Question about Fluke Networks Fluke T+PRO Electrical Testers
Fluke 97 scopemeter will not power up
Tried 4 "C" batteries, known bad AC Adapter
  • 92 Answers
I have the same problem now check in your fluke you have a fusse change it
Posted on Dec 03, 2008
Fluke 123 lcd fault
If LCD is faulty then order one from fluke and replace.
Feb 25, 2013 | Fluke 123 Industrial Scopemeter...
Wen i swtich on the laptop it desnot on
You have three possible parts in the computer that's causing this problem.
1. Ac Adapter - it is the cord that you use to power up your computer.
2. Battery
3. Motherboard of your laptop
What you need to do is to isolate the part what's causing the problem.
Here's what you need to do:
1. Remove the battery from your computer and power it up by using the AC adapter only. If it goes well, then you need to replace the battery.
2. If the AC adapter doesn't power your computer. Then, check if the light in your AC adapter is lit. If not, try another AC which is working fine. You can borrow from your friend or family member who has the same computer. If a known good AC adapter does not turn on your computer, then replace your AC adapter.
3. If your battery is a known good working part and your AC adapter is also a known good part. then you need to contact a technician to get your computer serviced. The motherboard is an important part and you don't want to try fixing it.
I hope you get an idea on how to fix the problem. I hope this helps!
David
Feb 12, 2013 | Acer Aspire Computers & Internet
Fluke 123 will not power up
try powering by power adaptor without battery connected
Jan 21, 2013 | Fluke 123 Industrial Scopemeter...
Charger is plugged but in not charging
I see that when the Adapter is plugged-in on the Laptop it does not charge, Have you tried a different AC Adapter to see if this is an Adapter issue or if this will be a hardware issue.
This concern can be an Adapter issue try a known good AC Adapter to see if the laptop will Charge or not if still it does not remove the battery and try the Known good AC Adapter to see if the Laptop will power ON using the known good adapter if it does then the issue can be the Battery or the Charger Board in the laptop now use the Old AC Adapter and see if the Laptop will as well turn ON with out the Battery if it does then the issue is either the Battery on the laptop or the charger board on the Laptop.
I hope this helps.
Oct 22, 2012 | Computers & Internet
Not responding
You need new keypad foil (Fluke PN: 188828).
Sep 15, 2012 | Fluke 123 Industrial Scopemeter...
No key response
Keypad foil is the problem (Fluke PN:188828).
Jul 28, 2012 | Fluke 123 Industrial Scopemeter...
My hp mini 1000 will not turn on. When I plug it in the light on the side will not say it is charging. It will not charge.
Here are some steps that can help you resolve the issue.
First, try removing the ac adapater and the battery and press and hold the power button for about 10-15 secs to remove the flea power. Then try to deattached the power cable and the power brick and attach it again properly, plug it to the computer without the battery and try to turn on the computer. If still the same problem try a good known power socket, if your using power strip try to plug it directly to the wall socket. If nothing works, try a good known ac adapter, or try you ac adapter to a good known working computer. If a good known ac adapter didnt work, contact HP as this is a power supply issue on the computer (power supply are mostly attached to motherboard for portables) contact HP to check your warranty and have it serviced. If the good known ac adapter works, contact HP to check the warranty and have the AC adapater replace or simply replace the ac adapter.
I hope this will be able to help you.
Thank you for choosing Fixya.
Mar 10, 2011 | HP Mini 1000 Netbook
Acer 5920 aspire wont start
1. Remove laptop battery, optical drive, hard drive and ram. Remove external peripherals as well.
2. Make sure AC Adapter is not yet connected to the laptop. Pressand hold on the laptop’s power button for 10 seconds to drain the powerflea.
3. Connect the AC Adapter for laptop to a known good power outlet, check ACAdapter power LED if it is on. Try to sense if AC Adapter is not makinga bit of noise when it is plugin to the wall power outlet.
4. Connect now the AC Adapter tothe laptop. Check if AC Adapter LED stays on when it is connected tothe laptop. If the LED stays on means the AC Adapter is fine. If the ACAdapter LED turned off check the AC Adapter pin that goes to the laptopAC socket if it is loose.
5. If AC Adapter stays on after connecting to the laptop try topower on laptop. If no power LED comes on then this is motherboardproblem.
6. Before replacing the motherboard there is one checking needs todo. If you can open your laptop bottom part then good, do this whenlaptop is not connected to any power source. Try to reseat the laptopCMOS battery then try to power on laptop after, if still fails thenreplace motherboard. I hope this helps.
Jan 19, 2010 | Acer Aspire 5920-6727 Notebook
Ac adapter does not connect to battery
You either have a faulty ac adapter; a bad power supply in your laptop; a bad battery; or a blown LED indicator light.
1. If the connection is not loose when you plug in your ac adapter try letting the laptop charge for a while. (If you are using the correct ac adapter)
2. Try removing your battery and using the ac adapter. If this works the battery is bad.
3. Try a new ac adapter.
4. Power supply is bad
Jun 05, 2009 | Dell Inspiron E1505 Notebook
Fluke Networks Fluke T+PRO Electrical Testers Logo
1,757 people viewed this question
Top Fluke Networks Measuring Tools & Sensors Experts
Vuk B
Trevor Turner
joseph m fucci
joseph m fucci
Level 1 Expert
Are you a Fluke Networks Measuring Tool and Sensor Expert? Answer questions, earn points and help others
