Question about Yamaha DVC6760 Multi-disc DVD Player
DVD Player / Stereo Audio problem
I have a Yamaha DVC 6760 home theater system. We run our DVD through the stereo for sound but the other day out of the blue the audio comes and goes. I thought maybe the DVD eye would be dirty but the DVD runs fine. The audio is the only thing going in and out. I am running a Monster 200 Ulta High Fiber Optic Wire from the Digital optical output to the Stereo. Could this cable be bad? What else could be the problem?
shaggyrat
  • 1224 Answers
SOURCE: dvr-s150 to dvd player
video cable has to goto the tv
audio can go to the receiver i have mine set the same way
Posted on May 27, 2008
SOURCE: I have a Yamaha Rx-v363
this sounds strange, but is true. you need to run your digital audio optical cable from your tv to your receiver (after, of course, connecting tv/receiver via hdmi). so, hdmi from blue ray to rec - hdmi from rec to tv - then optical from tv back to rec. it's round about, but that is how yamaha says (and the only way it works) to do it.
Posted on Jan 04, 2009
gymhasafit
  • 31 Answers
SOURCE: 8' Optical Cable from TV to Receiver and Signal is Breaking Up
Before you buy anything try checking the AUDIO Settings in the Menu of Each Device (Mostly TV) and see if they are set to PCM or BITSTREAM. HDMI is mostly set to PCM while Optical is generally Bitstream. The TV may be set to the opposite of what it needs to be. I would try to get PCM to work first cause it is Better, If not then set what you can to Bitstream and it should pass. Also check in TV Menu for SOUND OUT or AUDIO OUT or SPEAKERS. Some TV's have a problem passing Audio through when they are already Outputting them to it's own Speakers! I Hope this Helps out!
Posted on May 05, 2009
  • 7 Answers
SOURCE: Compatibility issue: Sony BDPS350 Blue-ray & Yamaha RX-V1700?
HDMI compatibility issues continue to plague the industry and this more than likely is the problem. There are a couple of ways around this.Some people insist on "hot rodding" the dvd and tv by hooking up directly to each other avoiding the receiver all togeether (I do this).But you lose functionality and it makes things more complicated for other family members. Your best bet is to use RGB and Digital audio cables.You won't notice any quality loss and there is a possibility it will look better.
Posted on Jul 07, 2009
mlapres
  • 757 Answers
SOURCE: i just bought a yamaha rx-v365 receiver and hooked
Make sure that the DVD player is connected into the correct inputs on the receiver and that the receiver also has the correct input selected to play. If your TV also has component video inputs it is best to connect the player directly to the TV. Otherwise, make sure you have the TV connected to the receiver via component video out.
Posted on Nov 25, 2009
Hook up new blueray thru old home theater system
Yes you can. If you have more than 1 HDMI sources and your old system only has 1 HDMI in, you may want to invest in an HDMI switch. They are inexpensive (under $20 on Amazon) and let you choose 4 HDMI sources to feed your system. The audio is embedded in HDMI and you may have to select the choices (surround versus stereo) when you play the disc.
Dec 25, 2012 | Sony DAV-DZ175 DVD Home Theater System
I have an AKAI SS-3800 home theatre system which connects to my DVD player by 6 cables to get 5.1 surround sound. Can it be connected to a bluray player to get 5.1 surround sound
Most DVD (and Blu-Ray) players have digital 5.1 audio outputs and some (like yours) also have analog outputs for electronics that lack a digital audio input (*).
I can't get a description (or picture) of the inputs beyond its having two, one 5.1 and one stereo. No mention of digital. Even at the lame akai site.
http://www.akai.com/product_detail.asp?id=3&id2=20&id3=58
* Like the Akai SS-3800 ??
So if the BD has 5.1 analog outs, yes, it will connect the same way as the DVD. Otherwise, you're limited to stereo analog audio (yuk).
Jun 26, 2011 | Audio Players & Recorders
I wanted to know if there is a way to hook up the sound from a Panasonic DMP-BD655P-K Blu-Ray player to my existing Yamaha DVX C310SW home theater system. I know I can hook the Blu Ray directly to the TV...
Yes this can be done. You have several options for audio hookup. Stereo 2-channel (white and red) RCA cables, digital audio (optical or coaxial) or HDMI. Your home theater must have the inputs available such as optical, coaxial etc. Typically the stereo 2-channel RCA is the simple way. Just connect from the Bluray audio outputs to the Home theater inputs (white and red) for stereo sound. Select the input on the home theater. For Dolby Digital 5.1 use optical digital audio cable (black port) or coaxial (orange RCA port) from Bluray to similar home theater input.
Mar 06, 2011 | Yamaha Audio Players & Recorders
Sound only from left front and right front speakers possibly my projection screen tv is only 2.1 channel does this mean i cannot have surround
surround receivers are supposed to be able to turn a stereo signal into a surround signal.  if the surround unit is producing just a stereo sound, then the tv is most likely outputting in mono, and not stereo; or there is no surround sound to decode..
Dec 27, 2009 | Coby DVD-937 5.1 Channel DVD...
How do we listen to aCD in 5 channel suround sound without having the TV on we can only get straight sound. We have a Yamaha RX-V365 av receiver.
Do you listen to audio CDs via a CD player or DVD player? Pure audio CD is only 2-channel, so either TV or the DVD player is doing the mix to 5 channels. But you can choose the sound mode via remote - there should be modes like 5ch/7ch stereo, where the same signal is going to all speakers (I you this mode for listening to radio sometimes).
Oct 27, 2009 | Yamaha Rx-v365 A/V Home Theater Receiver
Installed new 1080 plasma tv can't get sound from home theater system
A home theater system usually consists of a dolby digital stereo amplifier and 5 to 7 speakers.
Turn your stereo on and select the source that delivers video to the TV (DVD, VHS, Game, etc.). The video may be connected directly from the device to the TV, but the audio should connect to the stereo system (DVD, VHS, or other input). This way, the source audio is sent to the stereo and it provides the big sound to match the picture. Otherwise, you'd have to connect the source audio to the TV and let it's comparably tiny amplifier and speakers provide sound - that comes up short.
When playing a DVD, select the DVD input on the TV *and* the DVD input on the stereo. If you do not connect the audio to the DVD input on the stereo system, you'll have to connect to the TV, otherwise nothing will be heard.
Sep 17, 2009 | Audio Players & Recorders
Need owner manual for 8-watt Durabrand Home Theater System or directions on how to hook it up to flat-screen tv with built-in dvd player or digital dvr cable box
I would appreciate if you could let me know the manufacturer name of Duraband Home Theater system.. I'll paste the link to download user manual.
Awaiting response.
Thanks !
Sep 08, 2009 | Durabrand 5.1 Surround Sound Computer...
LPCM
well were is tv sound comming from charter dish or ect ?
or uusing teh dvd player try menu in sound change it from pcm audio to biitstream if u can
Jan 19, 2008 | Samsung HT-TQ85 Five DVD 5.1 Channel Home...
Center Channel Audio
There are probably several sound settings on the receiver :
Dolby surround , stereo, theater, SACD etc.
Try another setting other than the one you have
Dec 16, 2007 | Yamaha RX-V661 Receiver
Yamaha DVC6760 Multi-disc DVD Player Logo
Top Yamaha Televison & Video Experts
Larry Stiles
Larry Stiles
 Grubhead
Grubhead
Are you a Yamaha Televison and Video Expert? Answer questions, earn points and help others
