Question about Kenmore 53642 / 53644 Side by Side Refrigerator
My Kenmore water dispenser just stopped working today? Need help!
Hi Guys,
My name is Kelvin D. Cox. I live in Lakewood, CA. I own a Kenmore Stainless Steel Refrigerator for about 4 yrs. I notice my water dispenser just stopped working this morning. I use my water dispenser on (11.16.2008) and everything was working fine. And my icemaker works perfect. What caused my water dispenser to stop working, and "how do I fix it???" Please HELP!!!
Thanks.
Kelvin D. Cox
  • Anonymous Nov 18, 2008
    water keeps up freezer side very cold frig side warm
  • Harvey Butler Dec 01, 2008
    My water dispenser started taking several seconds to dispense water. The duration got longer and longer, now it won't work at all. The ice dispenser is working fine.
  • 100 Answers
SOURCE: Kenmore Refrigerator stopped dispensing water
Either your water tank in the fridge froze up, the waterline that goes up the freezer door from the bottom hinge froze, or the switch that your glass hits is damaged. Do you hear any humming or noises when you put your glass up to get water?
Posted on Oct 30, 2007
  • 27 Answers
SOURCE: Interior Water dispenser not working
Hi . Its good to know the Make and Model number of your refrigerators when you ask for a solution. Each manufactures have their own design flaws that create operating problems. IF YOUR WATER LINE TO YOUR WATER DRINK DISPENSER KEEPS FREEZING AND ADJUSTING THE REFRIGERATOR TEMPERATURE A LITTLE WARMER DOESN'T HELP, THEN YOUR DAMPER BETWEEN YOUR FREEZER AND REFRIGERATOR COMPARTMENT IS LEAKING AIR IN THE CLOSED POSITION. THIS IS COMMON FOR MAYTAG, WHIRLPOOL AND SOME KENMORE. THIS CONDITION NORMALLY REQUIRES THE REPLACEMENT OF THE DAMPER ASSEMBLY, BUT SOME ARE CAUSED BY AIR LEAKING AROUND THE ASSEMBLY AND CAN BE SEALED WITH A PLUMBERS PUTTY. DON'T CAULK IT. YOU WANT TO BE ABLE TO REMOVE THE DAMPER IF NECCESSARY. IF YOU HAVE AN LG REFRIGERATOR, YOUR DAMPER COULD BE THE PROBLEM OR YOUR FREEZER TEMPERATURE MAY BE RUNNING TOO COLD. THEY HAVE BEEN KNOWN TO RUN BELOW ZERO DEGREES INTO THE NEGATIVE TEMPERATURES. THIS CAUSES THE STORAGE BINS AND WATER LINE TO FREEZE. A COMMOM MANUFACTURES MISTAKE IS WHEN THEY BUILT THIS REFRIGERATOR, THEY FORGOT TO PULL THE COMPARTMENT TEMPERATURE SENSORS OUT FROM THE FOAM OF THE REFRIGERATOR CABINET. THIS MAKES YOUR REFRIGERATOR KEEP RUNNING. IF YOU TAKE THE LITTLE COVER OFF YOU WILL SEE IF THE END OF THE SENSOR IS INSIDE THE COVER HOUSING OR STILL UP IN THE FOAM. BE VERY CAREFULL REMOVING IT FROM THE FOAM BECAUSE THE WIRES ARE THIN AND SHORT. TRY TO PIVOT THE TIP OUT ONLY. YOU DON'T HAVE TO HAVE IT ALL THE WAY OUT AS LONG AS THE END IS NOW INSIDE THE SENSOR COVER. THESE COVERS ARE LOCATED INSIDE ON THE TOP AROUND THE MIDDLE AREA. CHECK ME OUT ON EBAY AS USERNAME themackshack. GOOD LUCK! MACK
Posted on Feb 03, 2008
refritech08
  • 149 Answers
SOURCE: Kenmore 106.53542300 is running non-stop
I supect a stuck thermostat. its the only thing to make it run non-stop also check the door seals wipe them down if they look dirty
Posted on Oct 03, 2008
  • 135 Answers
SOURCE: The ice maker stopped working on my Kenmore Mod 106.55532400
either your water valve is clogged or it has gone bad, located bottom right corner, you can take it apart and check the screen filter if it is not clogged than you need a new valve approx 72-80$ plus install unless you diy!
Posted on Nov 29, 2008
SOURCE: kenmore elite water dispenser not working
We had the same problem after 4 months. A technician came out and told us that our water line within the refridgerator was frozen and that every once in a while we'd have to take a hair dryer to it (!). Of course we told him that was unacceptable so they sent a second tech out who replaced some parts by being walked through the repair over his cell phone. He was unable to tell us what happened or details about the repair. 11 months later our water line froze again and we resorted to a Brita water pitcher.
