless Headset
Can this be fixed
Try adjusting the volume not only on your bluetooth but also on your phone as well. The 2 volumes are not associated with each other at all. If that does not work still, your Bluetooth may not be compatible with your phone or you may have a defective bluetooth. Make sure you within 18 feet of your phone when talking on your bluetooth. Hope that helps!
Mar 18, 2009 | Motorola Mobility H700 Wireless Headset
Hearing from Motorola H700
good morning!! ive been thru this before, try tapping your phone volume while your talking to your party, it shold be seen on your phone screen as earpiece volume than turn it up and when you have the volume where you want it dont forget to tap the set on your phone, another prob i had was some times there is a small protective plastic film on the ear holes on the tooth and one on the mike sometimes, i could hear my party but they couldnt hear me until i discovered that lil peice of plastic. remember your key codes are either 0000 or 1234. good luck m.m.
Jan 26, 2009 | Motorola Mobility H700 Wireless Headset
Earpiece volume on my motorola h700 is low.
while talking to your party try the volume on your phone, it should come up as bluetooth or earpiece volume if it does just turn it up and dont forget to hit the set button. good luck m.m. p.s. some times the volume isnt set at the factory. im fighting that problem now on two of my seven h-700s. this may be a solution it may not im letting you know my experiance as best as i can.m.m.
Jan 22, 2009 | Motorola Mobility H700 Wireless Headset
Screeching
These trouble shooting suggestions where taken from here. There are more things they suggest trying but this cutout pertains to your problem more so than other suggestions. If these do not work I would recommend reading through that guide.
Noise or Feedback:
  • A screeching noise when you talk you are experiencing feedback. Turning your TV down should help.
  • Loweringthe headset volume can also help. Go to Accessory Settings/ AudioDevice Settings (where you test your headset) and you can set the micvolume there. Level 3 is a good start. If people have trouble hearingyou then you should raise to Level 4 or Level 5.
  • Ifyou hear an echo when you talk try turning the earpiece volume down onthe headset. Many BT headsets have their own volume control.
Also, while the PS3 is compatible with almost any Blue tooth 2.0 headset, I have heard of of problems like this occurring where the headset had to be replaced by a different model to solve the problem. As far as I know this is the only headset guaranteed to work by Sony.
Jan 03, 2009 | Motorola Mobility H700 Wireless Headset
Blinking Indicator Light When in use
press the volume up and volume down keys at the same time and hold them until the light quites blinking you have to do this every time you turn your headset on
Sep 05, 2008 | Motorola Mobility H700 Wireless Headset
How do you reset it?
Turn the headset off (flip the boom in) then hold down the talk botton. The indicator should turn solid purple. Keep holding the the talk button and turn the headset on (flip the boom outward) and then it should stay soild purple and ready to pair with your phone.
Good luck.
Jul 19, 2008 | Motorola Mobility H700 Wireless Headset
How to do pairing
Thank you. I called a 1-800 number for tech support but they told me I had to wait 14 days from the date of purchase before they could help me. Your suggestion was right on the money. Thank you.
Jul 18, 2007 | Motorola Mobility H700 Wireless Headset
Problem with Motorola H700 Bluetooth
rhondarenee: If you're using a Motorola RAZR V3, the problem is the cell phone. Also check the volume buttons on H700 that sometimes it goes the volume all the way down. It is a common unnoticed situation. SithPitt
Jul 04, 2007 | Motorola Mobility H700 Wireless Headset
H700 headset can't hear me!
Push both volume buttons at once to turn Mute off. You should hear two beeps, ascending in pitch to indicate mute is off. If they go down in pitch mute is being turned on.
May 09, 2007 | Motorola Mobility H700 Wireless Headset
Motorola Mobility H700 Wireless Headset Logo
155 people viewed this question
Top Motorola Mobility Radio Communications Experts
Coss
Lawrence Oravetz
Are you a Motorola Mobility Radio Communication Expert? Answer questions, earn points and help others
