Question about Epson Stylus C84 InkJet Printer
The new ink cartridge is not dispensing its color.
I've been using Epson Stylus CX2900 for 1 1/2 years only. I changed the blue ink cartridge because it was empty. The new Epson blue ink seems to be not dispensing its color. I tried to print pictures with lots of blues and greens but the pictures all came out with colors orange, yellow, pink, black and brown. Every time I change inks (genuine EPSON ink cartridges) that is always the problem. It doesn't dispense its color. It's consuming a lot of ink for the other 3 colors and yet the blue is still the same.
Could you please help me with this. I've wasted a lot of ink because of this problem.
Thank you.
  • Gerry Millward
    Gerry Millward May 11, 2010
    Please post a new comment to confirm that you still have this problem and we can then try and solve it.
  • 353 Answers
Have you tried a cleaning cycle? If not, try one (right click the little printer icon in the bottom right corner of the screen and select head clean). Now run a nozzle check (right click the little printer icon in the bottom right corner of the screen and select nozzle check). Is there any sign of ink on the paper. Try up to three
cleaning cycles. If ink is now flowing, but not yet perfectly, don't carry out any more cleaning cycles. Just leave the printer for 24 hours (to allow any air in the print head to disperse). Then repeat the cleaning cycle/wait process. It may take a while to restore a perfect nozzle check print.
If these actions produce no positive results, or if you have already done lots of head cleans with no result, and you're sure you have a good ink cartridge properly installed, then you can try soaking the print heads for 24 hours (or more), as follows. Turn the printer
on, and as soon as the print head moves pull the power cord out of the back, or turn the printer off at the mains. You may now carefully move the print head by hand over to the left hand side out of the way.
Look inside the print head parking area on the right and you will see a rubber cup that comes up to cover the print nozzles when the head is parked (to stop it drying out). Use a syringe or dropper to fill this cup with head cleaning fluid or distilled water. DO NOT USE TAP WATER. Carefully push the print head fully into its parking position so that the cup full of fluid comes up over the print head. Leave this for at least 24 hours, then try a head clean again. Repeat this process again if necessary.
If still nothing, it looks like you may have a failed cyan print nozzle I'm afraid, or some other internal problem. This will require checkout by a Technician. Make sure you compare the cost of repair with the cost of a new printer!
Posted on Feb 28, 2009
SOURCE:
Epson txt 121 not pronting blue
Replace the ink cartridge for color- you've likely run out of Cyan ink
I’m happy to help further over the phone at https://www.6ya.com/expert/susan_42b401e0b1603d8a
Jul 16, 2011 | Epson Stylus Photo R220 InkJet Printer
Head cleaning not working
Doesnt sound like you Used Genuine Cartirdges?
Did you use Epson Genuine Cartridges? ALL…. Epson & Brother Requires Genuine Cartridges. !!!!!!!!
That sounds like your problem.
In Purchasing Epson's CX 5400, CX4600, & CX7400 and more, I found out that Epson does not like Generic Printer Cartridges. I also Purchased a Brother MFC-240C All-In-One InkJet Printer. That also does not like Generic Print Cartridges. Color that should be Yellow, will turn out Green, Blue Brown, etc.
These printers have a CHIP that will detect if it is Generic or Genuine. When they see it’s Generic Cartridges, it will print lines thru the words, stripes across the picture and also do a mix match with the colors. It also will not let you print anything, if only one of the cartridges is empty.
I wanted to print only Black, and would not let me, because I did not have any ink in one of my cyan cartridges. Go figure.
That's what these Companies do., so they can keep selling the ink cartridges. Some Printers, are able to use Generic, and some are refillable. Some you can refill them up yourself and I heard, quite MESSY.
So I learned, thru trial and error, that you must use the ORIGINAL Genuine Cartridges for these PRINTERS. Some people say some models work fine compatible, but not mine.......
I had to replace the printer, but Epson, Lexmark & Brothers are always on sale. My Brother & Epson cost me $50.00 with Rebate. .
IF YOU ARE USING GENERIC CARTRIDGES, MAYBE IT WOULD BE BETTER IF YOU DISABLE THE INK MONITOR.
This is the only advice I can give you.
The next step would be to disassemble the Epson, and clean the Pads/Heads. Click on link below.:
http://www.hm2k.com/posts/parts-inside-your-printer-are-at-the-end-of-their-service-life
I located a page on http://www.fixyourownprinter.com forum, which had plenty of details about similar issues.
If you find this helpful, pls rate me.
Thanks and Good Luck :0)
Apr 04, 2010 | Epson Stylus Color 740 InkJet Printer
My Epson stylus 84 color printer is only printer the color blue
Hope you have installed a original ink.
Take the cartridge out, wipe the extra ink on the cartridge and carrier with little alchole and cotton. and reinstall the cartridge back.
Print a test page and let me know
Kevin
Apr 06, 2009 | Epson Stylus CX5000 InkJet Photo Printer
I have a epson stylus printer C65 series. I ran out of black ink so i changed the ink cartridge and it will only print colour not black now.
I have an Epson stylus 6000 series, second hand but was working just fine. I changed the ink cartridges and now the color won't print. Utilities shows all cartridges full, but only black and pale green-blue print. While it was printing color it was drinking the ink, but that's another story.
Yvonne
Aug 09, 2008 | Office Equipment & Supplies
Epson stylus c45
epson.com, actually you can print using black ink only, but you have to reset the color ink for it to register as full. :) or you can freeze the ink counter using the ssc service utility before the other ink rans out. :)
Jul 17, 2008 | Epson Stylus C46 InkJet Printer
Blue tint suddenly appearing on all my photos
you may need to run a clean on ur nozzles and check if you are low on ink.
Jun 13, 2008 | Epson Stylus Photo R300 InkJet Printer
Ink not empty
You have confused the software in either changing a cartridge when not required or having a chip failure whilst changing multiple cartridges.
Full info on how to get out of this is on my site.
Please go to my website http://www.the-inkstore.co.uk . I have the latest version of SSC Service Utility to download directly onto your computer and instructions on how to use it, what to click on etc etc. Click any of the Epson links if you can't find it, everything you need to know will be there, including printer Firmware resetting which sorts out a multitude of problems.
The 'maintenance required' problem with Epson printers has absolutely nothing to do with which cartridges you are using, it is a built in page counter in your printer firmware, which has a different maximum amount for each Epson model. Don't listen to old wives tales and heresay, we are the experts and it's an Epson scam to cause a lot of people to pay for maintenance or throw their printers away.
I haven't found a model that can't be reset with the latest version of SSC Serve or the manual reset on my site.
For Epson RX500 users there is also a manual reset on my site, as the SSC Serve software won't do it for you.
When using the program & choosing your printer from the list, it may have a weird name with 'x' in the model number, this is because some configurations are for many models in a series. For example, the C46 will be listed as C4x as it is for the C42, C44 & C46 models.
I hope this helps all Epson users to overcome the Epson scam of page counting and locking out until you pay their dealers money for maintenance.
If you like what I've done for Epson users, please show your appreciation by spreading the word and perhaps buying your ink from my site.
Happy trouble free printing
The INK Store (UK & Europe)
Apr 13, 2008 | Epson RX620 All-In-One InkJet Photo...
Epson Stylus C84 InkJet Printer Logo
208 people viewed this question
Top Epson Office Equipment & Supplies Experts
Inky Fingers
Inky Fingers
Clive
Clive
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
