Yamaha DVR-S120 DVD Player Logo
Posted on Nov 18, 2008
Where do you get the speaker connectors and wires
This unit was a hand-me-down, which was great. Unforturnately, the speaker wires were not included. I have searched far and wide, and have failed to find this part.
  • 1 more comment
  • mikeendo Mar 08, 2009
    I found the connectors on ebay.
  • Anonymous Jan 05, 2017
    Try HT-SpeakerCables.com
    You can find all of the hard to find speaker connectors at HT-SpeakerCables.com Forget about ebay, they always sell you the wrong size!
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Jan 24, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
6815
Points
10
As an alternative cheap solution, if you have the following available you can do as I've done.
I used an old burnt out ATX power supply 24pin motherboard connector, cut all the wires of about 10 inches and then cross sliced the connector up into 2pin connector pieces. Worked perfect, saved me $ and made some great recycling use of an otherwise useless PSU.
  • R0BUK Oct 24, 2010
    BRILLIANT! Thank you!
    Rob. UK
Anonymous
Level 1:
  • Posted on Nov 26, 2008
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
6815
Points
You can buy original from here http://www.chsinteractive.co.uk/electrical-components/misc/dvrs120-cable-speaker-set-yam.htm but they are very expensive also they are available from the states (via ebay) cheaper but the shipping is really expensive (more than the cables) there is also an ebay seller selling non original universal connectors for about £15 inc shipping they look like they will fit ok ........ search ebay using this ;
6 SAMSUNG SONY 4,2mm HOME THEATER SPEAKER CONNECTORSor for original connectors try this ;
Sony Samsung Yamaha Toshiba Speaker Connectors Wires
Hope this helps ..... Tim
Anonymous
Level 1:
  • Contributor 24 Answers
  • Posted on Jul 22, 2009
Anonymous
Contributor
Level 1:
Answers
24
Questions
0
Helped
32796
Points
54
My name is Gary and I work for the Bogue Engineering Company and we sell those hard to find speaker connectors for HT systems. Please goto www.BogueEngineering.com and you will find exactly what you are looking for. Thanks, Gary
My panasonic says f61 when i switch it on wat do i do
An F61 error occurs on a Panasonic home theater system when the speaker cable wire connections are wrong. This situation is likely to happen if you just purchased your unit or moved the system and try to reconnect the speakers again. Polarity is key in a successful setup. The positive and negative ends of the cable wires must match the input of the main unit. Retrace your speaker wire connections to clear error F61.
Step 1 Attach the speaker labels to the speaker wires for easier identification, if they're not already labeled. At minimum, labels for front left (L), front right (R) and center speakers should be included in the packaging contents that came with your system.
Step 2 Verify that the white ends of each speaker cable are connected to the corresponding "+" positive inputs for each speaker.
Step 3 Verify that the blue ends of each speaker cable are connected to the corresponding "-" negative inputs for each speaker.
Step 4 Push the plastic ends of the speaker wires on each speaker to verify that each is locked into place.
Step 5 Connect the remaining end of the "Front (L)" speaker wire to the white terminal/connector on the main unit.
Step 6 Connect the remaining end of the "Front (R)" speaker wire to the red terminal/connector on the main unit.
Step 7 Connect the remaining end of the "Center" speaker wire to the green terminal/connector on the main unit.
Step 8 Connect the remaining end of the "Subwoofer" wire to the purple terminal/connector on the main unit.
Step 9 Connect the remaining ends of the "Surround (R)" and "Surround (L)" speakers to the wireless system.
REAR door speakers dont work in 98 gmc c1500 suburan
Hi, generally when you a buy a car, the steroe and speakers are all stock fitted, if bought second hand, they may have been upgraded.
Down to your speakers, check connectors behind the steroe unit, should be 2 plugs, one for power with red, black, yellow and blue wires, and the other plug is your speakers. Check there is 8 wires into the plug.
If all is correct then check the rear of your speakers, check the connection and that the wire isnt loose.
If all is fine there must be a wire break somewhere, your stereo presets are only set to the front speakers (fade setting).
Hope this helps
1helpful
3answers
Protect mode jvc
The protect mode is activated when it senses a short in the audio outputs in the stereo. Turn volume down, power off, and remove speaker wires from the back, next power on, if the protect comes on the audio output ic is shorted, if on the other hand it runs, check speaker wires for shorts and then hook up one at a time to find the fault including the speaker.
2helpful
How can I detach the speakers from my philips wac700
Lay your unit face down on something soft like a towel maybe.
Remove the stand, which had a small tongue that you'll need to depress.
Hold the centre segment firmly at the top and then with the heel of your hand, give the base of whichever speaker a few firm thumps upward. (This takes quite a bit of force!)
