Question about Whirlpool Cabrio WTW6600SBT Top Load Washer
F 50 wont spin code F 50 whirlpool cabrio 2 years old do i fix or trash $$$$
  • sreknoy Dec 13, 2008
    I ignored this problem on several different occasions. It didn't completely stop working till now. I get the F 50 flashing and no spinning. It almost did once when we were trying but then stopped and flashed the F50 again. Is there any cost effective way to do this on our own or should be begin searching the classifieds for cheap ones to replace. Budgets are tight right now as everyone feels the pinch.
    Problem Solver:
  • 5 Answers
Ya the F 50 code. I'm getting it too. open the that top control piece by taking a quarter inch nut driver and there are 3 screws in the back. You need an ohmmeter to check the resistance on the motor and the rps sensor. If you dont know how to use an ohmmeter then u probably wont benifit from this. There are 3 wires yellow red and blue. You need to see what you get between those. it needs to be 16 ohms if it is not then the motor might be bad. also check the resistance on the 6 brown wires if there is none between the brown on each end of the harness then the rps might be bad. i would recommend doing that and then calling whirlpool 1-800-253-1301. Thats what im going to do. Im getting 30.6 ohms on the motor and none on the rps sensor. so i figure one of them is bad or both of them are bad.and if it costs over 150 to fix then i will probably recommend it a total loss.
Posted on Dec 21, 2008
My whirlpool cabrio washer wtw6200vwo shows f71code and wont spin out clothes
WHIRLPOOL CABRIO WASHER ERROR F71. The Cabrio Washer Error F71 code is the same as the SD code: This error means the main control board detects too much drag on the basket during the spin cycle.Mar 29, 2017
Nov 13, 2017 | Whirlpool Washing Machines
Ld code. It won't drain. Not the drain pump (I changed) and not clogged pipe.
Slow drain code. How high is the outlet pipe ABOVE the machine?
Jan 05, 2016 | Washing Machines
Changed door switch on my kenmore h2 plus cause of error code and it still wont work
Whirlpool & Kenmore Dryer Repair #01 - Won't Start or Run ...
? 8:50
https://www.youtube.com/watch?v=2WF71WdGn_g
Oct 19, 2011 - Uploaded by canyonman1963
This one deals with testing and replacing the door switch. ...sears wont work wont spin wont wash wont heat wont start fix repair bad noise noisy ... how to change a 4 to a 3 prong cord, to figuring out my door switch problem.
Dryer Door Switch - How To Replace - YouTube
What to do when your washer won't fill, start or run - YouTube
? 2:00
https://www.youtube.com/watch?v=Atd5YHbRh7M
Jun 20, 2012 - Uploaded by searspartsdirect
So if my washer wont start just call Sears. .... Bad sears mykenmore is only 2 years old, fill take 30 mins,,,wash 50 mins rinse never spin never,, ...
Nov 28, 2015 | Kenmore Washing Machines
Whirlpool cabrio loud noise
Check your bearings. This post will show you most of what you need to know about your bearings:
http://www.squidoo.com/how-to-replace-bearings-in-a-whirlpool-cabrio-maytag-bravo-or-kenmore-oasis
Nov 06, 2012 | Whirlpool Cabrio WTW6600SBT Top Load...
Whirlpool cabrio wtw5600xw0 will not spin
There is a spin sensor that is part of the shifter if this is wet it wont sense the spinning, hence wont spin, and if it is wet you mat need to replace the tub seal http://www.appliancepartspros.com/gearcase-motor-pump-parts-for-whirlpool-wtw5600xw0.html
May 29, 2012 | Whirlpool Cabrio Washing Machines
Whirlpool Cabrio F50 Error
Most likely the RPS sensor or the control board. Originally they had trouble with the RPS sensors.
Aug 25, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
F50 Error Code on Whirlpool Cabrio Washer
The F50 error code indicates that the RPS (rotor position sensor) detects no motor rotation. Check to see if the basket spins freely. If not, you could have an item caught between the outer tub and the inner spin basket. A toy or other item underneath the washer could also prevent the basket from spinning and would result in this F50 code.
If the basket spins freely, you could have a wiring failure that would prevent the motor from spinning.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question&&&&
Aug 23, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
F50 error code and Whirlpool Cabrio
this code would indicate rps sensor at motor. whirlpools are very bad with electronics and control boards. New rps sensor requires new harness as well.
Feb 21, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
it is the bearing, call 1800-905-9505 and ask for a service smart agreement cost about 200 and it will cover your washer for 1 year parts and labor and the machine will get fixed
Feb 14, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
CODE F 50
most likely connection to motor sensor on bottom.. just behind the motor rotor the connection is probably not making good contact with sensor connection
Jul 29, 2008 | Whirlpool WTW6600SW Top Load
Whirlpool Cabrio WTW6600SBT Top Load Washer Logo
193 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
