Question about HP OfficeJet 6110 All-In-One InkJet Printer
I can only send faxes and not receive them
There are a few problems:
1) I can only send faxes and not receiv them
2) Do I plug the cord straight into the phone line or do I have to use the ADSL microfilter?
3) Can you receive phone calls and faxes as long as they are not at the same time without unplugging any cords? (The phone and fax number are the same)
    Novelist:
    Scholar:
  • 111 Answers
As far as point 1, you might want to check out this web page at HP.com:
Faxes can be received but not sent
Point 2. I have two "out" phone ports on my ADSL modem. I use one to plug it the 6110 into the modem. I do have an ADSL filter one one of my phone jacks. but I believe the modem contains one as well for phone devices directly connected to it.
Point 3. Yes. Obviously, if you are on a phone call, you won't be able to receive a fax, but if no phone call is in progress, a fax can come in just fine. Having a fax machine is just like having more than one phone in the house.
Hope this helps. Post your results back here. Good luck.
Posted on Nov 18, 2008
The ride side of my faxes and copies are black, any ideas?
Sometimes you may see vertical streaks/black lines on the faxes you receive. Either your machine's
primary corona wire for printing may be dirty, or the sending party's fax scanner may be dirty. Clean
your primary corona wire. I recommend placing the drum unit on a drop cloth or large disposable paper
to avoid spilling and scattering toner.
1. Clean the primary corona wire inside the drum unit by gently sliding the tab from right to left several times.
2. Return the tab and snap it into the Home position, (Caution: If the tab is not at the Home position, printed pages may have vertical stripes).
3. Reinstall the drum unit into the machine.
4. Close the front cover.
5. Plug in the power cord first, and then plug in the telephone cord.
or ask the sender to make a copy to see if the problem is with the sending machine.
Try receiving from another fax machine.
If the problem continues, call Brother Customer
Service at: 1-800-284-4329 (in USA) or 1-877-BROTHER (in Canada).
Dec 31, 2010 | Brother IntelliFax-4100e Fax
TELEPHONE HOOK-UP REQUIREMENTS
Just a plain telephone cord, plug it in. Go into setup and setup your fax name and number that will appear on the fax your sending. Set the number of rings before answering. Place a test fax call to some fax machine.
  1. Send a one page black and white text fax to 1-888-hpfaxme (1-888-473-2963).
  2. When your fax is received by the HP Test Fax Service, we will generate a return fax to you within five minutes confirming that we received your fax. This verifies that you can both send and receive a fax with your fax machine.
If you do not receive a return fax within 5-7 minutes, there may be a problem with the setup of your fax machine. Consult the user manual that came with the product for proper setup and configuration.
May 10, 2010 | HP OfficeJet 6110 All-In-One InkJet...
Can't send or receive faxes ADSL
If you want to use the FAX - use the dedicated line to the FAX Machine..
Hi check the following steps
Problems with sending and receiving FAX
Check the TELEPHONE LINE
Make sure that you have plugged the phone cord directly and securely into the wall jack and into the back port of the fax product. The fax port on your product is marked "Line," "To Wall Jack," or with a wall jack symbol.
Check LIU
Make sure the Line Interface Unit (box that the phone cord plugs into) is fully seated into the back of the fax product.
Remove the SPLITTER
Remove any other devices from the line such as splitters, credit card machines, or telephone answering machines.
Can try sending the Fax on Another Line
CHECK WITH DIFFERENT CABLE
Try using a different telephone cord.
Jan 22, 2010 | Samsung CLX-3175FN Color Laser All-in-One...
I cannot fax with my Lexmark 2500 after installing Windows 7
If Cannot send or receive Fax :
1) Check the control panel for any blinking lights. If the lights are blinking then
The color print cartridge needs to be replaced soon.
2) Check power.
a) Disconnect the power cord from the wall outlet, thenfrom the printer.
b) plug the cord all the way into the power supply on the printer.
c) Plug the cord into an eletrical outlet that other electrical devices have been using.
3) Check Cable connections Make sure cable connections for the following hardware are secure, if applicable
* Power supply
*Telephone
*Handset
*Answering machine
4) Verify dial tone.
* Place a test call to the telephone number to which you want to send a fax to make sure that it is working correctly.
*IF the telephne line is being used by another device, wait until the other device is finished before sending the fax.
5) Check for paper jams. Check for and clear any paper jams.
6) Disable Call Waiting Temporily. Call waiting can disrupt fax transmissions. Disable this feature before sending or receiving a fax. Call your telephone company to obtain the keypad sequence for temporarily disabling the call waiting.
Can send but not receive faxes
1) Load paper. Load paper to print any faxes that have been stored in the computer.
2) Check ink. Check the ink levels, and install a new cartrige of necessary.
Can receive nut not send faxes
Check document placement. Load the original document facedown in the lower right corner of the scanner glass.
Hope this help. Please Rate My Response!
