Question about HP Pavilion dv6000z Notebook
Memory chip.. You answered my post about my screen turning black and blue light coming on.. Thanks by the way but I don't know how to change out my memory chip like you said to do...
  • fairie0025 Nov 18, 2008
    Thank you so much for helping. I guess I'll have to bring it in to get checked... Thanks again.
  • 93 Answers
You better ask anyone who knows little about computer to do this job for you if you don't know what memory chip look like or where can find them., because it risk to kills the laptop...
Posted on Nov 18, 2008
Have Gateway M6866 Laptop. Will not boot. when power button is pressed. you hear a fan start power light comes on, harddrive light and a few others comes on for 2 seconds then goes off. screen is always...
If it never posts anything to the screen then more than likely you've got a video card issue. It could be the memory also.
When you plug in the power cord is there any lightswhatsoever on the laptop, where the plug goes in or on the AC Adapter of thepower cord?
When you press the power button do you hear fans running, hard drive spinning,lights on the computer, hear any beeps or lights constantly blinking, hear theDvD/CD drive click and the light on the drawer of the DvD/CD turn on for asecond or two? If so the laptop is trying to boot or may have booted, butthe screen is not showing for some reason.
Beep tones and blinking lights tells the technicians what is going on with thelaptop and why it is not booting. Most times it's a motherboard issuewhen you hear beeps or blinking lights continuous. Most times the problemis with the memory or Video Card. Count the Blinking Lights or Beeps and takenote of their pattern (1 Long or 1 Long followed by 2 Short).
Maybe your power cord is bad if you don't get anything to happen whatsoeverwhen you press the power button. And if that's true maybe you wasoperating off the battery the last time you had it on and since the power cordis bad, it was not charging the battery so the battery is drained and the powercord is bad.
Maybe you have a Static Charge Buildup. Remove the Power Cord, Remove theBattery, then Press and Hold the power button for 30seconds. After 30 seconds plug the power cord back in (leave the batteryout) and hit the power button to see if it boots. If it does, you can putthe battery back in and let it charge.Maybe your DC Power Jack which is where the power cord plugsinto the computer is bad. Take an ink pen and push the tip inside thejack and see if the little pin wiggles, if so the jack is bad. You'll have totake the laptop apart to fix it. Most times it is soldered onto themotherboard, so you will have to desolder the old and solder a new one.Maybe your memory is bad or the memory slot is bad.Remove the Power Cord, Remove the Battery, Remove the cover that houses the memory on the bottom of the laptop then remove one of thememory chips. Set the chip aside then try rebooting the computer. If it boots, then you know the memory chip you set aside is bad so mark an x onit with an ink pen. If it fails to boot then move the chip to the nextmemory slot and try rebooting. If it fails take the chip out and set itaside, then put the other chip in and try booting it in both slots. If itboots, just to verify that the chip set aside is bad, mark an x on it and putit into the open memory chip slot and try booting.
May 24, 2012 | Gateway Computers & Internet
Black screen
Try running the check disk utility.
To run the check disk utility you will need a repair disc or a operating system disc. Put the disc in the cd drive and boot from it. You want to get to the Dos Command Prompt (Black screen with white letters) and type the following command: chkdsk /r
Check disk will run well over an hour or two and you will notice the percentages going from high to low, this is normal. Let it run to completion. Then reboot machine.
If check disk fails to solve your problem you might have to reinstall windows. Try doing a Repair Install that way you don't loose your data, documents, music, pictures, videos or programs.
In windows xp you get to the dos command prompt by selecting R for repair when the options appear.
In Vista and Windows 7 you want to get to the recovery console and look down at the bottom of the window for the Dos Command.
If check disk does not solve it try the steps below.
When you plug in the power cord is there any lights whatsoever on the laptop, where the plug goes in or on the AC Adapter of the power cord?
When you press the power button do you hear fans running, hard drive spinning, lights on the computer, hear any beeps or lights constantly blinking, hear the DvD/CD drive click and the light on the drawer of the DvD/CD turn on for a second or two? If so the laptop is trying to boot or may have booted, but the screen is not showing for some reason.
Beep tones and blinking lights tells the technicians what is going on with the laptop and why it is not booting. Most times it's a motherboard issue when you hear beeps or blinking lights continuous. Most times the problem is with the memory or Video Card. Count the Blinking Lights or Beeps and take note of their pattern (1 Long or 1 Long followed by 2 Short).
Maybe your power cord is bad if you don't get anything to happen whatsoever when you press the power button. And if that's true maybe you was operating off the battery the last time you had it on and since the power cord is bad, it was not charging the battery so the battery is drained and the power cord is bad.
