Question about Poulan Featherlite Gas Blower, with Low Emission Engine, 150 M
Runs only with choke at half position
Blower is only 2 months old. now harder to start. with choke at half position, it's not attaining max speed --> lower air velocity --> less ability to blow leaves, etc. gas/oil mix at recommended blend.
  • gary Nov 18, 2008
    thanks for the prompt response! it will be about a week before i can try some of your suggestions as i will be traveling. i'll update this site as soon as i get back home. just fyi... i just bought new fuel so i'm going to be very disappointed if it's a fuel issue. also, i've probably only used it about 5 hours. thus, a clogged filter, needs wd40 etc, etc also seems like it's needing a lot of trouble shooting for a "new" blower. regardless, i'll give your ideas a try. thanks much!
  • gary Nov 24, 2008
    OK. Emptied the fuel & the fuel filter looked like new. Checked the air filter & it had a small amount of discoloration in one small area. All in all, looked ok. The spark plug also slightly discolored. Cleaned it & added a spray of WD40. Also used carb cleaner after starting it. Not quite as hard to start but still will only run at half-choke. No speed increase or decrease on the throttle lever from half to full & back to half.
    Yep, its a FL1500LE.
    Spark is good, compression seems ok on starting, so my thinking is either the gas is bad or there is a carb issue. I'll get a new gallon of high-octane & new oil mix to try.
    Other suggestions????
  • 659 Answers
First and most easyest solution would be to empty the gas tank and check the fuel filter to make sure it is not plugged or damaged.
Secoundly your carb could need a good cleaning and a new spark plug may help as well
and one last thing if hard starting pull the spark plug out and grab some WD40 and give it a shot inside and then put the plug back in and it should help I ushally do that with my machines every spring startup.
but also just to make sure you have the featherlite 150 m? then I can look into the issue a bit more but I feel if those have been checked then it should be running efficiantly
on my leaf blowers for some odd reason I love to run a bit higher of octaine just to make it last a bit longer alot cleaner for it to be running.
check those and let me know where we are at with it.
Posted on Nov 18, 2008
I have an older craftsman snow blower 10 hp. It starts ok with full choke, runs ok half choke, backfires with no choke-run position.
It's too lean; not enough fuel mixed with the air. Look for the main mixture screw--it should be a large screw with a spring under it on the carburetor. Run the engine until it's warm.
With the engine running, turn the screw outward (lefty-loosey) about 1/8 turn slowly and see if it improves. Slowly turn the screw back and forth until it runs best with the choke completely off. Then set it 1/8 turn richer (turn screw outward 1/8 turn) than the best position.
Reason for doing this: Conditions change, even the barometric pressure. Small engines run okay if they are a little rich but not if they are a little lean.
Mar 03, 2015 | Garden
How do I start a weedeater fb25?
Press primer bulb 6 times
Move throttle lever to start position
Move choke lever to full choke position
Pull starter rope sharply until engine attempts to start, but no more than 5 pulls.
Move choke lever to half choke position. Pull starter rope sharply engine runs. If engine hasn't started after 5 pulls, repeat all steps above.
After warming up for 10 seconds, move choke lever to run position.
Manuallib.com has a manual for this model available for free download
Oct 20, 2014 | Weedeater Garden
Small gas engine dies when choke full open
I have attached a diagnostic sheet to help you determine what is wrong.
Jan 21, 2014 | Weedeater 2 Speed Gas Blower FL1500LE ()
Turn off choke, engine stops
You may need to adjust the carb.
Jan 03, 2013 | Garden
Engine surging 179cc craftsman snow thrower
sounds like the carb will need removing and having it ultrasonic cleaned
Dec 16, 2011 | Mtd Garden
Blower only runs with full choke. When I switch to half choke, it dies and won't start.
it may simply need the high speed jet opening up a bit (2 screws near eachother on the carb and the high speed is furthest from the engine)
failing that it needs a carb kit.... this is a serviceable item changed regularly.
Mar 14, 2011 | Poulan/Weed Eater No. Bvm200le 711482 24cc...
Craftsman blower stalls when choke is disengaged
You need to play with the timing adjustment, either on the spark plug, or the gap between the contact and the magneto.
That'll do it ;)
Don't forget to rate, thanks
Jul 31, 2009 | Craftsman 4 Cycle Blower/Vac
Gas leaf blower runs at half speed
First you will have to get a carburetor kit ,it consists of diaprams and inlet needle,you then remove the two srews that hold carburetor on the engine and remove gas lines,also the throttle cable remove screws that hold ends of carburetor on under these you will find the diaphrams and needle remove these be carefull not to loose the little spring under the needle lever.
!get you a can of carburetor cleaner and spray carburetor the blow it out with air you will notice little jets in carburetor that have to be clean use a wire from a bread tie to clean them out install new gaskets and diaprams in same position you took old ones off.you can also look at carburetor to see what kind it is walbor,zama,tilloson? type the name in google search and can get a diagram of carburetor if you loose your place,or just ask me.
May 15, 2009 | Homelite Consumer Products MightyLite...
Blower does not stay running
Make sure you have the propper mix of gasoline and oil. If the fuel is old mix new fuel to proper ratio. Find your manual and find the low speed fuel adjustment and the high speed fuel adjustment on the engine. First, turn the screws in and count the turns so you know where you started. Return the screws to the origional position. Usually 2 to 2-1/2 turns are a good starting point if you get them messed up. If the engine runs with the choke on you have to open the high speed jet a bit, 1/4 turn CCW. Keep trying this and get the feel of the change in the engine performance. If you have too much fuel the engine will not get to peak RPM. The low speed jet works similar but you have to adjust it so the engine idles at a decent RPM. This should get you on the path.
Mar 15, 2009 | Garden
Won't keep running except at 1/2 choke or a little above
ahter you start it up turn choke too off position
Feb 26, 2009 | Ryobi Backpack Blower 25.4cc
Poulan Featherlite Gas Blower, with Low Emission Engine, 150 M Logo
682 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
