Question about Panasonic PT-56HX41 56" Rear Projection Television
Color shadowing I am still having the same problems that I was having with the color shadowing after I replaces the Convergency IC. I am still not able to adjust the blue from one side and down is there anything that I have missed that you could let me in on or should I call a repair man and have him service it? I have the Panansonic PT-56HX41PE
  • Panasonic Master
  • 3,459 Answers
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projeciton sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the settings menu then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move RED and BLUE in all directions - up, down, left, and right. And you should be able to get the grid straight.
If you can't move them in all directions or cant move them far enough your convergence chips are bad and should be replaced. This is a common problem.
Note: If you TV has as flash focus or magic focus button only try pressing the button. If it fails to fix the convergence your need to fix it. See below for a fix
69189a5.pngCONVERGENCE SOLUTION
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses.
This is a a fairly easy DIY job if you are handy and can follow directions. You can get complete repair kits from TvRepairKits.com or click here. They have put together DIY repair kits that include the OEM parts and step by step photo instructions for each repair. If you are not handy or can't follow directions we would suggest calling a shop.
Posted on Jul 03, 2010
Apex gb4308 43 inch projection tv
This is not my main field of expertise, in any case here is the link for a solution to same problem and same model. According to expert the problem is related to vertical chip fault.
http://www.fixya.com/support/t142256-apex_gb4308_multi_colored_horizontal_bow
hope it may help you
cheers
Feb 18, 2008 | Apex Digital GB4308 43" Rear Projection...
My TV color has yellow, blue and red shadows n the picture.
Enter Service mode.. Press Menu -0-1-5-7 in quick succession . From there select the convergence option. You should see 3 crosshairs -Red, Blue and Green. Green is fixed but Red and blue can be moved. Align both of them with green and see if the issue resolves. If not Try moving them around and see if the problem is cleared. If not you may have the inevitable convegence IC problem and the IC needs to be replaced. Let me know if that is the case and I will give you the procedure.
Jun 11, 2010 | Mitsubishi WS-55907 55" Rear Projection...
Blurry picture
Sounds like convergence failure. (Colored shadows of images.)
Apr 13, 2010 | Televison & Video
Red color convergence issue; Red lines are curved
This sounds like convergence output IC problem. convergence board would have to be removed - remove and replace 2 STK IC's and check the surrounding resistors. Shops usually $200-$400 Be sure to vote/rate me if this helped Thanks!
See link for more detail
http://www.ehow.com/how_4575598_yourself-projection-tv-repair-convergence.html
Nov 24, 2009 | Televison & Video
Different color shadows. Double or triple vision
replaced convergence IC.what is the model#?
Oct 04, 2009 | Televison & Video
Objects are shadowed on screen and color seems to be seperating
This is a convergence output IC problem. convergence board would have to be removed - remove and replace 2 STK IC's and check the surrounding resistors. Shops usually charge between $200-$300
Sep 30, 2009 | Toshiba TW65H80 TV
Can't set color and everthing has a shadow
I sounds like you have a convergence IC issue. These parts are not expensive, the average repair for replacement of these and re-convergence is around $250-350 from most svc co's.
Feb 28, 2009 | Zenith Televison & Video
Mitsubishi WS-55511
Good Day;
Sounds like you have bad Convergence Output IC > 267P155010 > STK393-110, replace and it will correct the problem TV uses only ONE, make sure all resistors look good in the circuit around IC.
Good Luck, big IRISH.
Sep 19, 2008 | Mitsubishi WS-55511 55" Rear Projection...
Samsung hlp4663wx/xaa (after replacing the color wheel)shadowing
If the color wheel you replaced was the BP96-00674A, it would have come with the proper cca adjustments for that particular wheel. You must enter the service menu and reset the cca's for proper color.
Feb 20, 2008 | Samsung HLP4663W 46" Rear Projection HDTV
Panasonic PT-56HX41 56" Rear Projection Television Logo
79 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
