Question about Hitachi 55FX48B 55" Rear Projection Television
Hot to converige
Ok i have a toshiba tz55v61 just replaced both IC and now the top left corner is the only thing out and that is the red
my lay out is like this
left to right
top 123
mid 4+6
btm 789
the "1" is what i am having a problem with the red will move left and right but not up and down all of the others are linded up correct.
when i 1st started to hook the board back up got all the wires put back in to place but i forgot to twist lock the 4 wired that look like spark plug wires back in and the red "1" jumped then i whent back and twist locked the spark plug wires things and this is where i ended up.
  • rob_jensen Nov 18, 2008
    sorry
    and thanks for all of the help to come
    Top Expert:
  • Hitachi Master
  • 75,169 Answers
  • 65 Answers
SOURCE: Hitachi 50FX20B 50 inch: Blue Convergence --will not adjust
You need to change convergence amplifiers. Should be no problem for a professional
Posted on Apr 09, 2009
  • 1039 Answers
SOURCE: 3 resistors and IC's replaced, still have convergence problem
Do you have B+ and B- voltages to the convrgence circuit? What is th Brand and Model and I can tell you where to look.
Posted on May 02, 2009
pilot210
  • 39 Answers
SOURCE: 43FWX20B. Convergence problem.
Look for hidden screws in the board... that's all I can say from experience. Plus, for the three red HV leads, Push down into the block and turn. This should release them if there is no other visible means of mechanical retention.
Posted on May 18, 2009
freetek
  • 5568 Answers
SOURCE: Hitachi Ultra Vision 61UWX10BB Will not power up Red led flashes
Your repair didn't address the failure. It is much more likely (in the absence of video and sound) that the power supply has failed.
The items you replaced affect convergence and have nothing to do with the audio section or the set's ability to receive signal. The power supply failure will diasable everything.
Look for a separate board with larger-than-average components, some cylindrical (capacitors), some block-shaped (chokes and transformers). And you may be able to recognize its relationship to the AC input line.
Locate the assembly number which may be on a paper label or just printed in ink on the board; any that appear to have been part of the etched traces will be only the empty board number, not the assembly.
Removing and replacing this assembly can be done by most everyone using a little common sense and just plugging in the connectors where they belong. Call your Hitachi service center and ask about potential repair or replacement costs. If you can score a new board, don't throw away the old one since the new board will be as crappy as the original. This way, you will have time and opportunity to find an independent reapir service for these and have a spare on hand for . . . sorry, the next failure. These things aren't 'your father's TV', they die much more often.
Posted on May 25, 2009
video-tek
  • 150 Answers
SOURCE: Hitachi 43fdx20 power supply removal to replace Convergence
Hi, doesn`t need to be removed and I strongly advise you to not remove them. That flyback is no longer for sale, if you break any of the tabs high voltage will leak and arc all over the place. the entire board assembly should be slid back towards you and then lifted straight up so your looking at the solder side of all the boards, unsolder the ic`s, r&r with new ic`s, be certain you use new heatsink compound on new ic`s or they will fail, questions? email me, gl, video-tek
Posted on Jun 02, 2009
How & where do you install stk392-180 for a toshiba tz55v61
You have two convergence amps that need to be replaced on the convergence board.This is a very common problem with these units.The part # are STK392-110 but I would upgrade to a STK392-120 or a STK392-150.Also there may be a couple of low ohm resistors that need replacing.Depending on your electronics experience this job is pretty much a straight forward soldering job that requires a certain amount of knowlege.These parts can be obtained from partsstore.com.I as a technician charge between$185.00 in shop and $250.00 inhome for this repair.It is well worth it as this particular chassis really did`nt hve very many problems, and once fixed you will have a like new picture.Good luck!!!
Dec 31, 2008 | JVC AV-56WP30 56" Rear Projection...
Toshiba 50H 71
Its recomended to replace both at the same time as each IC controls one color and half the green so when one goes out the gree tends to weaken the other. You can get them with free instructions at the following link.
http://servicemanuals.vstore.ca/
Jul 31, 2008 | Toshiba 50H71 50" Rear Projection...
Red line in top corner of screen
Sounds like an IC on the LCD panel went out of TV. Only thing to do is replace panel (it won't go away only get worse) It will probable be cheaper to just get another tv.
Apr 21, 2008 | Philips 42HF7444T 42 in. Plasma TV
Toshiba tv-model tz55v61
If the red,green and blue mixture adjustment is what you want...
remove front lower speaker grill & access panel..locate RGB
adjust on Screen / focus block.......slightly adjust screen controls for best mixture....do not adjust focus controls.....T.
Jan 10, 2008 | Toshiba TZ55V61 55" Rear Projection...
Toshiba TZ55V61
Hi, I`m assuming your saying the letters on the screen have different colors (red, blue, or green) shifted to the left or right?
If so try going into the menu and adjusting your "convergence"
adjustments, basically, move the red onto the green then move the blue onto the green and the bar turns white, if one or more of the colors doesn`t adjust either up/down or left/right then the convergence IC`s have failed, this will require removal of the board and unsoldering the old IC`s and installing and soldering in the new IC`s, questions? e-mail me back, BMW Rider
Jan 04, 2008 | Televison & Video
Toshiba 55" rear projection
Hi, convergence circuit has failed, the IC`s will have to be changed,possibly a couple of precision support resistors as well and the set will then need to be re-converged, More questions? feel free to ask away, Happy Holidays, BMW Rider
Dec 10, 2007 | Toshiba TZ55V61 55" Rear Projection...
Tosiba TZ55V61 Convergence IC 150?s vs 110?s
STK392-150 can be replacement for 110's no other resister values need to be changed, however be sure bad resisters are replaced and check all the resisters (6) have been taken out of circuit and checked. also check for solder cracks and cold solder joints.
Dec 02, 2007 | Toshiba TZ55V61 55" Rear Projection...
Toshiba TZ55V61 having prob. w/red,yellow lights
Convergence issue...replace STK392-110 IC's on small PCB
mounted by itself above power supply....................T.
Nov 08, 2007 | Toshiba TZ55V61 55" Rear Projection...
TZ-55V61 Convergence
Do you still need assistance?? The convergence IC's are always
on the largest heatsinks in set......have you replaced??....T.
Aug 22, 2006 | Toshiba TZ55V61 55" Rear Projection...
Televison & Video Logo
44 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
