Question about HP Pavilion dv6000z Notebook
Smart Web printing
I see from the volume of information on this thread that you have tried quite a number of solutions already. Although id like to clarify if you have tried a different computer. I have the same program installed on one of my computers and am not having a problem. XP SP2 IE 7 so im thinking it has to do with the OS that you have installed being that there may be some probelms on them. Although by experience i have found out malware causes problems on HP software as is what happened on an All in one printer i had a couple of months back as well as a Lexmark printer i took care of on location a couple of days ago. Id suggest you either try another computer and see if you get the same problem or try malware software such as is on the link below then run a full scan. You can use the free option by the way even if you have antivirus it does not filter some malware and after a full scan do Delete any malware found and also uninstall and reinstall the program.
LINK
After updating to IE9, my printer won't print in grayscale, only color, why?
are you trying to print grayscale copy of the broswer or webpage? or grayscale from word document?
if you are trying to print grayscale from webpage or email, check the version of you IE 9 if it is BETA version or the complete version.It might have something to do with it.
Try using mozilla firefox browser or google chrome as work around.
If there is a smartweb printing software
Disable the HP Smart Web Printing add-on loadTOCNode(2, 'workaround'); To have us disable the HP Smart Web Printing add-on for you, go to the "Fix it for me" section. If you would rather fix this problem yourself, go to the "Let me fix it myself" section.
To fix this yourself, follow these steps:
  1. Close all Internet Explorer windows.
  2. Open a new Internet Explorer window.
  3. When you see the message that states that the "HP Smart Web Printing add-on can cause Internet Explorer to crash or to stop responding," click Always open Internet Explorer without this add-on.
Your's Truly,
Christian from HP
Say "Thanks" by clicking the thumb icon in the post that helped you.
Please click "YES" in solution that solves your problem as "was this helpful?"
(Although I am employed by HP, I am speaking for myself and not for HP)
Apr 11, 2011 | HP Photosmart C5280 Printer
No printing off web pages
* What happens when you print from we page?
* Are you able to print emails?
* Which is the internet browser you are using?
* Are you using HP Smart Web printing software to print from web pages?
Please get back to me with the above information.
:) Dr Tony
Apr 14, 2010 | HP Photosmart 3210 Printer
On my model 8885 uniden phone, when I try to store a # the screen say's memory full. I only have two numbers stored. help
These phones use a "Shared" memory, the CID information and the Phone book information share the same memory chip. If you clean out the caller ID data you should be able to load more numbers in the phone book. Since you have an 8885 I am assuming you have TCX800 or TCX905 handset(s), to clear the CID memory, Follow these steps:
Deleting Information from the Caller ID List
1) When the phone is in standby mode, view the Caller ID
information to be deleted (see "Viewing the Caller ID
List" on page 50).
2) Press the DELETE soft key. De let e C all er ID appears.
3) Press volume up/down to choose Yes.
4) Press the OK soft key. You will hear a confirmation tone.
To delete all the CID information follow these steps:
Deleting all Caller ID names/numbers
1) When the phone is in standby mode, press cid.
Press the DELETE soft key. De let e A ll? appears.
2) Press volume up/down to choose Y es.
3) Press the OK soft key. You will hear a confirmation tone
Mar 27, 2009 | Uniden 5.8GHz Dual Cordless Phone
Hp6310 officejet all in one
here is solution..
Solution Step one: Make sure that the product prints correctly
  1. Print a self-test page from the product control panel, from Windows, or from the product software. (See the product user guide, available online, for instructions to print a self-test page.)
  2. Check to make sure that black and all colors (if using a color product) print on the self-test page.
    • If the self-test page does not print correctly, an issue might exist with the product hardware. See the product user guide, available online, for further troubleshooting steps.
    • If the self-test page prints correctly, continue with the next step.
Step two: Determine what portion of the page is set to print Many Web pages use frames. Frames divide the screen into multiple windows. Follow these steps to determine what portion of the page is set to print.
  1. Click the Internet Explorer icon on the desktop. The Internet Explorer window opens.
  2. On the File menu, click Print . The Print dialog box opens.
  3. Click the Options tab to view the print settings.
  4. Change the settings if required, and then click Print .
Step three: Change the Encoding setting in the Web browser
  2. On the Menu bar, click View .
  3. Click Encoding to view a list of encoding options.
  4. Check the Encoding settings.
    • If Auto Select has a check mark next to it, click to clear the check box.
    • If Western European Windows does not have a check mark next to it, select it.
Try printing again. If the issue continues, proceed to the next step. Step four: Check the page setup settings for the Web browser Web pages are designed to be viewed at a certain screen resolution. If the resolution of the screen is lower than the resolution of the Web page, the whole screen might not display or might not be printed.
