Question about Electrical Supplies
Hard to start , have to manually choke, and when running on auto
When running on auto sounds like it isnt getting enough fuel
  • 169 Answers
You didn't say, so I'm assuming that this is an LP Vapor fueled Home Standby generator. The bottom line to these things is that if it sounds like a fuel problem it almost always is one.
1 - Check for leaky fuel supply plumbing.
2 - Check the fuel pressure at the input side of the demand regulator inside the generator, it needs to be something like 11 inches of water all the time. My Generac/Guardian training came with a nifty manometer just for this purpose. If you can't get a manometer your LP supplier should be able to come and make this measurement for you. If you aren't comfortable with adjusting the gas pressure you should call them anyway.
3 - Change the spark plugs. This isn't all that common a problem, but it's cheap compared to changing the demand regulator.
4 - Check/replace the demand regulator inside the generator. This part controls gas flow rate rather than gas pressure so if the diaphram in there gets sticky or leaky you can have fuel problems.
Posted on Nov 29, 2008
My pb413T want to run only on choke
Its a lean condition... Its not getting enough fuel. Check fuel filter and fuel lines, be sure to use fresh fuel then either adjust the carb or rebuild it.
Jul 12, 2014 | Echo Pb - 413t Backpack Blower
Car cranks but wont start jaguar s 2000
fuel starvation or your auto choke isnt engaging pump the gas pedel a few times when starting get some fuel through the jets, have you been running the car on low fuel this brings up the sludge from the bottom of the tank and blocks the jets try some jet cleaner in your tank when its running this will clean out your jets and give you better acceleration and fuel economy
May 04, 2014 | 2001 Jaguar S-Type
Supper LT1554 will only run with the choke on then it runs real rough
Sounds like a lean fuel condition. The carburetor is clogged and not getting enough fuel. By choking it you are manually changing the air/fuel ratio. You need the carburetor cleaned. If you are not confident, bring it to a reputable shop for repair.
Hope this helps.
I’m happy to assist further over the phone at https://www.6ya.com/expert/layne_0fccff498c319c32
Aug 10, 2013 | Garden
My 1990 Geo Prizm GSI will start, but it won't keep running when the weather is cold.
Sounds like the automatic choke control on the carburator is shot! It is stopping the proper flow of gas from getting to the engine...replace it! Also make sure you have recently replaced the fuel filter; moisture in the gas will stick to the filter and freeze up making it hard for gas to get through!
Jan 01, 2013 | 1990 Geo Prizm
Hi there i can start it up with full choke it starts it runs it clears its self i push the choke off it runs fine for about 40 seconds then its like it starts to run on 2 or 3 cilinders chokes up then dies...
check your carburatures. Sounds like they could use a tune up. Seems as if they are not getting enough fuel after it is warmed up, that is why it runs good when choked. Also check your air filter first.
Mar 29, 2011 | kawasaki ZX-9R Ninja Motorcycles
I have a Honda GX160. It starts up first pull, once its running if i start to take the choke off to put it in run possition it stalls. Checked fuel flow from the tank to the carb, took the bottom of the...
It sounds like your carb might have some tarnish built up in it and the jets inside the carburetor are not letting enough fuel through. This is really common among generators and lawnmowers because they sit for so long unused. So what happens is, with the choke "on" you are reducing the amount of air allowed into the fuel/air mixture. As you move the choke to the "off" position, you are allowing more air into the fuel/air mixture but not enough fuel is not being allowed in the mixture so it runs too lean and stalls out. Also, don't use tools to clean the carb jets, they are usually made out of brass and a tool can scar the inside of them and create resistance for the fuel flow. Hope this helps!
Nov 03, 2009 | Master Heaters MASTER HONDA POWERED...
'84 Ford Ranger cuts off after about 30 mins of driving.
sounds like the auto choke isnt turning itself off properly but to be totally honest i would need this to happen when i test drive it to diagnose it correctly .
Sep 01, 2009 | 1984 Ford Ranger
Bike won't stay running
Have the carburators cleaned. this is the first step to ensure there isnt any dirt in the carb.
2nd. Jets should be standar.
3rd. The Fuel/Air screw or knob should be properly set. This is usually 2.5 turns outward from full close. Check for the manual for the proper opening.
4th. Idle knob maybe set too low.
Mar 13, 2009 | 2005 kawasaki VN 800 Vulcan Classic
Runnung rough till warm then spot on plugs black
think what i would try first is a fuel additive to see if you possible might have gotten a little moisture or dirt in tank , I like sea-foam brand available @ advance auto or other auto stores but i would try this first and see results , black plugs could mean rich mix not enough air or moisture in fuel the latter is easiest to eliminate
Jan 31, 2009 | 1994 kawasaki ZZR 1100
Electrical Supplies Logo
210 people viewed this question
Top Electrical Supplies Experts
Craig Butler
Craig Butler
Steve
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
