Question about 3Com NBX® V3000 (3C10600BUS)
How To reset to Factory deffault NBX V3000 from Console Cable
My V3000 NBX is on unknown state. Cannot acces Netset or ping. But I can connect via console and get NBX300--> prompt.
I can run command . What I wonder to know is what command that set NBX to factory Deffault state?
  • Anonymous Nov 26, 2008
    I need to reset my v3000 to factory defaults because i dont know the password.
  • Anonymous Mar 23, 2009
    same here
    Problem Solver:
  • 10 Answers
NBX runs on VxWorks. Goole for the command on VxWorks to restore the FD settings.
Posted on Jun 11, 2009
Goto http://www.abnormal.com/~thogard/nbx/password.html.
The cracker at the bottom of the page will decrpyt any password that NBX uses.
Posted on Aug 27, 2009
  • 4,924 Answers
Http://www.polycom.com/global/documents/support/setup_maintenance/products/voice/soundstation_ip3000_3com_nbx_admin_guide.pdf
this is a guide...if it does not have a restore button hidden somewhere ..like on modems...
get into the main menu /// admin setup...restore defaults ..
this should restore to factory defaults ...in ths guide there are schemes about that on page 10
Posted on Nov 10, 2009
Lost web interface otherwise system is working
This does happen occasionally but is not a typical thing. This means that you have either lost network access to the system or a service on the system has stopped. The system will have to be rebooted to get things going normally again. The preferred method (since you can do it through netset) is to connect to the console port with a DB9 straight through serial cable and open hyperterm or putty and connect to it at 9800, 8, 1 none settings. Hit ctrl r and the system will reboot. if you don't have a serial cable then you are forced to pull the power or switch it off and then back on. CAUTION: you risk a database corruption every time the system loses power without closing the database properly (netset or ctrl r through the console) so do this as a last resort. Also, the system will do a disk scan (except V3001) and will take 15 to 45 minutes to complete before the system will start to function again. DO NOT UNPLUG IT AGAIN WHILE IT IS DOING A DISK SCAN! You can tell if it is doing the scan by looking at the S1 and S2 lights on the Call Processor. During a disk scan, they will be alternating back and forth (like police lights). Wait for it to complete and try netset again. I recommend doing a fresh reboot through netset after it comes back up just to be sure it's a fresh clean boot.
Jan 10, 2014 | 3Com NBX V3000 IP Phone
We had a power outage last night and I have not been able to successfully restart my 3Com V3000 server. I have powered it down several times, waited several minutes before restarting, but it just shows...
After you power it up LEAVE IT ALONE for at least 45 minutes. When the NBX loses power abruptly it will do a disk scan upon reboot. The disk scan takes anywhere from 15 minutes to 45 minutes (depnding on the size of the database). You can connect to the console and see it doing a disk scan when you boot it back up. It will go through 6 phases and then boot up normally. Each time you pull the plug you risk database corruption (or hard drive failure on an older system).
Aug 05, 2010 | 3Com NBX® V3000 (3C10600BUS)
I cant modify an extention number the apply button is greyed out
If you are using Internet explorer 8 click on the compatability mode icon. That should do it. You can also click "OK". I'v seen some strange things with IE 8 and the NBX Netset interface.
Aug 04, 2010 | 3Com NBX® V3000 (3C10600BUS)
We have a 3Com NBX V3000. The building our office
This was a rather simple fix. When I was speaking about the NBX V3000, I was talking about our 2U NBX Chassis which holds the line card. When our phone system was installed I wasn't shown the 1U NBX V3000 "Brain". I thought everything was contained in the chassis. Long story, short, I restarted the 1U "Brain" and the system came back up with 5 minutes.
Feb 15, 2010 | 3Com NBX® V3000 (3C10600BUS)
NBX 3000: Can't access WEB UI or Ping - System still up.
There is most likely another device on the network with the same IP as the phone system. You can check this by un plugging the link to the phone system (after hours of course) and then pinging the IP of the phone system. If you get a reply while the link is disconnected then you know there is a duplicate IP on the network. You can use your server to try to identify the device or use a IP scanner like NetScanTools to ID it. You could also try changing the IP address of the phone system and see if you have the same problem.
Apr 17, 2009 | 3Com NBX V3000 IP Phone
Need to reset admin password on V3000
Default password is 0000. If you lost a password you set its almost impossible to retrieve.
Mar 26, 2009 | 3Com NBX® V3000 (3C10600BUS)
My NBX V3000 suddenlny is frozen. the NBX hang, no dial tone on the phones, not accessible from the network, can't receive outside calls. The access to the NBX via Hyper terminal is possible during the...
Are you trying to forward calls in circular from 1 extension to the next. Like 101 to 102 back to 101. If not I would purge the database and start over. Export user data so you can see the Mac address of each phone and it will be easy to reconfigure the extensions. Do not import the Data. Start from scratch.
Mar 17, 2009 | 3Com NBX® V3000 (3C10600BUS)
Random crashes of 3Com NBX V3000...
Call 8008763266. Also check 3Com Primus Knowledgebase for savecore procedure.then check nboss.log.
3Com NBX Support Team
Feb 12, 2008 | 3Com NBX® V3000 (3C10600BUS)
Nbx v3000
check with the power supply, do you have a constant power supply
Feb 08, 2008 | 3Com NBX® V3000 (3C10600BUS)
3Com NBX® V3000 (3C10600BUS) Logo
3,706 people viewed this question
Top 3Com Computers & Internet Experts
micky dee
didi2005
john smith
Are you a 3Com Computer and Internet Expert? Answer questions, earn points and help others
