Question about Whirlpool Duet GHW9150P Front Load Washer
F06 whirlpool duet error
Looking for repair directions for washer F06 problem - as mentioned on fixya.
Thanks!
doityourselfer - I hope!
  • 5,911 Answers
"F06" is a motor speed error. The following link explains:
http://www.fixya.com/support/r714929-f06_error_whirlpool_duet_kenmore_elite
The link provided will give you the necessary steps to diagnose the problem yourself (yes, this a DIY project). All you need is a simple multimeter. I would begin by checking all the wiring to ensure you have nothing loose or broken. Then, I would recommend checking the motor windings. This would potentially rule out the first two possibilities by confirming whether or not the motor and wiring harness are good. That would leave the Motor Control Unit to troubleshoot. More commonly, the MCU fails causing this error. I'm not saying this is your problem, however. You will need to follow the steps provided to rule out all possibilities.
I hope you find this information helpful. Let me know if you require additional assistance.
PS If you do require parts. You can order on line at searspartsdirect.com. Repairclininc.com also carries parts for your washer if you would like to do some comparative shopping. There are other web sources out there, but I have found that these two have good service and are usually the lowest priced.
Posted on Nov 18, 2008
Error Code 01 F06
Your fault is mentioned here.
An F06 fault code in a Whirlpool Duet washer (the Kenmore HE3/4t's are also made by Whirlpool) usually means a motor-related problem. It usually pops up when the drum won't rotate at all or only very sluggishly. Here's the excerpt from the Whirlpool Duet Service Manual on this:
http://fixitnow.com/wp/2008/10/28/whirlpool-duet-washer-with-an-f06-fault-code/
May 10, 2015 | Maytag Dryers
Whirlpool duet front load washer, F06 error
FROM WHAT I CAN FIND OUT YOU HAVE A DRIVE MOTOR PROBLEM,
IF YOU TYPE IN YOUR SEARCH BOX (WHIRLPOOL FAULT CODE F06) there are several several sites that tell you how to fix it
Nov 25, 2012 | Whirlpool Duet GHW9150P Front Load Washer
The washer runs for about 3 minutes and flashes 06 then F?
Hi
Thanks for using FixYa. Error F06 in your whirlpool duet indicates that the control is unable to properly detect the motor speed and so the washer shuts down. This usually occurs during high speed spin and the door will be unlocked after 3 minutes. To resolve this issue you’ll have to check the wire harness connections between the Driver motor and the Motor control unit (MCU). If that is fine then check the connection between the MCU & central control unit (CCU), replace the part that has gone bad. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Sep 07, 2010 | Whirlpool Duet GHW9150P Front Load Washer
F06 message
Hi
Thanks
Rylee
Aug 28, 2010 | Whirlpool Duet GHW9150P Front Load Washer
What does the F06 error code on the Kenmore Elite HE3 washer mean?
Hi
Thanks
Rylee
Aug 27, 2010 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
F06 and washer stops spinning , must keep restarting
Hi
Thanks
Rylee
Aug 27, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Machine stops mid cycle with F06 error
Hi
Thanks
Rylee
Aug 11, 2010 | Whirlpool Duet GHW9150P Front Load Washer
F06 error message with flashing remaining minutes
Here is what the manufacture says about F06 - my comments will follow these.
DRIVE MOTOR TACHOMETER ERROR
The control is unable to properly detect motor speed and
the machine will shut down. If a failure occurs during
high-speed spin, the door will be unlocked after three
minutes.
Possible Causes / Procedure
1. Verify the shipping system including shipping bolts,
spacers and cables are removed.
2. Unplug washer or disconnect power.
3. Check wire harness connections between the drive
motor and the Motor Control Unit (MCU), and between
the MCU and the Central Control Unit (CCU).
4. Plug in washer or reconnect power.
5. Check the MCU by looking for operations of the drive
motor.
6. Check the drive motor for powered rotations.
Phil's comments--->
If you just set the machine up be sure the shipping bolts have been removed, this is the most common reason for F06.
Other than that there is some type of communication error between the three main components (motor, Motor Control Unit and Central Control Unit) or the wire connectors between the three.
If you have had the unit a while and it is not related to the shipping bolts I would recommend calling Whirlpool
Apr 19, 2010 | Whirlpool Duet GHW9150P Front Load Washer
F06 error code on Whirlpool duet washer
I have the whirlpool Duet 9150 with the same issue. I removed, reseated and reconnected every connector at least 4 times with the same random result of F06 to the point where it no longer finished the load. I then removed the motor control board again and sprayed it down with electronic cleaner along with all connections by disconnecting them , spraying them down and then reconnect and connected a few times to ensure good contact. I then tried again and the F -06 code came back. I then ordered the board for $ 150 online . When the new board arrived 4 days later, my wife tried the washer one more time and it worked. I have performed over 2 dozen loads . The board was never replaced. It appeared that spraying the board and connectors worked.
Jun 27, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
144 people viewed this question
Dan Webster
Dan Webster
Sal De
