Sony WEGA KV34HS510 Clicks when turned on, but get no picture and the standby light flashes.
  • 1 more comment
  • janie57 Nov 18, 2008
    it flashes 3 times, pauses, then 3 times and so on.
    Thank you all for trying - I have no electronic experience, so it's time to call a technician.
  • Any Guy
    Any Guy May 11, 2010
    How many times does the standby light flash?
  • 320 Answers
A 3 flash shutdown indicates a low voltage condition in the power supply (the D board) If you have electronic experience, I can walk you through some things to check. Otherwise, it's time to call a technician
Posted on Nov 18, 2008
My sony wega KDP57WS655 tv wont turn on...makes noise like it is coming on, clicks then turns back off and standby light is flashing
If the red light is blinking in front that sasy lamp. Your lamp needs to be replaced. They cost about $100.00 at your TV Fix It shop. Very easy to replace yourself
Nov 20, 2012 | Sony Grand WEGA KDP-57WS655 57" Rear...
  1. If your Sony Wega will not turn on, the front green light blinks, you hear a faint whirring sound and the green light turns red and flashes, it probably means the lamp inside the set is no longer working. If you noticed the screen beginning to dim in the preceding days or weeks, this most likely is the cause.
  2. If the green light flashes and the picture comes on momentarily but then goes off, and the green button flashes until the set restarts, then the seal around the lamp mount is loose and needs to be refitted.
  3. If the picture on your Grand Wega cuts in and out and the green standby light flashes, both of the set's STKs need to be replaced. STKs are small chips on your television's circuit boards and are identifiable by their labels. The specific STKs used in your Grand Wega TV will be identifiable by the numbered labels on top of the STKs.
  4. When you plug in your Sony Wega and hear a loud popping sound, it's probably caused by a defect in the high-voltage circuit. Let the professionals take care of this one.
  5. If, after turning on your Sony Wega, you can hear your set but the screen is black, you most likely need to replace your projection lamp.
Read more: How to Troubleshoot a Sony Grand Wega '
Feb 23, 2011 | Sony Grand WEGA KF-42SX300 42" LCD TV
My Sony Wega Trinitron KV-32HS20 does not tun on and the standby light flashes 4 times. I can hear the sound but no picture and the it turns off automatically after a few seconds.
This is a tip I got from a tech bulletin.
IC600 output pins 14, 15, 16, all have aprox 130v (all should be higher) until relay clicks
then they drop off. 200v line goes up to 50v, 135 goes up to 40v.
Checked D611 (135v rectifier) it was fine. Checked D615 (It's labeled D601 on the board)
it was shorted. (D615 is the 19v rectifier for the Audio B+) Removed D615 set power up
and has good picture with no sound.
Sep 08, 2010 | Sony FD Trinitron WEGA KV-27FS100 27" TV
The picture goes off, the power/standby light
Sony KDF-60XS955 picture goes and power/standby light light flashes
Most likely you have bulb failure. First step in troubleshooting is "Change the Lamp or Bulb". Lightning, power line bumps and collisions with vacuum cleaners can all shorten lamp life. Rough handling in shipment can also happen without your knowledge.
+90% of all Sony LCD Rear Projector "No Picture or Intermittent Picture" faults are related to bulb failure.
If new lamp does not improve the situation, then hands-on troubleshooting by someone that has parts and knows how the unit works is the only practical remedy.
Mar 14, 2010 | Sony Grand WEGA KDF-60XS955 60" Rear...
My kv34hs510 will not power up and the standby light flashes 6 times and then repeats.What is wrong? Ron....
There is a power issue,tv goes into standby (safety) mode. For self-diagnostics, press Display,channel,5,volume - minus not plus,then press power. You have no horizontal output,check IC206,C516,C515....for service mode press Display,Channel,5,volume + plus,then power,press8,then enter......hope this helps....
Mar 08, 2010 | Sony FD Trinitron WEGA KV-34HS510 34" TV
No sound or picture-just clicks when turning on-standby light flashes 5-7 times
it is problem in power supply.may be some of components are demage such as capacitor or diod and mosfac .Repear it by a good technician in your area.
Nov 22, 2009 | Sony FD Trinitron WEGA KV-36HS500 36" TV
Sound went out, tv turned off, red light flashing...
The Lamp being bad as well as one of the three fans in the unit not turning could also cause the problem.
Hope this helps,
Jul 23, 2009 | Sony Grand WEGA KDF-42WE655 42" Rear...
Sony Trinitron TV. No picture; red standby/timer light flashes.
My Sony trinitron has the stero lite on steady and standby lite flashes four times then pauses and repeats. Can you tell me the circuit/condition causing the set to not turn on.
Jul 15, 2009 | Sony FD Trinitron WEGA KV-36XBR800 36" TV
Sony wega 50 inch clicks and flashes 3 times and goes back onto s
If its model number is KF-50WE610, had you replaced its Lamp recently?
If Lamp is replaced, please check Lamp cover/ door that is not seated properly, make sure its fixed securely.
3 times light flashing shows Lamp cover error.
Jun 27, 2009 | Sony Grand WEGA KF50WE610 50" Rear...
Televison & Video Logo
143 people viewed this question
Top Televison & Video Experts
