Question about Samsung PCK5315RX TV
Samsung Projection TV Model # is PCK5315R
I have a 2000 Samsung Projection TV Model # is PCK5315R. I tried to turn the tv on but all it did was click and then make a gradually decreasing hissing sound. Now it won't turn on at all. Some advice on how and what part needed to fix it, or how much it might cost. i would like to fix it myself if possible. It displays a light on the "timer" indicator on front of the TV but the TV doesn't respond, no picture or sound. Any assistance would help, Thank you.
  • shel39 Apr 15, 2009
    We have exactly the same issue, on the identical model unit... We sure hope we can find a fix!
  • 150 Answers
SOURCE: Samsung 54" rear projection PCL5415R Won't Turn On
Although I am not incredibly familiar with your model, There is most likely a small board mounted above the others near the crts, there is a small red connector with a blue wire if you unhook it it will remove power from the convergence IC's and if they are shorted it might come up with conv out, will need a new module.
Posted on Jul 07, 2007
Shuttle83
  • 1139 Answers
SOURCE: Samsung TXN2726 TV Does not turn on
This denotes a power supply problem. The trouble could be in the low voltage or the high voltage supply. You will need a schematic and at least a multimeter to even beging to troubleshoot this problem. If you do not have a background in electronics. I would suggest taking the set to a TV repair shop.
Posted on Sep 22, 2007
  • 35 Answers
SOURCE: Samsung DynaFlat TX-P2775H 27
Do you get any indication of power to the unit? Mine didn't.. the light next to the power button didn't come on. Turned out it was just a fuse inside the unit. So, take it in for repair and hopefully its a simple fix.
Posted on Dec 13, 2007
rey jr
  • 149 Answers
SOURCE: Samsung TX-P2670WH 26" tv squealing
hi there, you do have a problem at the hozintal section, check the FBT and some parts at the horizontal section and at the power supply section. ty
Posted on Jan 01, 2008
SOURCE: PROBLEM WITH SAMSUNG DLP TV
disconnect the power and hold in the power button for 30 seconds to reset it.
Posted on Mar 03, 2008
Bought Samsung dlp h-l 5667w new in 2005. Replaced lamp, fan, and color wheel in 2008. Now lamp lights up and lamp indicator on front lights up, fans turn on, but tv picture will not show. After a few...
It time to replaced the tv projection lamp again,the tv projection lamp life span have ended.The tv projection lamp life span only last 2000 hrs.Average out like 1 1/2 or 2 years max for tv on watches 4 or 5 hrs of tv every days.
Jul 07, 2011 | Samsung HLR5667W 56" Rear Projection HDTV
Tv takes 20 minutes to turn on, keep hearing a clicking sounc
Ur tv the Ballast board the help to turn on the tv projection bulb is dead.Try website like Tvrepairworld.com to buy the Ballast board for the replacement.The Samsung/Akai tvs use the same Ballast board.When in the website go to the menu that said Samsung/Akai circuit boards.Pick that option click on it,u will see a picture of a Ballast board look like.
May 31, 2010 | Samsung HCN4226W 42" Rear Projection...
HCL4715W 47 in. Rear Projection Television: Wheb the TV is turned on the screen is fine, howev...
Yes,this tv can be fix it have convergence problems.The convergence board the 2 STK covergence ICS are defective and some or all it resistors are dead.The shop will cost u $300-350 for parts and labors.
May 16, 2010 | Samsung HCL4715W 47" Rear Projection...
Have lamp cooling fan noise on Samsung HLP5063W - 50 when I turn on TV and screen is distorted. Noise on TV is gradually getting worse and now does not go away and I essentially have no picture. Do I need...
the problem with your tv is the color wheel
not the fan let me know if you need help to take it apart...
I do repairs for samsung tv and I fixed a lot of them before..
Jul 29, 2009 | Samsung HL-P5063W 50" Rear Projection HDTV
Samsung PCK5315R TV
I have the same problem have you figured out what the problem is
Jul 31, 2008 | Televison & Video
Samsung rear Projetion Tv Model No. PCJ522R
I Have A
Samsung rear Projetion Tv Model No. PCJ522R i was cleaninthe inside when i spilled oil on half of the board power supply,when the tv is connected power button is light up but wont turn on,what can i do?
Mar 18, 2008 | Samsung PCJ522R 52" Rear Projection...
TV won't turn on.
Samsung Projection TV Model # is PCK5315R. It displays a light on the "timer" indicator on front of the TV but the TV doesn't respond, no picture or sound.
Mar 02, 2008 | RCA HD52W56 52" Rear Projection HDTV
Rear projection tv
the wing-nuts on the tubes are for focus. try adjusting the screen control for all 3 tubes and see what you get. there will be a square type object that you see in the front near the picture tubes. turning left will decrease the luminous for that specific tube and right will increase***do not turn too far right because you could make the set go into shutdown. if you see lines in the pic then start turning it back the other way*** if that works then glue the knobs so next time you don't have this problem again. otherwise you might have loosened a connector somewhere inside tv.
Feb 20, 2008 | Samsung PCL545R 54" Rear Projection...
Samsung 52" rear projection tv convergence problem?
THE PROBLEM IN YOUR TV. IT'S THE CONVERGENCE. YOU NEED REPLACE THE CONVERGENCE STK'S AND AFTER THAT YOU NEED DO ADJUSTMENTS.
Jan 14, 2008 | Panasonic PT-47WX49 47" Rear Projection...
Televison & Video Logo
115 people viewed this question
Jerry Greenberg
Jerry Greenberg
