The radio work but no sound, and after few minute our couple of hours, sound come back ??????? I check all car ground and every one is ok ?
SOURCE: Honda radio says ERROR E
You only get like 10 tries this means you made to many attempts trying to put the wrong code in. Disconnect the battery cable and then try putting the code in the radio again.
SOURCE: 2004 Honda Accord Radio fuse blows
There was a recall for the 03-04 Accord radio. It had faulty circuitry that caused the screen to go dim. Check with Honda to see if they'll still honor the recall.
SOURCE: 2004 honda accord engine light on and jerking
Sounds like the EGR Valve, Get the check engine light checked at your local garage or autozone or advance auto.
SOURCE: 93 Honda Accord has No spark, timing belt is ok.
change your distributor the problem is your camshaft position sensor
than is part of the distributor and check all fuses.
I seen this many times.
Good luck :)
SOURCE: Radio code
I think if you remove the radio fuse for a few seconds it will start the code required sequence over. This next part from Honda owner's manual for 2002: "When the radio shows "code" then enter the five digit code using the radio preset buttons. If you make a mistake, do not start over--complete the five digit sequence, then enter the correct code next try. You have ten tries to enter the correct code. If you are unsuccessful in ten attempts, you must then leave the system on for one hour before trying again."