The speaker are attached via 'mushroom' pegs into a rubber-lined hole which opens to a slot, so you're trying to push them upward until the pegs are in the hole instead of the slot and they will then just pull out.
WARNING: There is not a great deal of play in the speaker connector wiring so be careful once the speaker is free!
4helpful
3answers
I was given a Sharp HT-DP3000 reciever and all the speakers that go with it.. but I don't know how plug in the speakers into the wire there is a box for the two surround and a separate box for the right...
Do you have speaker wire if not you will need some, the wire is cheap about $5 bucks a roll your local department store will have it. You see a red and black tabs on the back of the unit and on the back of each speakers you push down and stick one wire in the hole. red will be your + and black will be - The two surround go on the back wall behind your seat.The center will sit on top of TV and the sattalite speakes go beside the left and right side of TV. and the sub sits on the floor in hidding behind something or under a table. (P.S, Make sure the wire is shaved about 1/4 of inch before you stick in the wire DO NOT plug the power cord in, intill you hook up all the speakers this could damage the unit. You do not need a sub woofer, if you have one great If not don't worry that will not damage the unit it has a internal switch to turn on/off the sub woofer The sub woofer offers extra deep bass that you can't get from the sattalite speakers.)
Head Unit of boat stereo cutting out at higher volume
check your ground wire ..
then check battery has enough charge..
usually fault is in where your stereo is connected to your ground source.. good luck ,if no luck try your checking your speaker wires for a short..
2answers
Radio wiring
The factory wiring connector hook-up for the Mustang is:
Radio / Power Connector:
Light Green / Yellow - Hot at all times (Fuse 8)
Yellow / Black - Hot in ACC or Run (Fuse 11)
Light Brown / Red - Goes to instrument panel dimming rheostat (Fuse 4)
Red - Ground
White / Purple - Hot in ACC or Run (Fuse 11)
Speaker Connector:
White / Light Green - (+) Right Instrument Panel & Door Speaker
Dark Green / Orange - (-) Right Instrument Panel & Door Speaker
Brown / Pink - (+) Right Rear Speaker
Pink / Light Brown - (-) Right Rear Speaker
Pink / Light Green - (+) Left Rear Speaker
Tan / Yellow - (-) Left Rear Speaker
Light Brown / White - (+) Left Instrument Panel & Door Speaker
Orange / Light Green - (-) Left Instrument Panel & Door Speaker
Your best bet is to buy a radio install kit and adapt it to the Mustang connector. Hope this information helps.
2helpful
Broken D-sub cable
I would advise against a direct solder inside the unit. I would go and purchase a replacement connector from a Radio Shack or other electronics parts store. Solder wires to this, then plug in, should fix problem.
60helpful
8answers
Bose Cube Speakers separated
Ok…
I had the same problem with a Bose separated double-cube Acoustimass speaker/array but was able to fix it as follows:
Tools:
small, thin, flat-head screwdriver
large pliers
C-clamp
Instructions:
1. Disconnect the speaker wires from the cube.
2. Remove the grille from the top speaker cube. It just pops off.
3. Insert a small, thin, flat-head screwdriver around the perimeter of the speaker. You will have to pry lightly to break the glue’s seal.
4. Using a set of pliers (large, plumber-sized) wiggle the speaker until it comes free. You might need to grip it top to bottom and then left to right. The speaker will come free of the case.
5. Remove the white insulation to get a clear view of the dislodged brace/connector.
6. Stack the top and bottom cubes. Make sure that the rubber seal between the cubes is seated properly and that the black and white cables are not pinched.
7. Using the C-clamp, compress the brace/connector until it seats on one side. Loosen the C-clamp and compress the opposite side. The brace/connector should snap into place. Be sure the make sure that you do not pinch the speak wires that are running through the center of the brace/connector.
8. Test the articulation. It should be the same as your other speakers.
9. Replace the white insulation in the back of the speaker case.
10. Press the speaker into the case’s face. If you wish, you can apply your preference of glue to the edge of the speaker prior to pressing it into the case.
11. Snap the grille onto the speaker.
12. Connect the speaker wires to the cube and you are done.
You should be good to go.
10helpful
2answers
Manual
Yellow - +12V Constant Power Red - +12V Switched (accessory) Power Blue - Power Antenna Blue/White - Amp Turn-on White - Left Front Positive Speaker Wire (LF+) White/Black - (LF-) Gray - Right Front Positive Speaker Wire (RF+) Gray/Black - (RF-) Green - Right Rear Positive Speaker Wire (RR+) Green/Black - (RR-) Purple - Left Rear Positive Speaker Wire (LR+) Purple/Black - (LR-)
Top Yamaha Televison & Video Experts
 Grubhead
Grubhead
Grand Canyon Tech
Grand Canyon Tech
Are you a Yamaha Televison and Video Expert? Answer questions, earn points and help others
