Question about Whirlpool Duet GHW9150P Front Load Washer
Duet washer rubber gasket replacement
Hi, I am a 50 year old woman attempting to replace this gasket. I thought I could do anything but I am stumped on how to get the door off and the front panel to be able to get to the clamp. It is a tight, dark, impossible squeeze. Do you have suggestions. I took the screws out of the hinge and the door stayed right were it was! Thanks, Julie
  • Whirlpool Master
  • 2,651 Answers
Ive never taken the front panel off, ill give you its tigth anbd dark, but the clamp inside is removed with a small ratchet( 9/32" is size), its definetly a little aawkward, to undo, adn even more to reattach, butit can be done with A LOT of patience
Posted on Nov 20, 2008
Replacing door gasket
Most door gaskets are available online, most recommended taking drum out to replace, but task can easily be done by removing rubber from hole in machine (end of a spoon helps) then push drum back through the hole and you will see a large clip on rubber to the drum, unscrew clip and pull out rubber, reverse to replace. Good luck.
Feb 19, 2014 | Whirlpool Duet GHW9150P Front Load Washer
Duet washer leaks during use; rinse cycle?
Check the water pump hose connections and the water pumps housing bolts themselves could have loosened from vibration. more likely the hose connections on the pump itself though. Hope this helps.
Feb 03, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Kenmore elite He3 leaking water into tub
Outstanding diagnosis. You are correct to assume a water inlet problem and, "yes", this can be a common problem. If you live in area that has hard water, or if you use well water, sediment, rust and calcified deposits can clog the small diaphragms inside the valve causing them not to close properly and leak by. You can attempt to clean the valve by removing it and submerging it in a 50/50 solution of distilled vinegar and hot water for about 30 minutes, Sometimes this can dissolve any clogs and restore the valve to full operate. However, if this does not work, you will need to replace the valve.
The following link explains the steps required to replace the valve if you need directions:
I have included web resources to search for replacement parts.
If you have any questions about this repair, please post back and let me know. I hope this helps you.
May 29, 2010 | Kenmore 3.8 cu. ft. HE3t Front Load Washer
Whirlpool duet dryer felt seal replacement
The drum may to be removed to install the new felt gasket but the old drum can then be reinstalled. The felt gasket seals the joint where the drum rotates at the inside back panel. It is likely that the inside back panel can be removed when the dryer is placed front-down and the outside back panel is removed. In that case the drum does not have to come out.
Jul 08, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Washer is ripping my clothes
yep, I have that problem too. My son's winter coat got wripped to shreds.
Apr 02, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Washer is leaking
Check the rubber bellow (gasket) around the door. This is the symptom of a door gasket that it starting to leak. Pull the rubber folds back and check the area where the gasket attaches to the wash tub. You may have a crack or tear. If the gasket is worn please replay back to this post and I can give you advice on how to replace it and where to get a replacement gasket.
May 14, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Mold? behind seal on whrilpool duet front load.
Run it a couple times on hot water with bleach in it. Should help. Also run through with dishwasher detergent in it. This helps clean too. I leave door ajar to allow air in washer. You can also purchase cleaner just for this at parts place.
Nov 17, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
171 people viewed this question
Dan Webster
Dan Webster
Sal De
