Question about Sharp AR-M205 Copier
Sharp arm 205
I replaced the developer, not the toner. After this Istartedhaving the white stripe on the papers in a horizontal fashion,alwaysin the same place. I noticed developer dust on thedrumcorresponding to the place where the stripe is on the paper. Iremoved and replaced the drum and blade. This worked onlyverytemporarily and there is still the dust on the drum in thesamelocation. I also noticed that the mylar tab on the developerunitwas pushing on the metal roller and collecting developer, but Ibentthis back so it does not occur anymore. I also vacuumed outthedeveloper unit in the process of replacing the developer. Ididblow out the transfer charger with air and also blew out the wirecagein the drum unit when I replaced the drum. Any thoughts?
Thanks
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 115 Answers
This worked only very temporarily and there is still the dust on the drum in the same location.
If this went away after you changed the drum and cleaned it out, I would guess it is something in the process unit itself. The Charge..
Is the Drum Scratched after a few copies? Is there a Band around the drum?
Are the separator pawls bad? Do they have movement, are they touching the drum? I have seen this collect dust, get stuck and ride on the drum scratching the drum...
There is the Cleaning blade, the other side is a piece of Mylar which also cleans, is it warped, bent.
If so I would replace the Drum Frame (they call it the Process Unit CFRM-0049QS51 , and the main charge, MC holder unit CHLDZ0035QS53 or what you refer to “wire cage in the drum unit”)
Open the top of copier; make a copy with the lid open. The page made should be black. This is called a Sky Shot, do this in between each thing listed below... look at each copy to see if there is a change.
do a sky shot,
open the side door as the paper just reaches the drum, your drum should have a consistent black around it. This is good a good way to find lines, is this happening before the drum or after.
If there are lines on the drum (no scratches on it) then it is in the optics, or process unit (drum/developer) or laser, if the lines are past this point,(no lines on drum) then it is in the charge.
This is what I would do if I were standing in front of your machine...
First. Open the side door on the right side, there is a transfer charge there. Clean that out with some air. And gently wipe it with a Lint Free Cloth.
Do a Sky Shot
Second: Remove the Drum, take the Charge Unit off the drum, clean it very well, hold it to light look for a spec of dust. You might think you have cleaned it, and not see it, when you make a copy does this line move if so, there is dust in the charge. do a sky shot copy..
To clean it, the Grid will come off with some needle Nose pliers, pull the one side with the tab to get it off, wash it off (soap and water works, drag you finger over it), let it dry, do no use any thing that will cause lint to get on it, the saw tooth part in the charge, you can use styro-foam poke some down in there. Put it back together, Make certain it is dry.
I usually replace this piece. All this is too much hassle, and it is a pain to get it back together.
Do a Sky Shot
The Charge is usually what cause's a white line…
As for the Developer and that Mylar bent piece. Look at it again, then in a week or two again. Bending it some times works for a little while. Is it turning brownish, and curling. If so it is old and needs replacement. This part comes in a regular maint kit, I believe it is replace at 150k copies (I could be wrong on that), I change it every other PM. I think this is the part number- PSEL-0001YSZ1 DV plate
It will collect developer and builds up and cause problems such as DV dumping, etc etc...
And changing your drum, did you use Setting Power. The drum and blade should have a little setting powder on it, if not this is necessary, otherwise your drum will squeak against that blade.
Posted on Nov 21, 2008
Motor does not run properly
What motor are you talking about the fuser motor, paper draw motor, the finisher motor, the transfer motor, the drum motor, the developer motor, corona wire transfer cleaning motor. I can go on.
Replacing developer and toner has nothing to do with the motor running,
Aug 06, 2014 | Sharp AR-5320 Black and White Copier
I'm getting a line that isn't printing through my printing from a Fuji Xerox DocuPrint C3055 DX
Possible reasons are: 1.empty toner cartridge, 2.dirt under one of the toner cartridge's developing roller, 3. dirt on the primary charge roller in the drum cartridge, 4. obstacle on the laser path.
Replace the empty toners first and try printing again. Follow the next steps if it didn't solve the problem.