Posted on Aug 13, 2009
Water dispenser not working on kenmore trio refrigerator
The tubing inside the door is most likely frozen. Mine did that a year ago. I had to remove gasket and loosen screws around edge and allow to defrost inside door. There was a lot of ice around dispenser and tubing.
Sep 16, 2012 | Kenmore TRIO® 77553 Stainless Steel Bottom...
Our fridge is rusted underneath the water dispenser it is a kenmore purchased at Sears July 2003, the rust began 2 years ago, in a small spot of which was not too noticeable, now it's ridiculous and...
Hi!!
Sand down the rust, clean the area around it and apply a couple of coats of Appliance Paint of the same color, the more coats you apply, the better protection against rust you'll have. You can find that paint at any HomeDepot or most Hardware Stores. They have it in spray can and nail polish size to apply with a tiny brush.
Don't forget to rate this post!!
Sep 16, 2010 | Kenmore Refrigerators
Ice dispenser not working water does
I need help in solving this problem. The ice dispenser is not working but I still get water. Thank you please let me know what to do.
Aug 11, 2009 | Kenmore 57029 Side by Side Refrigerator
Kenmore side by side water dispenser has stopped
Most likely need to replace the water inlet valve. The water supply line should be directly connected to it. There are 2 valves bracketed together, 1 for the ice maker and 1 for the water dispencer. You will probably have to buy both valves, but want to do this anyway as the second valve will fail soon. Hope this helps.
Jun 14, 2009 | Refrigerators
Internal water dispenser stopped working
I lowered the temp on the freezer to 4 overnight, by morning water dispenser is working fine. I think that when we changed the temp to 7 (in order to make more ice ) it froze the water pipe going to the dispenser. I am going to keep both fridge and freezer at 5 ,and hope this will not happen again.
Dec 31, 2008 | Amana AFD2535FES Stainless Steel Bottom...
Dishwasher leaves soap in dispenser.
Hi Dirty Dish gang.
After having 2 appliance repairmen here, I now have the latest scoop on our dishwasher problems, $200 later!
Los Angeles IS currently having hard water issues. Also, all the new cleaning gels etc. are actually a cause of our dishwasher problems.
So, here is what we need to do:
1. Use Cascade POWDER detergent only.  Make sure is is just "plain" no "scented" or "complete"  or gel, etc. (I have tried a phosphate free powder and gel and this is a cause of our problem as well!) 2. Use Jet Dry in the dispenser (set it to a 2-3 opening) 3. Make sure water is at least 120 degrees 4. Only run dishwasher on "normal" setting.  All others just run it longer, hence causing more water stains. 5. Do not pre-wash dishes! You can knock of chunks with a "non" soapy brush, but don't rinse (the oils actually help to clean the dishes) 6.  Do not wash sponges in dishwasher.
Acid Wash: The repairman just gave my washer an Acid Wash today. It says it is an acid derived from lemon, I got mine from Carters appliance in Torrance, CA for about $19. I am to run a normal cycle with the above mentioned Cascade after this "acid cycle" is finished.
If you are still having problems:
Monthly maintenance: Glass Magic: Buy a box of Glass Magic (near the Cascade)  Use 1 Tbsb in main detergent compartment of dishwasher along with the Cascade, till washer starts working again. White Vinegar: You can run an empty dishwasher with white vinegar once a month.  Fill a bowl with 2 cups vinegar and place on bottom rack.  Then run as a normal cycle...this allows vinegar to disperse slowly.
So far it seems to be working.  Good luck.
Nov 07, 2008 | Kenmore 24 in. 16032 Built-in Dishwasher
Amana Side by side refridgerator Model SBD20TPE P1190006WE
hi
one question : are the units under warranty ?
if not its pretty easy to swap the dispenser paddles and the membranes
infact i have been using this site for many years and have found it helpful: : www.howstuffworks.com
thanks
May 04, 2008 | Amana ACD2232HR Side by Side Refrigerator
GE Water not working
You may have a frozen water dispenser tube inside the freezer door. You need a GE Water Dispenser Tube Heater Kit, part number WR49X10173.
Apr 10, 2008 | GE GSS25SGSSS Stainless Steel Side by Side...
The water dispenser in my frig stopped working but it still makes lots of ice. I replaced the filter on 29 Dec 2007. I normally get 6 months out of a filter.
We had same problem! The water line gets frozen in the door, and there is no way to get to it. But, I took some 14 gauge electrical wire and would get one end hot by putting it under hot water, then put that end up the water line in the door. This might take several attempts, but it will work. A little piece of ice about 2 inches long will come out.
Mar 05, 2008 | GE CleanSteel GSL25JFTBS
if you have not yet used it you will need to bleed the air out of the tank in the refrigerator hold the button in for a few mins to flush this out
Jan 23, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Kenmore 53642 / 53644 Side by Side Refrigerator Logo
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
acrman404a
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