Maybe you have a Static Charge Buildup. Remove the Power Cord, Remove the Battery, then Press and Hold the power button for 30 seconds. After 30 seconds plug the power cord back in (leave the battery out) and hit the power button to see if it boots. If it does, you can put the battery back in and let it charge.
If it is a laptop Maybe your DC Power Jack which is where the power cord plugs into the computer is bad. Take an ink pen and push the tip inside the jack and see if the little pin wiggles, if so the jack is bad. You'll have to take the laptop apart to fix it. Most times it is soldered onto the motherboard, so you will have to desolder the old and solder a new one.
Remove the Power Cord, (If Desktop Open the Case0 If Laptop Remove the Battery, Remove the cover that houses the memory on the bottom of the laptop)) and remove one of the memory chips. Set the chip aside then try rebooting the computer. If it boots, then you know the memory chip you set aside is bad so mark an x on it with an ink pen. If it fails to boot then move the chip to the next memory slot and try rebooting. If it fails take the chip out and set it aside, then put the other chip in and try booting it in both slots. If it boots, just to verify that the chip set aside is bad, mark an x on it and put it into the open memory chip slot and try booting.
May 23, 2012 | Compaq Computers & Internet
MY LAPTOP GOES TO THIS BLUE SCREEN THEN SHUTS DOWN WHY DOES IT DO THIS
Remove the Power Cord, Open the Case and remove one of thememory chips. Set the chip aside then try rebooting the computer. If it boots, then you know the memory chip you set aside is bad so mark an x onit with an ink pen. If it fails to boot then move the chip to the nextmemory slot and try rebooting. If it fails take the chip out and set itaside, then put the other chip in and try booting it in both slots. If itboots, just to verify that the chip set aside is bad, mark an x on it and putit into the open memory chip slot and try booting.
Apr 14, 2012 | Toshiba Computers & Internet
Error screen comes up after start up.
Must have been the guys in the blue shirts....Blue screen issues are normally caused by memory problems. If you are somewhat computer savy and know how to add or remove memory, try this. Take out one the memory chips, see if you get the blue screen any more. Then swap and do the same test on the other chip. If one has the issue and the other does not, replace the suspected bad chip.
Hope this helps.
p.s. If the computer is still under Samsungs warrenty (1year), contact them directly, you will have better luck with repairs than where you purchased the computer from.
Feb 23, 2012 | Samsung N145JP02 Netbook
I have a gateway tablet m285e. The problem is, it boots up to a black screen. F8 does nothing, trying to use a boot disk does nothing. I connected another monitor to it and still black screen. It does...
If you connect to external monitor and don`t work
Try:
1.- Remove the memory module and clean the gold connectors
reseat the memory.
If continue don`t show image
Disassembly the laptop
Remove the processor
and reseat again
If don`t work, is your Chipset video
Maybe you can try fix the chipset video
look solutions like
http://www.youtube.com/watch?v=BLNReuT67p8
apply heat to Chipset video.
Is important for people who share their knowledge, know your comments.
If the answer is helpful, rate my answers
Sep 22, 2011 | Gateway M285-E Notebook
Hi i have a hp pavillion dv1000 laptop and the problem it has is that i can turn it on (lights turn on, fan runs) but the screen stays black and also the light that is below the screen (between the screen...
all DVxxxx have graphic chip problem. to confirm to say others are OK, remove the RAMs and turn on.
you can here memory beep error.its says others are ok.
now you can repair the main board( re-flow the chip or replace the chip) or if not need to replace the main board.
Dec 06, 2010 | Computers & Internet
My Sansa e250 has hanged and only wheel light gets light is I restart the player....Plz help !!
Battery and Black screen Blue ring: Remove the back and check and see if the battery isn't fully connected
push softly but firmly on the Rubber rectangle above the battery (This is the Chip-set For the screen, and memory "Black screen Blue ring" ) and put the back on.
Jul 25, 2010 | SanDisk Sansa e250 MP3 Player
Screen goes blank and black
This can be due to many factors..
try the following steps..
1. Disconnect the battery and the ac adapter and hold down the power button for 2 Mins. This will drain the static.
2. reseat the memory chips..Its located at the back on the compartment that has an icon that looks line 2 square boxes beside each other. Try with one memory chip at a time.
also reseat the hard drive.
If it still does not work then you may have to get it repaired.
Hope this helps..
Regards,
Anup
Apr 07, 2009 | HP Pavilion Notebook
Screen goes black and SD-ms (memory card slot) light comes on..
Change the memory chip to another slot or swap two memory chips if you have two memory chips on both slots, see what happened and come back to me again.
Nov 17, 2008 | HP Pavilion dv1000 Notebook
HP Pavilion dv6000z Notebook Logo
18 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
