Question about Refrigerators
Need a water filter
I have a 2004 Kenmore side by side 106.54536400 refridgerator -
I bought a 46-9010 water filter but when I put it in - it will not turn 1/4 turn right, to fit in? What water filter am I suppose to be using?
  • sullivcaroli Nov 18, 2008
    This answer actually confirms my research. Now, I will order it and we will see
    what happens
Dont even need to buy a water filter system these days, you can build one with things you have at home. Here's a pretty simple guide http://hubpages.com/hub/How-To-Build-A-Water-Filter Forget water filter systems, you can get results for free these days.
Posted on Jun 02, 2010
  • tommyear Jun 02, 2010
    Oops, that link didnt work properly href="http://hubpages.com/hub/How-To-Build-A-Water-Filter">Build Water System There ya go.
    President:
  • Refrigerators Master
  • 2,651 Answers
Part number 9010-- substuted over to part number 4396510, says its the right part
Posted on Nov 18, 2008
Is there a water filter in my 7102 kenmore refridgerator
There could be one in the water line that feeds the ice maker.
Apr 03, 2014 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Kenmore fridge with a strong chemical taste in water and ice
Every time you replace a water filter you want to purge about 3-4 gallons. Or maybe the filter was bad.
Dec 31, 2012 | Refrigerators
We have a Kenmore side by side refridgerator and need a replacement water filter. Where do we buy one?
Sear would have them for sure. But places like Lowe's and Home Depot usually stock the common ones.
Jun 08, 2011 | Kenmore Side by Side Refrigerator
Why doesnt the water and ice work on my side x side kenmore refridgerator
1st-Make sure you have water entering the unit. 2nd- If you have recently replaced the water filter- make sure it is properly installed. When you press the water dispenser, you should be able to hear the water valve energizing. If all fails, your best resource is to have a Sears tech service the unit specially if Ice-maker continues Not to function. It might be costly but they warranty the work without any stories.
Oct 05, 2010 | Kenmore 57029 Side by Side Refrigerator
I WAS WONDERING ABOUT THE ICE MACHINE,IT ISN'T
check for water then check water valve where hose connects. the see if the is water in ice maker if so then wait for ice, if no water it could be the valve
Jul 28, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Refridgerator problem
Not sure about your model, but most of these style side by side refridgerators use the cold air from the freezer to cool the refridgerator. Sounds like your "flapper" valve is broken. At the top left in the refridgerator there should be plastic shroud. Remove it and your flapper valve should be under it. You will most likely find the flap broken off of it. You may have success using epoxy to glue it or you may have to replace the valve assembly.
Good luck.
Apr 20, 2009 | Frigidaire FRS26H5AS Side by Side...
Refridgerator not cold
Called Sears to send a technician. Replaced the thermostat (DTS). Fridge is now working. The themostat was $21 + service/labor total $160 +/-.
Nov 30, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Kenmore no water
does the machine have a lock out button on the despenser that you can push to activate the water and ice
Apr 06, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Refrigerators Logo
194 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
