Question about Kenmore 53642 / 53644 Side by Side Refrigerator
My kenmore refrigerator gets very hot in the face of devider
Between 2 doors please help me what is the problem
    President:
  • Kenmore Master
  • 2,651 Answers
Its overheating, youll need to remove the front toe kick, vacuum the coils, andtrhen pull unit from the wall and vacuum behind the unit as well, while back ther make sure the fan next to the compressor is running
Posted on Nov 18, 2008
  • 2 more comments
  • hchristmas Nov 15, 2010
    The fan is running, but it is not cooling the center front panel. Ideas?
  • Ron Coons
    Ron Coons Nov 15, 2010
    if the fan down below the unit by compressor is running t, there must be excessive lint/ dust build up under unit preventing proper air flow acros the coil. the unit is trying to release the heat generated by normal operation, and that is the next logical area to do so..
    I vacuumed it out and blew the excess dust out already and it is still overheating.
  • Sherry Savoie
    Sherry Savoie Mar 30, 2014
    I'm having the same problem. I've vacuumed and blew out too and its still overheating and very hot to touch on the divider and around the edge of the top freezer. Did you find an answer?
My Kenmore side by side is hot around the door frame. How can I reset or rebot it, if possible. Model #10657943700
Getting warm around the door is OK but getting hot around door indicates a restriction of the airflow below your refrigerator. The compressor produces hot Freon that is pumped out the discharge side of compressor. On many refrigerators the gas goes to the yoder Condenser Loop first and then cooled by the condenser fan motor before going to the freezer section as a liquid.
Anything restricting that airflow will cause the yoder loop to get hotter. Example a defective condenser fan, dusty conditions below refrigerator or room temperatures way above normal for a kitchen or room inside your home. Insure fan stays on when compressor runs because a defective condenser fan does not always stop when defective. Most refrigerators work best with room temperatures in mid 70's to middle 80's. In this case rebooting may not change much but unplugging for 10 minutes and then replugging the power is the same as rebooting. Making sure that airflow is good, fan's stay on with compressor and room temperatures stay in the normal range. If helpful please rate this solution, Thanks Sea Breeze
Jun 14, 2011 | Kenmore Refrigerators
I have a kenmore elite side by side refrigerator and it is getting hot between the doors
Here is a tip that I wrote about the reasons why the sides and/or seals couldbe getting hot on your refrigerator.
RefrigeratorTrouble The Outside of Refrigerator Hot
heatman101
Jun 01, 2011 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Freezer still working. Refrigerator not cooling. Hot to top on inside of left hand door as you face refrigerator
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Mar 31, 2011 | Kenmore Elite Trio 7855 (25 cu. ft.)...
Kenmore elite refrigerator, very hot between doors
Mine was doing the same thing. I pulled the cardboard cover off the back near the bottom and found the fan was not turning and lots of dust buildup. I unplugged it and vacuumed it out and spun the fan by hand and plugged it back in. The fan started and the temp between doors went down. I may have to replace the fan soon.
Aug 22, 2009 | Kenmore Refrigerators
Freezer and refrigerator are not cold enough.
you problem check and see if your fan condeser working best call service
Mar 22, 2009 | Kenmore 53092 / 53094 Side by Side...
Compartment Divider on side by side refrigerator gets very hot
Clean the condenser coil underneath the dust bunnies keep the coil from cooling. What you feel is your elictir running away
Mar 14, 2009 | Kenmore Refrigerators
Panel between fridge and freezer extremely hot
this is happening because company used pipes inside refrigerator body, as you mentioned now its heating more than normal,. need some technician to check if there any blockage etc. otherwise less heating of body is normal.
Nov 30, 2017 | Kenmore 44103 Side by Side Refrigerator
Warm to Hot molding that seals the doors
The heat in door frame is normal but undetectable when ref at normal temp. Definitely cooling problem. Google ref not cold enough to get help to solve problem. Never use any oil for it will not help also health problem if not approved to be used around food. Fan motor must be replaced for it will just keep stopping.
Mar 31, 2017 | Kenmore 52642 / 52644 / 52649 Side by Side...
Outside middle devider hot
It should be warm but not hot. If it is too hot then either the condensor coils underneath are too dirty or the condensor fan motor has failed.
Nov 12, 2007 | KitchenAid KSRS25IL Side by Side...
Kenmore 53642 / 53644 Side by Side Refrigerator Logo
249 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
oldblindman
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
