Question about Intel D945GNT Motherboard
Intel d945gnt after i set aggressive on memory bios set, 3 beep after rebot. please help me.
  • pulcinella19 Nov 18, 2008
    on motherboard have 4 1GB kingstom, one for slot
Yesterday night i resove the problem with the intel by many e-mail.
For all guys that have the same problem , the solution is:
1- put the jumper in position pin 2 and 3.
2- turn on the PC with jumper in the same position ( pin 2 and 3)
3- the bios start in "recovery mode"
4- deselect the memory "aggressive mode"
5- save bios setting, then power off the PC
6- set bios jumper in position 1 and 2
coolhandan thx for attention and please insert this solution in intel D945GNT archive for future customers that fall in same problem. Sorry for my bad English ;) THX at all
Posted on Nov 18, 2008
  • 102 Answers
Try to resrt the bios jumper near the batary on the motherboard put the jumper on to the other 2 pins for 3 seconds then put it back
What are maching ram for Intel D945GNT
Hello here is the homepage:
The board has four DIMM sockets and support the following memory features:
  • 1.8 V (only) DDR2 RAM DIMMs with gold-plated contacts
  • Unbuffered, single-sided or double-sided DIMMs with the following restriction: Double-sided DIMMs with x16 organization are not supported.
  • 4 GB maximum total system memory.
Windows xp does not support, more than 3 gb ram in the 32bit version.
Please take antistatic precautions, when working on the mainboard.
The drivers site is here if needed:
Good luck
Jan 24, 2013 | Intel D945GNT Motherboard
Problem with the Intel Desktop Board DG41BI\r\n I
setting the memory is pointless as the system will automatically find the best speed for it if its set to auto. As for the 3 beeps that is generally vga, but could be different on this motherboard , when you clear the bios do you move or short a jumper
Mar 11, 2011 | Intel Motherboard
After BIOS Update -- No POST
you may need reformat your HD...
Jun 08, 2009 | Intel D945GNT Motherboard
Hardware Monitor not working- Intel D945GNT
Not sure what chip you are using, but your problem is one which I have had and solved by the most extreme heat dissipation methods possible...I even went to the extremity of packaging dry ice in Plastic and using an external fan to literally produce arctic temperatures inside the case.
It did attenuate or reduce the heating problem and the Intel hardware monitors took note of that, but I also notice some degradation in the extent of the graphic presentation of the on screen diagnostic display of temperature, fan speeds, etc.
So, with your new problem, since you apparently responded to the three long beeps by adding a keyboard or other peripheral, and solved it, a full statement of that problem with all specs would be appropriate, unless you can no longer read the display.
Mar 27, 2009 | Intel D945GNT Motherboard
Alienware Desktop will not boot
Try removing the RAM as well and see if it beeps...
Feb 11, 2009 | Intel D945GNT Motherboard
3 beep sound
the 3 beeps means memory problem.
un-install the memories, take a look the stick and the slot. make sure they are in good condition.
reinsert the memory firmly, and make sure they are lock down.
if the still appear, you need to get new memories for the board.
Nov 12, 2008 | Intel D945GNT Motherboard
3 beep sound coming
Open your chassis (cabinet) and look for the bios jumper on the motherboard. It is located near the SATA ports next to the Front Auxiliary Fan connector. Put the jumper in 2-3 to enable maintenance mode. This will allow you to enter bios settings. Then redo any changes that you had made, i.e. reset the memory configuration to auto and save the changes and exit.
Now replace the jumper in 1-2 position. Reboot. And your system will work fine.
Apr 16, 2008 | Intel D945GNT Motherboard
HD Audio Hardware Problem
just try to go in the bios and load default setting ,,,if issue persist then update the bios
Aug 12, 2007 | Intel D945GNT Motherboard
Intel D945GNT Motherboard Logo
243 people viewed this question
Top Intel Computers & Internet Experts
Alun Cox
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
