Question about Epiphone Dot Electric Guitar
Need to replace the amp jack nut, Epiphone Dot
Nut has stripped, internal part where the amp cable "jacks" into has fallen into bidy. I can retrieve but need thread size to retighten. Can you help.
BEn
  • alexis173829 Dec 04, 2008
    How did you retrieve it!?
    Problem Solver:
  • 14 Answers
Just take the guitar with you to a local guitar music store, where you'll have to go anyhow to get the part, and the store will be happy to repair it for
the price of the part.
Posted on Dec 13, 2008
Input jack fell inside
Yes, the jack MAY actually be broken. It will need to be serviced. Run cables through the handle to avoid plugs from being yanked sideways and breaking the jacks.
Aug 23, 2011 | Roland Cube-20x (20w 8" Modeling Guitar...
My Epiphone Dot just started humming really loudly when I plug it in - it stops humming when I touch the input jack. I assume it's a grounding issue on the input jack, but how do I get at...
Make you a hook out of a coat hanger. Get inside and hook the wiring to the jack, take the nut off the jack and pull it up through the F hole. You can plug in to it a patch cord so you can pull it back through once fixed. Check out Guitarelectronics.com for a wiring diagram.
Jul 03, 2011 | Epiphone Elitist Country Deluxe Hollow...
When I plug my lead into the jack input the guitar just makes a distorted noise a little like when you hold the end on a lead when plugged into an amp. I think maybe the jack inside has bent slightly...
If your unit has a battery, make sure you have fresh batteries. The jack ALSO serves to turn on the battery. If the jack is damaged or you use a TRS cable by mistake, the electronics will not be turned on and the sound will be very weak and distorted.
May 07, 2011 | Epiphone DOT Deluxe Flametop Semi...
Guitar cable was under the amp, i picked up the guitar and it pulled the jack. it picks up static but not sound
The cable has a broken wire. If it's the type cable which allows unscrewing the jack, take it apart and look for a loose / broken connection. Repair would be to solder it back. If the jacks on the cord are the molded type, the most practical solution is to replace it.
Charlie
Feb 21, 2011 | Epiphone Les Paul 100 Electric Guitar
My input jack's nut has came loose and it fell into the amp. HELP
Open the unit and restore the jack to the proper place. Do NOT overtighten the input jack mounting nut.
Feb 01, 2011 | Marshall Amplification Marshall MG15 15...
The hexagon nut came loose for the Guitar -CD/MP3 input from my son's Spider 3 (75) amplifyer. Where can I find a hexagon nut?
Those can be a pain to find. Some are Metric which worsens the problem. There are several types as well. I would first try Radio Shack where they have the drawers of jacks, etc. Those ore probably English thread...
The BEST source would be to search the DIGIKEY.com website for a jack that has the identical nut... the jacks are NOT expensive... under $2. Finding just the nut alone unless a repair shop for amps happens to have one laying around will be near impossible. It is worth trying that source however because USUALLY the jack inside is broken.
Dec 06, 2010 | Line 6 Spider Iii 75 Guitar Combo...
No sound when I put in the jack. You just hear a little bit distortion.
First check the cable. If that works fine on another instrument then i would check the input jack next. Also try turning the volume knobs. You may have a dead spot on the potentiometer.
Apr 04, 2010 | Epiphone Les Paul 100 Electric Guitar
Plug-in jack fell inside body
Try to see if you can fish one of the wires attached to the jack out enough to get the jack through the F hole. If you can get to the jack, get some medical tubing ( like they use in sling shots for example ) that will fit inside a jack. Stick the medical tubing through the guitar starting at the outside of the hole the jack is supposed to be in. Once you can fish the end of the tubing out through the Fhole, insert it into the jack and gently and carefully manuever the jack back into position by pulling on the other end of the tubing. You should be able to slide the washer and then the nut down over the tubing until you can thread them back into -place. Hope this helps.
Oct 22, 2009 | Epiphone Dot Electric Guitar
Getting Static noise when plugged in to amp
This is a very common problem that I have repaired for many friends. Sometimes the guitar jack becomes loose and gets rotated to the point where the wire breaks and/or touches the cord plug when it's inserted into the jack. You need to remove the access plate/panel at the back of the guitar body and see if the wire is broke or twisted. You may only have to loosen the jack retaining nut and rotate the jack to get the twist out or you may have to remove the jack and resolder the wire back in place. If its broke make sure to solder back on the proper terminal--the one with solder already on it and not the one that the cord plug touches when its inserted. Retighten the jack nut by firmly holding the jack from access side so it doesn't rotate again and cause that undesirable STATIC sound. Hope this helps.
Dec 08, 2008 | Epiphone Les Paul Studio Electric Guitar
Problem with the pickup sound on the 'g' string on my epiphone les paul standard
Hi ! Must be a problem with either the nut or the g-saddle in the bridge of the guitar.
Good luck , Stefan from Sweden
Nov 10, 2008 | Epiphone Music
Epiphone Dot Electric Guitar Logo
1,200 people viewed this question
Top Epiphone Music Experts
Michial Gueffroy
Craig Butler
Craig Butler
Vito Vacirca Jr.
Are you an Epiphone Music Expert? Answer questions, earn points and help others
