Question about Acer Computers & Internet
I've acer travelmate 4500 laptop. Till yesterday it was working fine, but today i donno what happend to it.. the screen display is completely dull. that I couldn't see the display and if I closely observe the screen display, there is a display which is not active ( in the sence its not actively bright)... please let me know the possbile reasons and the solutions.... thank you
  • 30 Answers
If you can see some kind of display when you shine a flashlight on it at an angle, either your CCFL lamp is bad or your inverter board is bad. Neither part should be too expensive not to get it fixed.
Posted on Dec 15, 2008
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 86 Answers
The possible reasons is that you have turned down your brightness and contrast without realizing it, to fix this simply look for a brightness key on your keyboard and turn it up. If it is missing or did not fully work, see if you can notice any image and try to get into your Display properties, click the setting tab and go into advanced and turn up your brightness and contrast from there. If this does not work, im afraid to say you have damaged your LCD screen and this would result in your dull screen appearance. Get a computer technician to take a good look at it to see what has happened if this is the case
Hope This Helps
Posted on Nov 18, 2008
My neices travelmate 2200 screen seems to be rather dull ,even with power unit plugged in and switched on
They are all like this. You can try disabling the dimming function in the bios but it won't help. The screen is simply dull.
Oct 14, 2009 | Acer Travelmate 2200 Notebook
Can't make webcam work on Acer Travelmate 4500
This sounds like a USB issue. Not all USB ports on laptops are created equal (they should be but they are not) some usb ports supply enough voltage and current to run usb items properly and some dont. It is always better to run direct from the computer / laptops ports .
If you cant do this then use a HUB but make sure the HUB HAS IT"S OWN POWER SUPPLY !
Also make sure you always use the same port and swapping them around does not always work for all hardware.
Aug 09, 2009 | Microsoft LifeCam NX-3000 Personal Web...
Blank Screen
HI there.
Try booting into safe mode by pressing F8 while the computer starts up.
If you can get it into safe mode perform a system restore.
If it won't boot into safe mode please post back.
Good luck and thanks for choosing FixYa!!
Jun 02, 2009 | Acer TravelMate 4230 Notebook
Acer travelmate 2410 broken screen
Hi
2 THINGS,one it could be the lcd cable has come loose behind the lid,
or the inverter is faulty.if your happy to take lid off an reseat the cable.
two.the screen cable maybe loose at the motherboard end.unplug power supply,remove battery,and unscrew keyboard,pull off cable an reseat the lcd cable.
i hope this may help
May 19, 2009 | Acer TravelMate 2300 Notebook
Acer dismantle
Acer TravelMate 2300/4000/4500 Series Service Guide
Download it, extract it, run it, scroll to page 57-74 for disassembly.
Jul 15, 2008 | Acer TravelMate 2300 Notebook
Laptop's LCD Panel showing a vertical burn-in patch (Picture Attached)
Try updating your display driver.
Generally the computer should be updated as far as the drivers is concerned.
Check on line at the website of this laptop for updated drivers.
Check these before you do anything else.
Jan 31, 2008 | Acer TravelMate 2300 Notebook
Acer travelmate 4500 screen problem
if u have two memmory stick.try to boot with one..if it not ok try it with other one...
Nov 30, 2007 | Acer TravelMate 2300 Notebook
Problem can you cure plz :((
Not enough RAM memory. Increase the size of the Virtual[scratch] disc Reduce the number of different A/V- Spy ware programs These will conflict just use a single A/V and Firewall and leave it at that.
Jun 22, 2007 | Acer TravelMate 270XV Notebook
Computers & Internet Logo
100 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
