When plugged in the green power light flashes (in sets of 3 flashes) 5 or 6 times and the tv powers up, immediately followed by the tv powering down and the light flashing red continuously. I do hear everything inside power up and it sounds like a fan (probably the color wheel?) starts up before the tv shuts back down...How do I fix this?
SOURCE: TV is not powering up and red light keeps flashing
Cyndy, Yes this problem you have is most likly caused by the STR##### regulator IC in the power supply. You probably also have a capacitor or two that may need replacement and the best way to find those would be with an ESR type capacitor checker.. This is not a type of repair that a consumer with no TV experience should fool with. Please seek out a pro to assist you with this repair. Good Luck
SOURCE: Flashing green light
sounds like the bulb is blown. Its the main lamp in the side of the set. you will see a small door there once you take it off there is 2 screws to remove and bulb in its casing will slip out. by looking at the buld you should be able to see if its blown. You should get approx 3000 to 4000 hours from a bulb but if you are a heavy user of this tv with higher contrast the bulbs dont last. i have this model tv myself and ive been told that they are not designed to be run for long periods of time and dont use gaming machines on them. Shame they dont tell us this when we are buying them.. hope this helps you Craig ([email protected]) let me know how you get on
The
Standby/Power light of the TV blinks when there is any internal malfunction in
the TV. The self-diagnostic function of the TV will cause the STANDBY light to
blink or flash when the television detects an issue. The number of times the
STANDBY light flashes corresponds to a specific issue.
Few
examples are given below; some of the issues may be resolved without the need
for service.
1 blink / 2 blinks / 5 blinks: - This indicates that there may be a
power-related problem with your set.
3 blinks: - This indicates that there may be a power-related problem with your
set. The set will need to be serviced to allow a technician to determine the
specific issue that needs to be repaired. If the power light flashes three
times in sequence in a Lamp TV, the lamp cover is not securely attached.
Reattach the lamp cover to resolve this issue.
4 blinks: - This indicates that there may be a back light or lamp power
problem.
6 blinks: - This indicates that there is some kind of audio problem with your
set.
7 blinks: - This indicates that there is a temperature problem with your set.
Please check to make sure that the air vents on the sides and back of the set
are not blocked or clogged and there is adequate ventilation around the
television. We recommend that you check and clean the vents periodically to
make sure the set receives adequate air flow. If the problem continues, the set
will need to be serviced.
8 blinks: - This indicates that there may be a video-related problem with your
set. If the flash sequence is not listed above or the light continues to flash,
follow the steps below to perform a power reset:
Try the following steps to check if the issue can be resolved.
Turn off the television.
Unplug the television power cord from the electrical outlet.
Let the television remain without power for 60 seconds.
Plug the power cord back into the electrical outlet.
If
the television is plugged into a power strip or surge protector, remove it from
the power strip or surge protector and plug it directly into the wall outlet.
If the issue is resolved, the problem is with the power strip or surge
protector and not the television.
If
the issue continues to occur, service may be required.
Thanks
for using Fixya.
The
Few
for service.
problem.
set.
If
If
Thanks
for using Fixya.
The
Few
for service.
problem.
set.
If
If
Thanks
for using Fixya.
Diagnosis: If none of the above test resolve the issue, then the failure lies in one of the following:
None TV is powered off. Normal operation.
Green TV is powered on. Normal operation.
Green 1. TV just plugged into AC outlet.
Wait until blinking stops before turning on (approximately 1
minute). Normal operation.
2. AC just restored after power failure.
3. TV Rebooting after System Reset was
used.
4. TV Rebooting after power fluctuation
or receiving abnormal digital signals
from digital channel, or digital device.
5. You have begun the procedure to
update software from an authorized
flash memory device.
For detailed information, see the instructions that accompany
the authorized software update. IMPORTANT: Do not
use unauthorized software at any time.
Green TV just powered off and lamp is
cooling.
Starts to blink 30 seconds after turning off TV. TV can be turned
on before blinking starts or after blinking stops, but not while the
indicator is blinking. Normal operation. hope it helps regards shaun
Green TV powered off and auto-on timer is set. Normal operation. TV can be turned on at any time.
