Question about Brother ML-100 Typewriter
Brother ML100 typewriter
We've replaced the correction tape in the typewriter several times. This time it won't work. I've looked at the manual and we are doing it correctly. The tape is not reversed. Any suggestions as to what we are doing wrong? Thanks, Lori
  • 1 more comment
  • Anonymous Feb 20, 2008
    The correction tape and ribbon are lifting up together. What is wrong?
  • Anonymous Nov 21, 2008
    i can not correct anyhting on my typewritter!!
  • Anonymous Apr 03, 2009
    the letters are not matching what I type
Instead of turning the ribbon to the inside, install the ribbon turned outside.
Posted on Jan 05, 2007
    Problem Solver:
  • 20 Answers
Make sure that the correction tape is place in the guides one on each side small metal guides, remove ribbon to see, it should be behind ribbon guide (closes to you). Dry lift-off tape only(#3015)
Posted on Dec 17, 2006
My typewriter will not type the correct letters I have replaced the wheel twice any suggestions?
Make sure that ps pitch is not selected. check if ribbon or corr. tape is in printwheel
Sep 26, 2014 | Brother ML100 Daisy Wheel Electronic...
INSTALLING CORRECTION TAPE ON A BROTHER SX4000 TYPEWRITER
try to see it in the sides or it might be in the bottom of the machine in some models remove the older and replace the newer.
Aug 25, 2008 | Brother SX-4000 Typewriter
How can I get printer ribbons for this Brother ML 100 typewriter? Can you give me the code #?
The Brother ML100 uses the BRT 1030. There are several supplies available like the lift off tape, the daisy wheel and of course the printing cassette.
check it out:
Brother ML100 Typewriter Supplies
Good luck and if you need anything you can always call or email.
Duane ONeil
www.FJAproducts.com
800-982-9989
bc.cbi?cbdid=423141670777502444&wdid=1041068402873934082 8 to 5 (pst) Mon-Fri
Sep 15, 2009 | Brother ML-100 Typewriter
We are having problems installing the correction tape for the Brother ML100
PUT THE SUPPLY SIDE ON FIRST ON THE LEFT SIDE OF THE PRINTHEAD. ABOVE THE TAPE AND RIGHT IN FRONT OF THE CARDHOLDER THE IS A GUIDE, TAKE THE TAPE AND TURN ITTO THE RIGHT AND PUT IT IN THIS GUIDE. THE DULL SIDE OF THE TAPE SHOULD BE AWAY FROM YOU. THEN PUT IT BETWEEN THE TWO METAL "FINGERS" AND THE CARDHOLDER AND THEN IN THE GUIDE ON THE RIGHT SIDE, THEN PUT THE TAKE UP SPOOL ON THE POST AND TURN ITT THE DIRECTION OF THE ARROW ON THE SPOOL UNTIL IT IS TIGHT AND THE "LEADER" IS PAST THE PRINTHAMMER
Dec 17, 2008 | Brother ML-100 Typewriter
Typewriter is an ML100 Standard Brothers Typewriter
repost if you are still having this problem
Aug 28, 2008 | Brother ML-100 Typewriter
Brother ML100 Lift-Off Correction Tape won't lift off
Correction tapes DO have a shelf life, Also make sure the ribbon is moving and very important and this may sound dumb, but I have seen it that the ribbon is not a correction ribon. Are the spool turns orange or yellow? should be. Blue is multistrike and will not correct. Don't know the shelf life of ribbons but they do loose the ability to correct.....Good luck try new supplies..
Jun 30, 2008 | Brother ML-100 Typewriter
I have a brother SX4000 at work and I am having a hard time getting the correction tape on. Can you help with any instructions?
Jan 29, 2008 | Brother SX-4000 Typewriter
Brother ML100 Typewriter:All of the sudden, it just won't type. It seems the 'hammer' doesn't hit the daisywheel. We've replaced the daisywheel, corrective tape, ribbon and still it goes through the...
Ok,there could be two possibilities ,1, The daisy wheel may not be seated in properly. Of course I assume that the print side of the daisy wheel is facing the platen and that when the typewriter is switched on the print unit makes its customary re-setting motion and that the daisy wheel spins around at the same time. if this does not happen make sure that the lock-in lever for the daisy wheel is pushed home.. I am sure that you do all these elementary things so the only other possibility is the the hammer seleniod is not fully functioning and would have to be re-placed....Good luck!
Nov 14, 2007 | Office Equipment & Supplies
Brother ML-100 Typewriter Logo
1,194 people viewed this question
James Cagle
James Cagle
ctnozil
Victorman
Victorman
