Question about E-Machines eMachines Desktop PC
Emachine speakers are on but give no sound
The speakers come on when turned on (you can actually hear them go on and off) but they give no sound with a cd or movie
  • 1 more comment
  • Redoscars200 Nov 26, 2008
    I have the speakers on full volume and so little sound, I'm thinking of taking them out back and shooting them
  • quiltiowa Nov 27, 2008
    my speaker are on but are very quiet . i have tried to turn them up and everything is on max.
    it says
    realtek HD audio rear output
    or
    mic in
    can you help
  • Anonymous Feb 02, 2009
    no sound
    Champion:
  • 253 Answers
NEED AUDIO DEVICE DRIVER OR AC97 CODECS
Posted on Nov 18, 2008
My emachine et1831-07 wont start up. it turns on but the monitor wont start and keyboard dont work. sounds like it turns on but it dont do nothing..
Your computer is not passing the Power On Self Test or POST. Turn up the sound on the speakers, if you hear the sound of Windows loading then the fault lies with the graphics adaptor/card.
If you don't hear the Windows loading sounds then the computer is experiencing a more serious fault.
See my published guide entitled My Computer is not turning on!!! Is it dead!!! No POST!!!
It goes through the standard procedure to find and repair the fault. Try and do it yourself if you can, the other option would be to contact a computer technician. Claim warranty support if you can. Usually a component has failed and would therefore need to be replaced, however it is possible that the fault is due to a loose connection some-where in the system. Go through the connections in the chassis and ensure that they are all in, give them a slight push.
Take care!
damnor01
Jun 10, 2011 | eMachines ET183107 Desktop PC Intel...
There speakers r not putting out any music via the internet or my documents...but gives warning sounds
Check the volume control properties t oensure the speakers aren't muted, if they are not muted then the mainboard's volume control overide program has them turned down! To turn them up from there sumply locate your function key and they key that corrosponds with the volume up or volume down features. (usually the up or down arrows, but not always) they will be marked with a speaker icons and some variation of up or down markings.
As far as the warning sounds, that in its self is a seperate speaker unit that is not controlled the same way your actual speakers are, hence you can still hear the audio warning sounds. Good luck, thanks for using FixYa
Jan 10, 2010 | Acer Aspire 5500 5570-2609 Laptop
No sound except with headphoneson emachines home computer
Are your speakers plugged in and/or turned on? Plug them into the same port that your headphones go into and give that a whirl.
Dec 16, 2009 | eMachines T3604 PC Desktop
XP with no sound
Ok go here http://www.emachine-upgraders.info/d...ownloads.shtml
install the Intel INF Patch 4, then RESTART your comp, you have the Realtek driver install again
DON'T FORGET THE SYSTEM RESTORE POINT BEFORE INSTALLING EACH DRIVER
P.S.: If this information was helpful, please rate this solution.
Mar 13, 2009 | Microsoft Windows XP Home Edition for PC
No sound on computer
Yuour signal cable wire is damaged or not properly connected to the sound port or the port may have been damaged try connecting it to another sound source like headphone or output of radio you will find out
Feb 03, 2009 | E-Machines eMachines Desktop PC
I can't hear sound on my computer...
You didn't give us much detail (model, keyboard type) but it could be as simple as having the audio muted, either from the keyboard or the sound controller.
Look for a small speaker icon on the right of your task bar (bottom of screen) to see if it is 'Xed' out.
If you have external speakers with a separate power supply, the supply may have failed (check to see if still warm) or the speaker supplied has expired; the amplifier for both is in the speaker attached to the plug-in power supply.
May 05, 2008 | E-Machines eMachines Desktop PC
All the Songs on Media Player & Music I Download into the Media Player Get Distorted you Can Hear the Backround music & Some of the Chorus Fine but the Lyrics of the song are distorted if you can hear it...
It sounds like you have a problem with what is called "phase cancellation," which is something complicated that happens with audio when the left and right channels get out of sync and cancel out all of the common sound between the two channels. This can happen with bad speakers, a faulty output jack, or just failing to plug in the speakers all the way - it's also used (trivia!) constructively in the studio to create interesting effects on sounds.
http://en.wikipedia.org/wiki/Phase_cancellation
I don't think that you are actually experiencing a problem with WMP, but with your speakers or possibly your sound card. Here's what to do:
First, while music is playing, check and make sure that the speakers are well connected. Double check where they plug into your computer and ensure that the jack is inserted all the way. If they appear fine, flex the speaker cable a bit near the adapter...if you hear the sound change in any way (not including clicks or pops, really), the problem is most likely a short in your cable. Replacing the cable or speakers if necessary will solve this. If this doesn't help either, turn the speakers off and unplug them.
If you have an iPod or Discman lying around, plug it into the speakers and turn it back on. With music playing does it sound better? If yes, probably your sound card is damaged. These can be replaced very inexpensively. If it still sounds just as bad, your speakers are probably broken. You can try a new cable if it is A) removable and B) you have a replacement or don't mind buying one. Otherwise the speakers will have to be replaced.
Mar 13, 2008 | E-Machines eMachines Desktop PC
Motherboard sound and old speakers
what really matters is the quality of the usb speakers. check specifications such as wattage first and find reviews if possible. however usb speakers will probably not come close to separate speakers. i'd recommend buying a cheap sound card ($20 or so). these work great overall. $20 spent on a sound card will be a better trade off than $20 spent on speakers. just use your old speakers with the new sound card and you'll have plenty of power. after this i'd recommend headphones as they work great in this case. finally moving the sound card would probably work fine, but i have doubts.
hopefully that helped
Dec 30, 2007 | Dell - 0089D Sound Card
Sometimes make noise
if u play ur speakers with high sounds the speakers gonna give a hit sound and the beep sound what u get actually with the computer what u can do is just play ur speakers in some other system see if the same things happen with ur speakers then ur speakers are not proper if it is playing right with some other computer then there is a problem in ur computer in ur computer go to ur sound drivers software and just turn all settings to default and play if the same problem persissts then reinstall ur audio driver and play then it should play perfectly
Nov 21, 2007 | Logitech X-530 Computer Speakers
E-Machines eMachines Desktop PC Logo
906 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
