Question about Zanussi 18 in. DE4744 Free-standing Dishwasher
Zannussi de4744 switch on dishwasher but it just hums seems to have washed but not full cicle and ideas chaps cant switch off says ready but hums
Aquastop on water inlet tripped. Turn off and slightly undo main inlet hose. find water inlet valve and remove thin pipe from nipple. Turn m/c on for a few seconds, turn off and replace all pipes m/c will now fill and continue
Posted on Jul 12, 2007
Meiko manual 530f
I have a meiko 530f.
recently suddenly switching off while washing.
furthermore, the first washing cicle doesn't seems to end e any ad
Would you have any advice on that?
Thanks
Jackl'yn
Jan 03, 2014 | Dishwashers
Frigidaire FFBD2403LW normal cycle hum
Hello ddux97 - Often this occurs because either not enough water is being pumped to the spray arm or in other words the full flow of water is not making it to the upper spray arm. Will the spray arm rotate freely? If it does not, then you might have to remove or replace the spray arm assemblies since it is possibly damaged. Confirm that the drain hose is strapped up properly under the sink to prevent the water from siphoning out during the cycle. If issue persists, I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if the unit's status has changed successfully.
Jun 20, 2013 | Frigidaire Dishwashers
Makes noise during wash cicles and dishes are not cleaned
Hi Kenneth Cho - I will suggest verifying that there is enough water pressure coming into the unit. Is the unit making a grinding noise? If it is, then the dishwasher seems to have a defective drain motor. When was the last time the filter was cleaned? Do you noticed if the spray arm will rotate freely or if it is damaged? If so, you might have to remove and replace the spray arm assemblies. If any proves to be ineffective, it could possibly have a communication problem coming from the main control board, I would suggest contacting a professional technician to diagnose the unit accurately.
Nov 24, 2012 | Frigidaire FGHD2433KF Builtin Dishwasher
GE washing machine does not run, gives humming noise
A washing machine is a simple product.
When trouble shooting anything you have to know what is supposed to do and what is it not doing.
At the begining of a washing machine cycle the machine fills with water until a switch is made telling the machine it is full and ready to agitate. Since it never fills it will stick in that part of the cycle.
When you start a cycle and no water enters the drum you have one of three problems:
1. The water supply is shut off.
2. The solenoid valve that supplies the water is not opening.
3. No power to the washing machine.
Since you are hearing a hum, the machine seems to be trying to activate that valve,
The humming noise comes from the electromagnetic field that activates the valve,
Dec 04, 2008 | Washing Machines
Electrolux ESL4114 problem
see other problems listed ,other machines have similar problems one chap suggests that the FLOAT SWITCH is stuck or faulty causing the inlet valve to read as full so continues program...
Oct 30, 2008 | Electrolux 18 in. ESL4114 Slim-Line...
Control Panel
I have not heard of this brand of a dishwasher but It should be like any other. I would say that the control panel for the cycle select is bad and needs to be replaced. You will want to check and see if there is any kind of thermal fuse that may be open and to make sure there is power getting to the control. Also check that the door switch is als operating normally.If all checks out good replace the control bord. Good luck
Jul 19, 2007 | Zanussi 18 in. DE4744 Free-standing...
Dishwasher
I have not heard of or seen this dishwasher but I do know on a lot of dishwashers if the water is not hot enough it will heat the water and the heating light will come on to let you know. On most models if the washer has to heat the water it will prolong the wash time. It may do this through out the wash and rince cycles. dont be surprized if your dishwasher runs 90 min or longer. This is normal for most all dishwashers now. I would read the owners guide and get to know whats normal for your unit.
Jul 12, 2007 | Zanussi 18 in. DE4744 Free-standing...
Flashing lights
You have a heat problem, using a test meter check the heater element, then check the thermostat if niether of these you have a PCB fault Regards Engineer
Mar 15, 2007 | Indesit 23 in. DV62 IX Built-in Dishwasher
Zanussi 18 in. DE4744 Free-standing Dishwasher Logo
284 people viewed this question
Top Zanussi Dishwashers Experts
Paul Carew
Charles T Nevin
Charles T Nevin
Are you a Zanussi Dishwasher Expert? Answer questions, earn points and help others