Print a test page with 4 stripes across the page - black, cyan, yellow and magenta. See if all have the missing toner line or only one of them. If the white stripe is going trough only one color, inspect the cartridge with that color. It has to have the same stripe on the developing roller. See if there is some dust beneath it that makes the stripe and clean it with a brush. If the stripe is across all colors, then inspect the drum unit. The drum itself has to be evenly shining on the light. If there are uneven matte tracks on it, consider replacing. There should be a gap somewhere for the laser beam to pass and the drum is visible trough it. Look trough it for obstacles like piece of paper or hair. The primary charge roller has to be close to that gap inside, touching the drum. Look for dirt on it. Clean if possible.
Toner cartridges last approx. 6500 pages. The drum cartridge lasts between 14 000 and 28 000 pages depending on the color use.
Jul 02, 2014 | Digital Products Office Equipment &...
Can i use sharp ar m205 toner for my machine sharp ar205. thanks
Hi S Samra,
Its no problem you can use ARM-205 toner for AR-205. Both same powder.
Regards,
Rakshita
Jul 08, 2011 | Sharp AR-M205 Copier
I have a white stripe on the copies. I just installed a new toner cartridge, and cleaned the transfer charger. I have a Sharp AR-162S copier that is 3 - 5 years old. Thanks.
Hi check the developer unit make sure it is coated end to end some times the blade on the developer gets foreig matter stuck and prevents the developer/toner to go onto areas of the developer mag roller also check and make sure the transfer corona wires are in good condition no black marks on the corona wire if there is replace the wires
Feb 15, 2011 | Office Equipment & Supplies
Get F2-40 error on sharp ar-5520 Im a newbie in
How are you , this problem occurs when there is very low toner concentration on the unit or low developer.
solution
  1. Replace a toner cartridge and make sure it is smoothly running as some come with hardened toner or
  2. Replace a new developer which is Sharp Ar 205 dv Check that the toner motor is rotating well
This error is self resetting so no need of simulation code. Bye.
Oct 21, 2010 | Sharp AR-5316 Advanced Digital Imager...
SHARP AR 5012 developer reset
i have a sharp sf 1025 , and i want to reset developer conter? can u help me pls
Jun 25, 2009 | Sharp AR-5320 Black and White Copier
I am not a sharp tech but I have a client that put in new develop
I of my fellow works had a CD wirh the manual on it for the sharp AR205
Mar 19, 2009 | Panasonic Office Equipment & Supplies
White stripes on pages copied from ARM 205
If you changed your developer? Or did you change the Toner Cartridge?
White stripe? Check the charge on the drum, it might have a piece of dust on it.
take the charge out, (dont take it apart) hold it up to some light, you might see some dust particles hanging in the grid. If so, rub very lightly with finger, do not use a cloth to clean. Blow it with a can of air.
Clean the transfer charge as well
Usually replace those as it is such a pain to clean on the smaller machines.
if you need any further help let me know
Thanks
Nov 05, 2008 | Sharp AR-M205 Copier
Horizontal black and white lines are coming on copy
you don't mention whether the document you are copying also appears on the paper.If it does you could have 1 of 2 problems-
The drum cleaning system could be at fault or-
the fuser roller has picked up some **** easy test...... run copies and when the 1st copy edge appears switch OFF. This is a crash stop.Now examine the sheets in there.Is the stripe on the copy before the fuser (Heat) roller? If yes you could have a drum cleaning problem, usually fixed by changing the drum module.If no and the stripe appears after the heat roll, the problem is with the fuser system,dirty rolls etc. There are a number of other problems with stripes, but you have to start somewhere! If the document does NOT appear on the copy, forget all above, could be scan or ROS problem
Jul 20, 2008 | Sharp AR-5320 Black and White Copier
White "Stripes" across page
REPLACE PAPER AND THE INK CARTRIDGE
May 14, 2007 | Sharp UX B700 Plain Paper Inkjet Fax
Sharp AR-M205 Copier Logo
224 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
jasbo
jasbo
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
