Question about Philips 42PF7320A 42 in. Plasma HDTV
Remote control code for 42PF7320A/37.
Can you tell me the exact, correct, code for the above flat screen TV, so I can enter it into my universal remote and get rthe maximum amount of functions?
  • 12 Answers
SOURCE: REPAIR NEEDED
sounds like the Y boards.best to replace all 3 at same time main and buffer upper and lower
http://www.shopjimmy.com/searchparts.cfm?make=Philips
Posted on Jul 21, 2008
  • 5 Answers
SOURCE: Need Universal remote code for Magnavox 15MF400T/37
these are the codes associated with Radio Shack's line of remotes:
One for All Universal (Radio Shack)
0054, 0179, 0030, 0020, 0024, 0096, 0186, 0171
And I was also able to find these:
UNIVERSAL REMOTE CONTROL CODE LIST for TVs
MAGNAVOX
002 009 109 118 209 309 402 408 502 508 510 807 914 917
Posted on Feb 26, 2009
SOURCE: Universal Remote Codes
I just programmed my comcast remote today and the codes in the manual work fine. I was lucky, the first one as the one I needed. Good luck.
11454, 10054, 10030, 10706, 10187, 10386,10802,11198,11254,11963,11990.
Posted on Jun 06, 2009
  • 44 Answers
SOURCE: Philips 42'' Plasma TV 42PF7320A/37 red led error codes
I had the Same issue. on a 50PF9431D/37 set. Many Plasma Set's use a LJ44-00118A PS-505-PH Power supply from Samsung. Known to have this common problem. If you can, or have a friend that can Solder components?. Unplug your set remove the back panel & locate your power supply. It will be the PCB in the center of the set just above the Video/Audio connections. http://www.shopjimmy.com/power-supply-unit-lj44-00118a-from-philips-50mf231d-40.htm. Is a Link to a photo of the PCB. Make a note of the locations of all cable connections then unplug them all. Un-install PCB, Check all Fuse first. I believe their is 5 or 6 of them on the PCB. Then replace the two 3300uf 10v 105C Radial capacitors at C8060 & C8059. Look to see if the Caps are deformed and or split at the top. The location of the caps are in the Lower bottom edge of the PCB. A local shop may Carrie them if not, digi-key has them. Part # http://search.digikey.com/scripts/DkSearch/dksus.dll?Detail&name=493-1754-ND. Total cost was $7 with S/H.
Posted on Jun 25, 2009
Xeuvious
  • 100 Answers
SOURCE: tv turns off and I get a red flashing light on
After looking through the user manual I could not find any error codes to diagnose your problem. I suggest calling Phillips Customer Support at 1-888-PHILLIPS.
Posted on Sep 30, 2009
Total Control Universal Remote. URC 4140. What is the 4 digit code to operate the above TV
Search Results
    [PDF]Total Control URC-4140 - Universal Remote Control Codes
    www.remotecodelist.com/remotes/URC_4140_B00_and_B01.pdf
    UNIVERSAL. Remote control. URC - 4140 ... Your TOTAL CONTROL can operate four devices: a Television, ... The TV, VCR/DVD, SAT and AUX keys select the device.... 4. Enter your four-digit code using the number keys. The red light will blink twice.... To set up your other devices, follow the same instructions above, only.
    Codes and links for a number of universal remote controls, including Sony, RCA, ... GE Remote Codes, General instructions for GE Universal 3 and 4 digit remote controls. ... This manual may work for a number of Philips-Magnavox remotes. ... Total Control URC-4140, PDF Instruction Manual (remote also known as Crest .
Jan 13, 2016 | Sanyo 42 in. LCD TV
This TV has been in use for 2 years. None of the cables have been changed or removed. Apparently hit a button on the remote that blanked the picture & sound. I have a gray screen with menu options,...
Hi Jim:
You can find an owners manual on the Philips site.
There's also a quick start guide and a firmware update.
http://www.p4c.philips.com/cgi-bin/dcbint/cpindex.pl?ctn=42PF7320A/37&scy=us&slg=en
Try the above link, should take you to the site..or you can
do a google search....
owners manual Philips 42PF7320A/42
you should see this link in the list of links...maybe the top one.
42PF7320A/37 Philips flat HDTV 42PF7320A 42" plasma digital cable ...
May 25, 2007 ... Philips flat HDTV 42PF7320A 42" plasma digital cable ready with Pixel Plus ... Manuals & documentation · Leaflet · User manual · Quick start guide. + More Manuals and Documentation ...
Hope this helped.
Dec 27, 2010 | Philips 42PF7320A 42 in. Plasma HDTV
Need the 4 digit universal remote control code for toshiba 37e200u.
your user manual for tv should have that in it. however go to www.manualsonline.com enter the universal remote mfg and model number in search bar, if they have it there, you can download the manual w/codes for free... best of luck.
Oct 17, 2010 | Toshiba 37E200U 37 in TV
Have a philips 42pf7320A/37 with poor menu control. It keep popping up and staying on screen,even after activate exit, it pops back up.
That's your remote, not the TV. Your Remote button is hanging. Try a Phillips universal remote replacement and see if that problem doesn't go byebye.
Mar 09, 2010 | Televison & Video
Vizio vw37l tv with a lost remote. i have a panasonic universal one is it possible to program it?
Try 1-800-Remotes Factory original.Buy an exact remote.Finding unversial remote codes like pulling teeth i'm telling u.
Jan 19, 2010 | Vizio VW37L 37 in. LCD TV
Need a remote code for the tv 37" Sabre LCD Tv Model # lct371bka. RCA Universal remote Model # RCR660
as soon as u bought the universal remote it came with a paper that say a bunch of codes find ur tv model go to set up look were u can put in the code and follow the code exact
May 24, 2009 | Sabre LCT371BKA LCD TV
Remote codes for sentry rmc10 really big universal remote
i need the codes for the Sentry Big universal remote for a philips magnavox or for someone to tell me how to do the code search
Jan 28, 2009 | Samsung DLP HL-P5663W 56" TV
RCA REMOTE CONTROL CODE FOR OLEVIA/SYNTAX 237 HD TV
Go to Best Buy and buy the DirectTV Universal Remote Control Model RC64 ($20). It will control all the functions on both the Olevia TV and the RCA Satellite box, except the A-B-C-D buttons for the User Guide. It's codes are:
Satellite Box - 00392
Olevia TV - 11610
Enjoy!
Nick from Ft Myers
Feb 10, 2008 | Olevia LT37HVS 37 in. LCD HDTV
Philips 42PF7320A 42 in. Plasma HDTV Logo
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
