Question about Hardware & Accessories
Can't take apart an EMTEK entry set
I have a mortised entry set in my front door. When it was installed one of the two buttons on the side was depressed and this apparantly was the wrong one. If you unlock the door from the inside, it will not allow you to open the door from the outside. The way to fix this is to take the unit out of the door and reinstall it with the other button depressed.
My problem is that I can't get the exterior deadbolt plate off so that I can slide the unit out of the side of the door. I don't see any screws that hold it in place, and I feel like I am going to break it if I pry it off. Any ideas?
Thanks
  • thomas85249 Dec 27, 2008
    I have the same problem and I have no screws attaching from the back side. There is some king of side hole that seems to be the problem, but I can not seem to figure out how the exterior handle is attached and seemingly locked in place. Has anyone seen this before? If so, how do I take this apart - I think the spring is shot inside -
    Problem Solver:
  • 4 Answers
Hope I can help! I have worked with Emtek before and some of the front plates are secured with screws from the the other side of the door. You may want to check if this is the case. if so remove the screws so you can remove the exterior plate. Best of luck. Hope this works!
Posted on Dec 03, 2008
I am trying to replace a Kwikset 970 3cp Max security dead bolt. I have taken all the screws out but the lock will not come apart. Any suggestion?
Posted on Jun 07, 2009
How do you reset the alarm system on a 98 olds silhouette after it triggers without the remote entry
Theft Deterrent Arm/Disarm Modes
Important: Although mode 2 provides increased security, the content theft deterrent system disarms only by pressing unlock on the keyless entry transmitter. This can pose a problem if the keyless entry transmitter is damaged, lost, or inoperative for any reason while you attempt to disarm the content theft deterrent system.
Mode 1: The system arms when you lock the doors with the keyless entry transmitter. The system disarms when you unlock the left front, right front, or liftgate door with the key or the keyless entry transmitter. The system does not arm when you lock the doors with a power door lock switch.
Mode 2: The system arms when you lock the doors with the keyless entry transmitter. The system disarms when you unlock the doors with the keyless entry transmitter. The system does not disarm when you unlock the doors with the key.
Mode 3: The system arms when you lock the doors using a power door lock switch or the keyless entry transmitter. The system disarms when you unlock the left front, right front, or liftgate door with the key or the keyless entry transmitter.
Changing the Feature Customization Modes
  1. Turn off the IP dimmer switch.
  2. Turn the ignition switch to the LOCK position.
  3. Remove the BCM PRGRM fuse.
  4. Turn the ignition switch to the ACC position. The BCM flashes the fasten belts indicator and sounds the chime 4 times, which indicates that BCM type 4 is installed on the vehicle. At this point, the BCM has entered the feature customization mode.
  5. In order to change the theft deterrent/shock sensor mode, turn the headlamp switch from OFF to PARK and back to OFF.
  6. The BCM flashes the fasten belts indicator and sounds the chime a number of times equivalent to the theft deterrent/shock sensor mode. A transition past mode 4 repeats the sequence starting with mode 1.
  7. Complete the following steps in order to change the theft deterrent arm/disarm mode:
6.1.
Insert the key in the left front, right front, or liftgate door lock cylinder.
6.2.
Rotate the key from the center to the unlock position.
6.3.
Press the horn button on the remote keyless entry transmitter.
6.4.
Count the number of chimes that you hear. The number of chimes tells you which mode you have set.
6.5.
Press the horn button again in order to change the mode. Continue to press the button until you hear the number of chimes that indicates the mode that you want.
6.6.
Turn the key back to the center position and remove the key from the door key cylinder.
In order to exit and save the current feature customization modes use the following procedure:
  1. Turn the ignition switch to the LOCK position.
  2. Reinstall the BCM PRGRM fuse.
If you are unable to change locking modes Theft Deterrent System Feature Customization Inoperative
Aug 25, 2015 | Cars & Trucks
Tip
Sagging handle on Emtek door lock set
My front door has a very nice Emtek cast bronze door latch set with a deadbolt. a few months ago the inside handle started sagging so I looked on line and did not see what I thought the problem might be. At any rate it turned out to be super simple so I thought I would post the fix hear with pics.
