Question about Maytag Neptune MAH5500B Front Load Washer
Maytag Neptune MAH5500BWQ Front-load Washer Stop Working
When press the start button, and many other buttons on the panel, it simply just sounds 3 beeps. Power circle the machine doesn't help. Anyone can share the solutions? Many thanks in advance!
  • russNjenn Apr 19, 2009
    It started but cme back and timer was counting down but nothing was working. hit cancel to unlock the door, and now all it does is beep when any of the buttons are hit. Also when I press the door switch and release it it dings but it wont give a "do" on the display
  • 5911 Answers
SOURCE: nf pops up on the screen & the washer stops
The "nf" code is a "no-fill" fault. This indicates that your washing is not getting water supplied to it, or the pressure isn't substantial enough to complete a fill. You need to, first, make sure the water supply is turned on. Second, if the water IS turned on, and you're still not getting anything to your washer, you may have a fill valve problem. The fill valve is what both your hoses connect to on the back of the machine. It can become clogged with sediment over time (especially, if you have hard water or well water). Turn the water supply off and remove both hoses from the back of the washer. Check both these hose connections for clogs in the filter screens. If they are clear, then more than likely the fill valve has gone bad. I hope this helps you.
Posted on May 13, 2007
  • 868 Answers
SOURCE: Beeping Neptune washer...
Replace control board
Posted on May 25, 2008
  • 639 Answers
SOURCE: maytag neptune mah5500bwq fault code
Dear friend,
ngfam at you service!
The Neptune was discontinued for 98 design defects!!!!!!!!
You can not fix this problem your self!!!
This sounds like it will only fixed by service then you will be happy again!!
Yes sounds like you need service!
Call A&E Factory Service /They service nation wide
And are available 24/7 for making appointments!
If the appliance is 10 years old or more,it may make sense not to invest any money to fix it!
Happy to assist you,
Posted on Aug 26, 2008
i have maytag neptune wash,modelo mah5500bww,my problem is: no starting,flashing start/pause button,after ten minutes is off.And now is ready for start when press start/pause button
Posted on Aug 29, 2008
  • 335 Answers
SOURCE: manual
I found a Service repair manual on this site search for this; FAV6800 Manual
Posted on Dec 15, 2008
3 beeps on any button press, machine will not start, and will not go into service mode
Try unplugging and plugging it back in, carefully. The control panel most likely has gone out. These panels are generally readily accessible, so it is not a big deal to replace a circuit board or component. Be sure to unpower the machine if someone is to try this that is not a licensed technician. If you have a warranty it may be time to call someone out.
Aug 31, 2017 | Maytag Neptune FAV6800AW Top Load Washer
The lights go on, but washer will not start.
door not closed try open door and then closing again
Feb 11, 2010 | Maytag Neptune MAH5500B Front Load Washer
Wash time too long
if the water supply is restricted, yes this would happen. remove supply hoses, check screens, check taps
Jul 23, 2009 | Maytag Neptune MAH5500B Front Load Washer
Maytag neptune washer: will not start
plug a light into the washer outlet to check for elec current at this point before anything else.
Aug 17, 2008 | Maytag Neptune MLE2000A Front Load Stacked...
Maytag Neptune rinse cycle doesn't start.
cold water valve screen plugged or bad valve, just check it!
Aug 06, 2008 | Maytag Neptune MAH6500A Front Load Washer
Maytag neptune
May 20, 2008 | Maytag Neptune Washer
Maytag Neptune MAH5500B Front Load Washer Logo
138 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
