Question about Philips 43PP9202 43" Rear Projection Television
PHILIPS 43PP920217 DPTV305, no video feed after Conv IC Install
Essentially, got the tv for free, the convergence was all messed up so I replaced the factory STK392-120's with the same ones put the thing back together and now i get all my projectors lighting up but can't get any actual video feed out of it. I can change channels and hear them fine but no video feed other than a mix of the colors with no changes. So I guess I'm trying to figure out where to go next, I checked over all the boards for blown anything but can't find a single thing wrong. Anyone have any ideas where to go next?
  • Philips Master
  • 5,138 Answers
You should have used 180s for replacement,and check all low ohm resistors near ics.And alot of time when you replace them you have to have service code to be able to Factory converges and realine.Need help let me know.
Posted on Dec 24, 2008
Red color distortion hitachi 46f500
Can't remember which this one uses but its right on the chips. Check your resistors too.
Apr 08, 2009 | Hitachi 46F510 46" Projection HDTV
Have an Hitachi 51UWX20B that has the 3D thing going on, when I adjust it manually, and exit, the TV wont let me save, cancel, reset, or go back! Have to turn TV off to get out of that screen. Any advice...
Do not adjust any knobs as instucted in the previous thread if you TV have a convergence problem. Doing so will only make things worse. The blog does however show you how to fix other common problems with these sets.
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
2c07611.pngSolution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
Feb 21, 2009 | Hitachi 51UWX20B 51" Rear Projection...
Convergence board swap questions....
You can try to change it out and go to convergence adjustment mode on service mode to setup the template.
But I rather replace couple trans and leaky diode on your old convergence amp board to save my time
Jan 06, 2009 | RCA D61W20 61" Rear Projection Television
Convergence problem
did you replace the six convergence resistors with the ICs? as Hitachi recommends replacing the six resistors when the ICs are replaced as the old ICs can harm the resistors and they will need replacement.
Sep 27, 2008 | Hitachi 53FDX20B 53" Rear Projection...
I have a 60 inch mitsubishi projection tv model # vs-60609 and the convergence is messed up...the tv guy said it needs a chip or a someboard... need help in finding part or needing to know if it can be...
You need to replace the convergence IC your set only uses one IC ( Chip) its STK393-110 you can get a replacement IC at the following link and they provide free instalation instructions with pictures and free shipping. Here is the link.
http://servicemanuals.vstore.ca/
Jul 09, 2008 | Televison & Video
Messed up Image
You need to replace both of the convergence ICs. They are both STK392-570 you can get replacement ICs at the following link and they provide free instalation instructions with pictures on how to replace the ICs. Here is the link.
Jul 08, 2008 | Mitsubishi WS-55809 55" Rear Projection...
PT-53WX42F
Convergence amp ic bad
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
http://www.hdtvoice.com/voice/showthread.php?t=28929
Sony Convergence
http://www.techlore.com/blog/entry/19694/Sony-Convergence-Repair-My-Sony-TV-has-a-distorted-picture-/
http://www.techlore.com/article/19631/Sony-Convergence-Procedure/
Jan 26, 2008 | Panasonic PT-47WX49 47" Rear Projection...
HCM4216W Convergence Problem
the convergence problem you had before, re- occured
Sep 25, 2007 | Samsung HCM4216W 42" Rear Projection...
Convergence issue
You can go back to factory settings by pressing and holding the ACTION and POWER buttons on the TV while it is on. A CHK screen will appear and when it does release the buttons and then power the set off then on again. This had reset all settings back to factory conditions. You will have to reprogram any channels into memory after this.
Mar 29, 2007 | Panasonic PT-51G44 51" Rear Projection...
Philips 43PP9202 43" Rear Projection Television Logo
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