I simply removed the interior side of the lock set and found that the spring that holds the lever handle up had slipped off its stop. I simply removed the lock washer that holds it in place, re positioned the spring behind the stop and it works great now.
I am not sure how the spring slipped off, as it is quite tight but I am sure it had something to do with two ten year old boys going in and out constantly ;-)
http://i.fixya.netwrite_tip-dpvo4qigktl0w3wlwtq4dsz2-3-1.jpg
on Sep 10, 2015 | Miscellaneous
How do I remove the doorknob to possibly oil it?
it would depend on the door knob construction and what was stiff inside it.
The problem could be part of the handle or part of the lock mechanism.
For a typical indoor door lever handle, undo the screws on the face plate and take the handle off and oil as appropriate. You may have oil handles on both sides of the door.
For a rotating door knob handle there is generally a single screw on the underside of the knob
For a lock mechanism, you could just spray oil inside the mortise moving part (you wouldn't have to dismantle anything to do this!).
However to dismantle it, you'll need to remove handles on both sides of the door, remove the square bar that slots between both handles and remove the lock mechanism (you may have to remove locating screws that exist on the mortise face. If lock mechanism is user serviceable then there will be screws to undo to allow it to be dismantled. If none exist then it is probably worth buying a new one.
Oct 16, 2014 | Hardware & Accessories
We have the thumb press elongated handle on the outside of the front door entry. I was ready to enter the front door when I pressed the thumb handle and the whole set fell apart. Need instructions to put...
For the Lido Keyed Entry, go to this page:
http://www.kwikset.com/Products/Details/Door-Levers/740LL-26D-SMT.aspx
and click on "Installation Guide", found under the red text " Technical Documents"
If I've steered you to the wrong lockset, the product main page foe Kwikset can be found here:
http://www.kwikset.com/Products/Categories/Handlesets.aspx
Feb 13, 2011 | Kwikset 4 Lido Lh Passage Levers Satin...
If I do not have the key, How do I remove the exterior door know on an emtek lock. I was able to remove the inside door knob with a set screw. I have a rectangular plate on the inside with no visible...
There should be a pin set on the outer knob as well. if not the inner knob after it has been removed should thread off, you may need to turn opposite thread.
Oct 02, 2010 | Top Knobs M826 Door Pull
I have an emtek key in knob lock and wont disasemble
The locks are tricky, they have special tools to make it easier, I'm not saying you can't do it, but if you can't get the knob apart, I don't know if you can get the pins in the tumbler right. Usually a pin hole in the side of the knob will release the keyset, then the ring in the back will release the tumbler, the cap on the top will release the pins, and I mean release, hang on to them, cause they fly! Put the tumbler back in without the pins, put the new key in, make sure it is right, drop the pins in one at a time, first the bottoms, they should all be the same size, then the tops will be according to the cut in the key. Or is it the other way around, drop in the springs, put the cover on, if it works the first time, you will be very lucky. Hope this helps.
Mar 20, 2010 | Top Knobs M826 Door Pull
I have an emtek exterior door lock, that is stuck in the locked position. I can only open it with a key, and not even the inside unlock mechanism will permanently unlock it. I took it apart as much as i...
If the opening is on the side, it probably comes off by pushing a small tool (pick or large paper clip) into the hole while turning the key. When you feel the pin move, pull on the knob and it should come off.
Nov 19, 2009 | Top Knobs M826 Door Pull
I would like to install a used mortise lock in an old door which has the cut out for a smaller mortise lock. I am hoping to use a power tool and not a chizel because the door is a 100 year old hard wood...
Can't think of a bit which will do what you want but you could stitch drill it to the desired size then chisel the holes square this should reduce any chance of cracking
Jun 29, 2009 | Eagle EKB-2020 Key-2020 Key Box w/ Mortise...
Baldwin 6321 mortise:when locked can open from either side
It sounds as if the lock is installed backwards or more specifically in inside mechanism. The inside lever/handle when turned should retract the deadbolt (safety feature). If yours does not currently switch around.
Feb 02, 2009 | Hardware & Accessories
Hardware & Accessories Logo
889 people viewed this question
Top Hardware & Accessories Experts
Gene Haynes
Craig Butler
Craig Butler
Are you a Hardware and Accessory Expert? Answer questions, earn points and help others
