Question about Pioneer AVH-P7500 Car DVD Player
Pioneer avh p7500
Hi there i have a pioneer avh p7500 that doest want to work. all it does when i put power to it is (light up and the screen comes out) the screen doent light up and none of the buttons do anything. i have tried a reset but no luck. i brought it second had of someone i work with. i know it was working when it was in his car so im puzzled. not sure if there is a security code thats stoping it working. could you please help. thank you
  • 156 Answers
SOURCE: pioneer avh-p5700 dvd player
You can download installation and operation manuals at this link (free registration required):,,2076_310070347_192089338,00.html
Posted on Jun 04, 2007
Posted on May 05, 2008
SOURCE: pioneer AVH-P5000DVD
**** it
Posted on Aug 07, 2008
  • 64 Answers
SOURCE: pioneer AVH-P5700 instalation
You can find a wiring diagram for your 87 monte at You can refer to the installation manual for your deck at Since you are removing a shaft style radio and installing a DIN style you will need to perform extensive modifications to your dash. The Pioneer manual provides the dimensions.
Posted on Nov 25, 2008
  • 18 Answers
SOURCE: bypass ebrake with relay on a pioneer avh-p5700
Go to any auto parts store and purchase a four wire relay and wire it up as follows: The relay will have numbers written on the bottom for each pin. The wire from the parking brake from the H/U to 87. Ground to 85 and 30. Remote from the H/U to 86. This will give you an automatic bypass to the DVD lockout. If you want to just put a switch to do this manually you can also. Go to Radio Shack and buy a momentary push button switch, part number 275-1548. Take the green wire coming out of the unit. Strip the wire, and attach it to one of of the pins on the relay switch. It doesn't matter which one. Buy a standard 16 gauge wire from Radio Shack and connect it to the other pin on the switch, then connect the other end of it to a grounded connection on your vehicle. Now, when you play a DVD, the warning screen will come on. Just press the button on the switch and it will go away, since it tricks the receiver into thinking you have engaged the parking brake. Like someone said before, it is illegal in just about all states to have a dvd or other video playing if the driver can see it and the car is moving. This method is used because the lockout not only keeps you from seeing videos but also locks out some features which many feel have nothing to do with safety and they need it.
Posted on Jun 10, 2009
  • 69 Answers
SOURCE: install a pioneer AVH-P6800DVD
Here is a link to the manuals for this device:
1st manual is the installation manual, it is mislabled.
Posted on Feb 15, 2010
0 characters
1 Points
Player cannot detect mini disc and showing code error 22
I really rather doubt if this deck will play mini discs.
Apr 15, 2011 | Pioneer AVH-P7500 Car DVD Player
I have an avh-p7500/dvd and it wont power up... oh yeah i dont have the hideaway either. but i should still get power to the head unit no?
sorry, but it will not work with out the hideaway unit. the on/off switch itself is in the hideaway unit.
Mar 11, 2011 | Pioneer Car Video Players
My tv will not get a picture after the system was converted to digital,is there a solution to this. pioneer p7500dvd in dash m/fm,cd,cdrw,TV,DVD PLAYER.
There are a few companies now - like Pyle and Farenheit that make digital converter boxes for mobile applications.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Nov 25, 2009 | Pioneer AVH-P7500 Car DVD Player
Pioneer avh-p7500 switch live
i dont know too much about these, but what i do know is, most of these units have a small 1 amp continuous blow glass fuse inside the unit, i would have a look to see if yours has it, and also look for any signs of over-heating on the PCB
Aug 13, 2009 | Pioneer AVH-P7500 Car DVD Player
Screen says " cannot prform this function while driving"
Since your DVD player is newer, it has a safety feature that keeps it off when driving. Its better that way trust me. I have one and I watch DVD's while driving in Los Angeles traffic. Not a good thing. it is possible that you might have an option on the DVD menu to turn this safety feature off.
Feb 27, 2008 | Pioneer AVH-P7500 Car DVD Player
Still not allowing me to play my DVD's..???
simply connect the green wire to the ground of your systemt
Dec 31, 2007 | Pioneer AVH-P7500 Car DVD Player
Blank Screen
I had this problem. Your flex cable needs to be changed.
Jan 16, 2007 | Pioneer AVH-P7500 Car DVD Player
Pioneer AVH-P7500 Car DVD Player Logo
67 people viewed this question
Top Pioneer Car Video Players Experts
Craig Sagar
Level 1 Expert
Phil Sowers
Level 1 Expert
Are you a Pioneer Car Video Player Expert? Answer questions, earn points and help others
