How To reset to Factory deffault NBX V3000 from Console Cable
What is the command to reset to FACTORY DEFFAULT nbx V3000 from the console terminal ? I cant acces to Netset and cannot ping to the NBX IP Add. But I can connect to thw console terminal and get NBXV3000---> prompt
Not only can I no longer access Net Set, but autodiscovery no longer works, and 2 of our extensions have disappeared thus far.Not only can I no longer access Net Set, but autodiscovery no longer works, and 2 of our extensions have disappeared thus far.
You can't post conmments that contain an email address.
After you power it up LEAVE IT ALONE for at least 45 minutes. When the NBX loses power abruptly it will do a disk scan upon reboot. The disk scan takes anywhere from 15 minutes to 45 minutes (depnding on the size of the database). You can connect to the console and see it doing a disk scan when you boot it back up. It will go through 6 phases and then boot up normally. Each time you pull the plug you risk database corruption (or hard drive failure on an older system).
If the extension is already in use on the system you wont be able to assign it to another phone. You can change the conflicting Ext. to something else (not in use) and then use the one you wanted. There are also specific ext. ranges that you have to abide by.
This was a rather simple fix. When I was speaking about the NBX V3000, I was talking about our 2U NBX Chassis which holds the line card. When our phone system was installed I wasn't shown the 1U NBX V3000 "Brain". I thought everything was contained in the chassis. Long story, short, I restarted the 1U "Brain" and the system came back up with 5 minutes.
You must make sure to use the correct username. The only username that can be used for administrator is administrator (ALL LOWER CASE). It is case sensative and can not be capitalized. You typically have to open a case with 3Com to get the current password. There is no "backdoor" way to gain access or change the password but if you have console access to the system you can enter the nbxDb command and get an encrypted password. If the system is running a software version 4.0 and older then the password is unencrypted and you are done. I can get the encrypted password decrypted if needed.
Are you trying to forward calls in circular from 1 extension to the next. Like 101 to 102 back to 101. If not I would purge the database and start over. Export user data so you can see the Mac address of each phone and it will be easy to reconfigure the extensions. Do not import the Data. Start from scratch.
