When i turn on my computer, it goes directly to a black screen and it says, "Internal hardisk drive not found..." and i do not know the rest.
  • 8 more comments
  • RandyNEWWIN Nov 18, 2008
    ok, i dont have any usb stuff in their, and idk how to do the rest of the stuff u just told me....plus, more info, it doesnt go to my desktop. i have a dell and when i turn it on, it loads and then stops then it goes to what i told u before.
    ok hold on a sec let me get it ready...it takes a little bit so hold on
    ok im bak, srry bout that. ok i dont really now what that is but ill check
    ok, i have a dell inspiron, and my servise tag is 4gml0g1 and express code is 9712520065
    ok i just tried turning on my laptop and here is what it says..."in ternal hard disk drive not found to resolve this issue, try to reseat the drive.
    No bootable devices-- strike F1 to retry boot, F2 for setup utility ress F5 to run onboard diagnostics.
    thanks man, ur a big help, u possibly saved me in school
    i dont think this is correct becausei have a dell inspiron 1525 and the link sends me to a 4000
    i did what the link told me to do, but when i turned it back on, it goes back to the same screen. plus it doesnt have Primary Hardrive as an option in my computer. do u know anyother way?
    i dont want u to hury up but i have to go in a bit sorry
    im sorry but i have to leave now, thanks for all ur help, ill be on tomorrow and ill ask agian. THANK YOU
    Novelist:
    Scholar:
  • 84 Answers
Before you encountered the problem,. have you installed any hardware/software? you need to make it sure that there is no other devices connected to the computer like any USB external devices.If so, disconnect them and try rebooting your computer. If still doesn't work, try to check your hard drive in the BIOS or you may need to reseat it.
Let me know what type of system you have.
Keep me posted.
Thanks.
Posted on Nov 18, 2008
  • 5 more comments
  • Jeff R
    Jeff R Nov 18, 2008
    hi,
    Thanks for your immediate response.
    Let me know the type of system you have so that i can walk you through how to check the hard drive in the BIOS and try reseating it.
    Thanks.
  • Jeff R
    Jeff R Nov 18, 2008
    Hi
    It would be easier if you can provide me the Service tag or express code.
    Thanks
  • Jeff R
    Jeff R Nov 18, 2008
    Service tag can be found underneath the laptop. It like a serial code with 5-7 characters.
  • Jeff R
    Jeff R Nov 18, 2008
    Press F2 to go to system BIOS. When you are there, please check if the hard drive is detected under Primary Hardrive. If it says None then the hard drive is not detected. You may try reseating it.
    You may follow the link below to reseat (unplug/replug) the hard drive. But you need to unplug the power adapter and take out the battery then press and hold the power button for 5 seconds without the battery and the power adapter.
    http://tinyurl.com/6e2kyx
    Keep me posted.
    Thanks
  • Jeff R
    Jeff R Nov 18, 2008
    I apologized. But that was it shows on the service tag you gave me. but don't worry. i will send you another link.
    Please wait.
    thanks
  • Jeff R
    Jeff R Nov 18, 2008
    Randy,
    Based on the information you told, since the hard drive is not detected after you reseat it in the BIOS then you might need to replace the hard drive because it is failing or could be damage. The reason why it's damage because it could be that the system was not properly shutdown.
    I suggest to call your computer manufacturer and check if the system still under warranty to replace the hard drive free of charge.
    Keep me posted.
  • Jeff R
    Jeff R Nov 18, 2008
    No worries, just keep me posted.
    Thanks for your time. Take care.
Say operating system not found
Reset bios to defaults and try again. If that doesn't work then its possible that your hard drive has failed.
Nov 08, 2013 | Samsung R580 Notebook
The computer does not boot into the operating system and displays "Operating System not found."
For that problem, do this first check-up your bios setting.
Power on your PC laptop
, when screen popped up ( press F2, delete etc. ) to get into standard bios Setup you see there if your hardisk drive detected or not detected. if not detected try to open your Laptop PC ( need power off. open cover at the back of your laptop ) check-up your hardisk drive for loose power cable, data cable hardisk Some burn , noise hardisk sound ) if detected, your operating system corrupted. you need to Reinstall your operating system like windows xp, windows 7 or linux base operating system. try that Solution first.
Just let me know if not yet working your laptop PC.
Regard.
Aug 26, 2011 | Toshiba Satellite M30 Notebook
Sata hardisk is not working "usb not recogenised"
Connect hardisk directly to computer without usb
go to start > run > cmd
type chkdsk /p enter
it will fix your problem
remove hardisk via safe remove
and connect via usb cable
Jul 29, 2011 | Conrad WD HDD 250GB SATA 35" WD2500AAJS...
I have a " My Passport Essential Ultra-portable
Your portable harddisk is not working because the hardisk inside is bad or damage, try to change the hardisk inside. it also happen to me and when i chage the hardisk it works.
Thanks for using Fixya
Jun 01, 2011 | Western Digital My Passport Essential...
"operating system not found on
hard drive failure, replace the drive.
Dec 13, 2010 | Compaq Presario 5000 PC Desktop
"Computer screen goes completely black,
first check your screen and verify if your monitor is problem. you can use known good monitor to verify.
Second, check your VGA cards. you might want to reinstall VGA cards drivers. If you know the brands you might be able to download your driver here.
Oct 30, 2010 | Computers & Internet
When i start my computer it says press f1 to
This means your hard drive has either failed or is disconnected.
Given the age of the computer it's most likely the drive has failed.
Let me know if there is important data saved on the computer. Otherwise, replace the drive and re-install windows and it should work again.
Crankstart
Jan 08, 2010 | Dell OptiPlex GX150 PC Desktop
My computer won't turn on and it goes to a black screen with words and then i click start windows normally and it goes to a blue screen then stops, how do i get it to turn on?
The blue screen states that it has a hardware error. Usually the problem is in the memory card. All you have to do is open your computer (cpu) and removed the memory card. Try to blow the memory slot and try to clean the memory card pins with a clean cloth and return it back to the memory slot. After that try to turn it on if it works. If not, try to replace the memory card if you have a spare.
Aside from memory card problem is the hardisk problem but usually rare. Try the memory step first before the hardisk step.
Jan 03, 2010 | Dell Latitude Cp, Cpi, Cpx, C600, C800,...
Computers & Internet Logo
107 people viewed this question
Alun Cox
David Payne
David Payne
