Question about Panasonic KV S2045C Path-Through Scanner
KV S2045C scanner
When scanning in duplex, only 1/2 of the back page scans. It cuts it down the middle. Any idea why?
  • John Dezember May 11, 2010
    Just to clarify, one side of the page scans as expected and the other side is completely black?
Wow, it's been so long since I posted this, I cannot remember! I am the tech person and just was relaying the problem as an EX exployee relayed it to me. What did my original message say? I BELIEVE it was 1/2 black, but no image/words on the other half. Just black and white, but again, I cannot remember. Does it make a difference?
Posted on Dec 03, 2008
Can i skip blank pages while scanning duplex with a 5080c using capture perfect 3.0?
There is option to skip Blank pages. You have to specify in terms of percentage, above which the scanner will save and discard images below the specified percentage.
S. Mohan, India
Feb 28, 2013 | Canon DR 5080C Path-Through Scanner
Canon Dr2050C Duplex scanning reverse page all black
Check your brightness setting for backside. Ideally keep it automatic, else you can manually choose the right brightness.
S. Mohan
Sep 18, 2009 | Canon DR-2050C Path-Through Scanner
Scanner is not reading multiple pages...
Check your scanning software settings. If you are getting only one file output, then you must have chosen 'multipage' option.
S. Mohan
Jun 12, 2009 | Canon DR-2580C Path-Through Scanner
When i scan a letter 2 page is scanned:letter and blank page
You may be set for front & back (duplex) scanning. Change the setting for front only or simplex. This could be done with check/uncheck boxes, a drop-down menu, or a keyboard shortcut. I believe the standard Kodak settings are via check boxes.
This model is also capable of putting out color & bitonal (black&white) images simultaniously. If that's the case the pages should be separate image files. Uncheck either color or bitonal depending on which you want.
Apr 09, 2009 | Kodak i40 Path-Through Scanner
Can only scan simplex or duplex
The scanner can scan in either simplex or duplex mode only. If blank page is scanned, then it will appear BLANK, else someone would say, my scanner is not scanning properly! Remove balnk pages using software or sort on file size and delete the small sized files. Take care to ensure they are really blank.
S. Mohan, India
Nov 20, 2008 | Fujitsu fi-5110C ScanMaker Scanner
Duplex- Back of page not clear
Clean the glass with Isopropyl alcohol. Set proper Contrast level. If the level is not okay, you should get atleast a dark/very light image. If there is no image at all reinstall driver. Run Scandisk on the Comp
S. Mohan
May 05, 2008 | Canon DR-9080C Path-Through Scanner
Duplex Scanning
If the line appears in the same location, it is definitely dust sticking to the glass. How thick is it? If it is thick, it may be because of an LED failed to glow, but this is etremely rare. If you are getting line in Duplex mode and not in simplex mode, it is on the second scanning module! Try cleaning with Isopropyl Alcohol (IPA). If you have been scanning old documents which tend to break like biscuit or get powdery, a speck can enter into the scanning area and create trouble.
S. Mohan
Oct 26, 2007 | Canon DR-2050C Path-Through Scanner
Only scans 1/2 back page in duplex scan.
%95 of the times its a technical faliure, Talk to the store you bought it from or call Panasonic customer support, you can not fix this by yourself. =)
Jun 08, 2007 | Panasonic KV S2045C Path-Through Scanner
Panasonic KV S2045C Path-Through Scanner Logo
88 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
HEMANT GROVER
mahesh y.h
mahesh y.h
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