Nov 23, 2009 | Lexmark Wheelwriter 2500 Typewriter
Cannot send or receive faxes
Use the HP Fax Test
The telephone number for this service is 1-888-HPFaxme (1-888-473-2963). The fax service receives faxes and returns faxes within 5 to 7 minutes to the number contained in the fax header. Solution two: Run a fax diagnostic test
  1. Load plain white paper into the input tray.
  2. Press the Setup button (c01669474.gif ) on the product control panel.
  3. Press the right arrow (c01669475.gif ) to select Tools , and then press OK .
  4. On the Tools menu, press the right arrow (c01669475.gif ) to select Run Fax Test , and then press OK . The fax diagnostic test prints.
Solution three: Check the telephone line and change the HP fax settings Step one: Test the telephone line
  1. Disconnect the telephone cord from the back of the HP fax product.
  2. Figure 1: Two-wire telephone cord c01501963.gif
  3. Pick up the handset of the telephone and check for a dial tone.
  4. On the single-line telephone, dial the fax number of the receiving fax machine.
    • If the receiving fax machine answers the call, continue with the next step.
  5. Hang up the single-line telephone.
  6. Use a second telephone line or a cellular telephone to call the telephone number assigned to the HP fax product.
Step two: Change the HP fax settings
  1. Connect phone line into line 1
  3. Press the right arrow (c01669475.gif ) to select Basic Fax Setup or Advanced Fax Setup , and then press the right arrow (c01669475.gif ) again to change the menu option settings to the settings listed in the following table. Fax menu Fax menu option Setting Basic Fax Setup Rings to Answer 1 or 2 (At least one more ring than a telephone answering machine, if an answering machine is connected.) Advanced Fax Setup Answer Ring Pattern All Rings
  4. Use the HP Fax Test Service to try to send and receive a fax.
If the HP fax product still cannot send or receive a fax, continue to the next solution. Solution four: Check VoIP digital telephone line Using a VoIP telephone service can cause faxing to fail because fax transmissions are sensitive to the timing of the signals used to transmit the fax. If using a VoIP digital line is necessary, changing the Fax Speed Adjustment setting to Medium might improve the ability to send a fax over a VoIP telephone line. Use these steps to change the fax speed adjustment to a lower speed.
  1. Press the Setup button (c01669474.gif ) on the product control panel.
  2. Press the right arrow (c01669475.gif ) to select Advanced Fax Setup , and then press OK .
  3. Press the right arrow (c01669475.gif ) to select Fax Speed , and then press OK .
  4. Press the right arrow (c01669475.gif ) to select Medium , and then press OK .
  5. Use the HP Fax Test Service to try to send and receive a fax.
Jun 23, 2009 | HP Officejet 5610 All-In-One InkJet...
2 fax machines on 1 line
Once you place your both fax machine on same line you will keep getting this issue. Fax machine is waiting for a fax ring signal that your other machine is sending. Shut down one machine when faxing or connect your alt fax machine to a different number this way you can send faxes when need to.
Jun 09, 2009 | RCA 25201RE1 Corded Phone
Error codes 283 and 232 in received Faxes
basically error 232 indicates that a communication failure has occurred between the two machines
Following these steps may help resolving your issue
1. Make sure that the phone cord is plugged directly from the wall jack into the back port of the fax machine that is marked "Line" or "To Wall Jack", or that has a wall-jack symbol.
2. Verify that the line interface unit (LIU) (the box that the phone cord plugs into) is seated fully into the back of the fax.
3. Remove any other device from the line such as splitters, credit card machines, or telephone answering machines, and retry the fax communication.
4. Try sending and receiving faxes on a different fax line.
5.Try using a different telephone cord.
6. Have the phone company test your line for static or noise problems.
7. Disable Error Correction Mode (ECM) if the same error occurs repeatedly.
Hope this helps.
thx
Jun 02, 2009 | HP LaserJet M1522nf Multifunction Printer...
I'm unable to receive or send faxes
Are you sure the line is good? You can try a plugging a telephone into the line to check it.
If you press the "hook button" (or whatever it is called on that machine) do you hear a dial tone?
is the phone cord plugged in snugly and in the proper jack on the machine? Is the cord good?
These are a few things to try.
If all of that checks out, then the phone board on the machine is shot.
May 26, 2009 | Panasonic PANAFAX UF-6000 Fax
Brother MFC-7840W fax will not work
Plug a regular phone into the wall jack and listen for a dial tone.
Phone cord should be connected to the LINE port of the fax.
Do you have DSL?
Unplug power cord for 10 seconds.
Oct 17, 2008 | Office Equipment & Supplies
Canon MP830
When i am trying to fax a document it is saying that the memory is full. But when i go to the menu and to fax memory it is saying empty. How to solve this problem
Dec 19, 2006 | Canon PIXMA MP830 All-In-One InkJet...
HP OfficeJet 6110 All-In-One InkJet Printer Logo
49 people viewed this question
Ben Johnson