  1. Make sure that Internet Explorer is open.
  2. On the File menu, click Page Setup . The Page Setup dialog box opens.
  3. Review the Margins information.
  4. Make sure that the margin settings are greater than or equal to the minimum printable region margins for the product. The margins vary slightly among HP All-in-One products. As a general rule, the settings should be at least the values shown in the following table. Side Margin Top Margin Bottom Margin 6.3 mm (0.25 inch) 6.3 mm (0.25 inch) 6.3 mm (0.25 inch)
  5. Make necessary changes to the margin settings.
  6. Click OK to save the changes.
Try printing again. If the issue continues, proceed to the next step. Step five: Print using Smart Web printing software HP Smart Web Printing is fast, free, downloadable software that enhances how Microsoft Internet Explorer and Mozilla Firefox print Web pages. Use HP Smart Web Printing for the following tasks:
  • Select text and graphics from any Web site
  • Save paper by combining portions of numerous Web pages
  • Preview and modify clips before printing
Thank you.......
Jan 29, 2009 | HP Officejet 6310 All-In-One InkJet...
HP 1315xi all in one printer scanner copier config problem
Remove the HP Smartweb printing software.
1. In the Start menu select All Programs > HP Smart Web Printing > Uninstall HP Smart Web Printing.
2. Follow the onscreen prompts.
You can also open the 'Control Panel' from the 'Start menu' and open 'Add or Remove' Programs. Select 'HP Smart Web Printing' in the 'Add or Remove' Programs window, and then click 'Remove'.
If the changes you make in the Page Setup dialog of Internet Explorer are not reflected in the Page Setup dialog of the Print Clips window and vice versa ?
This is a known problem, and not unique to HP Smart Web Printing. When printing from the Internet Explorer File menu, select File > Page Setup and make your settings there. When printing from the Print Clips window, click the Page Setup button and make your settings there.
Now install the smart web printing software from the weblink provided below:
After removing the smart web printing software, please visit the weblink and download the HP Smart Web Printing 4.05 software from the webpage.
http://h10025.www1.hp.com/ewfrf/wc/genericSoftwareDownloadIndex?softwareitem=dj-56929-5&cc=us&lc=en&dlc=en
Just copy and paste the entire link(without spaces) in the web browser and press enter.
For more information on how to install the software visit the below weblink which leads to a webpage.
http://h10025.www1.hp.com/ewfrf/wc/document?lc=en&dlc=en&cc=us&lang=en&docname=c00793678
After performing the steps mentioned above, check the functionality.
Dec 15, 2008 | HP PSC 1510 All-In-One InkJet Printer
HP Photosmart D7460 Error Message
Oct 27, 2008 | HP Photosmart D7460 Printer
My HP Photosmart C4280 works OK for copying & scanning but will not print from a web page intermittently. I've had it uninstalled & reinstalled twice by tech. support in Capetown taking several...
Not quite sure what you mean when you say, "will not print froma web page intermittently". Do you mean it sometimes doesn't print a web page at all or that the print out isn't what you want? Also, there is an additional issue if you are using Microsoft Windows Vista (as opposed to another Windows operating system).
Without more information, the following links to information on HP's web site for your printer is the best I can do:
Printing Web Pages in Vista
Only Parts of Web Pages Print
Unwanted Web Page Backgrounds Print
If one of these works, please post back which one was the correct solution. If not, please post more details about the problem. Thanks.
Oct 07, 2008 | HP Office Equipment & Supplies
CALLER ID NOT DISPLAYED.DISPLAYS EXTERNAL CALL
Caller ID in the USA uses the FSK standard. For the most part, callerID in India uses DTMF (although I have heard of some FSK usage).
I am currently living in New Delhi and have an Airtel home phone line.My switch uses DTMF. I went to the Palika electronics bazaar (I awaysuse shop number 266 near gate 5, they seem to be a little kinder toforeigners as far as the "final price") and purchased an DTMF to FSKconvertor. My US phones now show caller ID information, although usingUS number seperations ### - ### - ####. I paid R500 but you couldprobably get it for around R400 if you are willing to put in the timebargaining. It looks like they are also available on Indian Ebay.
Mine says UST001B. It looks like these are low volume items becausethey stuck the components into a box marked "DSL Splitter" It works toconvert the caller ID as advertised.
Jul 17, 2008 | Philips CD4451B/37 Phone
Caller id
Caller ID in the USA uses the FSK standard. For the most part, caller ID in India uses DTMF (although I have heard of some FSK usage).
I am currently living in New Delhi and have an Airtel home phone line. My switch uses DTMF. I went to the Palika electronics bazaar (I aways use shop number 266 near gate 5, they seem to be a little kinder to foreigners as far as the "final price") and purchased an DTMF to FSK convertor. My US phones now show caller ID information, although using US number seperations ### - ### - ####. I paid R500 but you could probably get it for around R400 if you are willing to put in the time bargaining. It looks like they are also available on Indian Ebay.
Mine says UST001B. It looks like these are low volume items because they stuck the components into a box marked "DSL Splitter" It works to convert the caller ID as advertised.
May 03, 2007 | Siemens Gigaset 4215 Cordless Phone
HP Pavilion dv6000z Notebook Logo
96 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
