Question about Toshiba gigabeat X20 (20 GB) MP3 Player
Problem with TOSHIBA gigabeat model MEGX30
I have a TOSHIBA gigabeat model MEGX30. When i turn it on it always show USB CONNCTED screen and i cannot turn it off. I've made sure that the device is not connected with Pc. It only turn off when the battery switch is off position. I've made sure that the hold button is slided to off. After 5-10 secs when i switched the battery switch on again and hold the power button for 2 secs. it turns on, then the date and time reset screen appears. But when i reset the date and time, it again showed theĀ USB CONNCTED screen. How do I fix this whole problem, turning it on?
  • Anonymous Dec 14, 2008
    lost my user manual and driver and have a new pc can any1 help me please
I have manual and driver for MEGX30. Let me know if you need it.
nenen9@yahoo.com
Posted on Apr 28, 2009
Everytime when i switch on my gigabeat f20, it shows this error.NO SYSTEM FOUND ON HDD. i've tried formating but once this error appears, you can't do anything. Sometimes it shows SYSTEM ERROR.
Hi theofrimp109,
This error usually happens when the firmware has been corrupted or deleted. The easiest way to correct this is by updating the firmware. You may also try to restore the firmware data by following the steps below.
1. Connect the gigabeat to your computer using a USB cable.
2. Start Explorer on the PC.
3. Open the folder in which the gigabeat room is installed.
--> The folder in which the gigabeat room is installed can be opened by clicking [Start] [All Programs] [TOSHIBA gigabeat room 2.0] [gigabeat room 2.0
Program Folder]. Usually, the folder will be found in C:\Program Files\TOSHIBA\gigabeat room 2.0.
4. If you can't find the folder, please go inside the gigabeat then click on [tools], [folder option], go to [view tab] then select [show hidden files and folders].
5. Now, inside the gigabeat root, copy a folder named "GBSYSTEM" located in the folder that was opened in Step 3.
6. Use "Safely Remove Hardware" and disconnect the gigabeat.
Hope it helps.
Thank you for using FixYa.
Jun 28, 2011 | Toshiba Gigabeat MEG-F20S MP3 Player
Toshiba Gigabeat-U MP3 Player suffering "USB ERROR #203"
try reinstalling any software that come with it.
try a different usb cable.
try different usb ports.
Jun 28, 2009 | Toshiba Gigabeat MEG201 MP3 Player
My toshiba MES60VK wont turn ON
I am having the same issues, any luck finding a solution?
Apr 15, 2008 | Toshiba gigabeat MES60VK Digital Media...
Toshiba Gigabeat 30gb
If you stored music on a hdd it should be safe. If all else fails, remove the hdd and connect via usb to a computer to retrieve the music.
Jul 03, 2017 | Toshiba Gigabeat MEG201 MP3 Player
Toshiba gigabeat MES60VK (60 GB) stopped working
There is a little battery cut of switch at the bottom of the device. You can unbend a paper clip and switch it off. Then switch it back on after a few seconds. Plug it back into the usb cable to charge it. It should work ok now.
Dec 26, 2007 | Toshiba gigabeat MES60VK Digital Media...
Toshiba Gigabeat Won't Turn on at all
how did you reset the battery? i kinda have the same problem. but i lost my wall charger. i moved the battery switch on and off about 5 times and still nothing. please let me know email @ atl6_98@yahoo.com
Aug 16, 2007 | Toshiba Gigabeat S30 MP3 Player
When you attempt to charge the player does they screen display the image of the charging plug? If not the battery may have died, in which case it needs to be replaced.
Jan 20, 2007 | Toshiba gigabeat X20 (20 GB) MP3 Player
309 people viewed this question
Top Toshiba Audio Players & Recorders Experts
Electro Med Services...
 Grubhead
Grubhead
Are you a Toshiba Audio Player and Recorder Expert? Answer questions, earn points and help others
