Question about Compaq Presario M2000 Notebook
Not able to open windows
Power on...screen shows compaq...straight away black out...but power still on.Previously right after PC switched on and compag logo showln, it would show Windows XP loading screen...now just black screen.Tried F8...safe mode/ laste workable configuration and Windows starts normally..didn't work. Could it be a Hard disk problem? By the way mine is a Compaq Presario M2000 with AMD Athlon processor.Please help?
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 86 Answers
Sounds like a hard Drive problem. A virus actually. The Best thing to do if Safe Mode Failed is the Repair Your system, to do this insert your XP CD and wait until it says 'Press any key to boot CD' Press any key and follow instructions to repair windows. If it works, run a virus scan immediately. If Not, take it itno a computer technitian to look at it if you want the stuff on your Hard Drive, of if you feel you don't care too much just wipe the Hard Drive and Re-Install Windows XP. just do the same thing as repair but instead follow the instructions for Installing XP and choose either Clear or Erase Hard drive if you don't want the info or choose don't clrear or Erase if you really want stuff from your hard drive, But run a Virus scan Immediately asap.
Hope This Helps
Posted on Nov 20, 2008
Toshiba c855 screen went black
Try to reinstall windows formatting your Hard Drive... It seems to be an windows crash, or some software.
May 10, 2013 | Compaq Presario Computers & Internet
My compaq monitor for my desktop turn on switch pops on and straight off need to replace switch
This can be fixed. You have to open the monitor and reset the power switch so that it will press the power button within the monitor. BE CAREFULL!!!!!! Monitors can retain a nasty power shook even with the power cord unplugged. DO NOT TOUCH COILS OR WIREING DIRECTLY ATTACHED TO THE SCREEN BEFORE DEGAUSING THE MONITOR.
Good Luck
C2Solutions
Feb 14, 2012 | Compaq Computers & Internet
Hi i have a presario cq60-114em, on power up i get the fan coming on straight away, the power and wireless led on, black screen,the hdd led flashes 2x then a pause then flashes 2x and carrys on with this...
1st Steve I would remove the hard drive and power up and see if you can enter the bios by tapping either F2 or Del keys. If you can get into the bios then great. Shut down and refit the HDD. Try and enter the bios again and see if the hdd is recognised. If not then the hdd is finished. If it does show then your windows installation is corrupt. Try starting it up with your windows cd in the drive and point the bios startup to see the drive a 1st boot device. If this works then try and perform a repair of windows from the disk.
Good luck
May 15, 2011 | Compaq Presario CQ60-220US PC Laptop
Computer was on, screensaver is from my photo file - it was running. I moved the mouse to get back to the screen I had previously been on, walked away for a minute, came back, the screen was black. ...
Windows 8 especially and sometime Windows 10 may have a black screen during an update for over 15 minutes with no indication that anything is happening.
Try complete power down by holding the power key for 10 full seconds. Consider unplugging power for a few seconds after that as well.
Re-connect power, press power button to turn on the computer then if the screen goes blank, give it a half hour before looking for another solution... it may come back to you.
Nov 06, 2017 | Sharp LL T19D1-B (Black) 19" LCD Monitor
Cannot boot or switch on
The power supply is faulty and needs to be replaced, undo the screws holding the top cover on, pull the cover up and away from the from the front, the power supply will be at the back on the right, there are four screws holding the power supply in place, they are at the back of the computer case, undo these and the power supply should come out, make a note of where the power connectors go before removing, take the power supply to your local pc store, as most power supplies are standered the compaq power supplies maybe slightly smaller in size, so your local store may have a replacement or you may have to order one straight from compaq. hope this helps. cheers.
Feb 04, 2010 | Intel Compaq Deskpro EN Pentium 3 1Ghz /...
Screen went black...rebooted, computer seems to
Remove the battery and disconnect the power adapter for about a minute.
connect only the AC then boot it back up. If you can see the Compaq splash screen and still unable to load Windows, re install OS.
If you could not see the splash screen, too bad it could be a motherboard issue,
Hope this helps.
Dec 21, 2009 | Compaq Presario CQ60-220US PC Laptop
My hp compaq nx9010 notebook is no longer displaying the color black on the Windows xp start up page or on some of my powerpoints and videos. The color black is replaced by a redish color.
It seems that someone changed the desktop background color. point the mouse somewhere in the middle of the desktop, (away from any icons) and right click the mouse, a menu will appear with several options. The bottom one says properties. Click that. Once done another (more advanced) menu will appear with several tabs at the top. Click on the second to last tab, labled, "Appearance". Once in this tab. Toward the bottom right side of this screen you will see 2 buttons one atop another labled, "Effects", (on top), and, "Advanced", (below). Click the advanced button. A new window will pop up with the first option being desktop in a drop-down menu. To it's immediate right you will see "color 1" with a drop-down menu directly below it. That is where you will select the new background, (desktop) color. Once you have selected the new color, click OK, then apply on the remaining screen, then OK once the color is set.
Apr 16, 2009 | HP Compaq nx9010
I inherited N600C which had protected password
remove it again and make sure it inserted/seated correctly..
press power button to boot if nothing happens wait a minute or so and press and hold power button til unit turns off (you will hear this)
then reboot.
Jan 27, 2009 | HP Compaq Evo Notebook N600c
PC Closing Down
check your ram and power supply unit
May 08, 2008 | Microsoft Windows Vista Ultimate Edition
Screen stays black
Your inverter board is bad. It is time to change it.
This manual page 152 will show you what is involved.
http://h10032.www1.hp.com/ctg/Manual/c01035886.pdf
Mar 19, 2008 | HP Compaq Presario V6000T Notebook
Compaq Presario M2000 Notebook Logo
96 people viewed this question
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
