Question about Grilling
Trying to find a manifold for a weber genesis 3000. weber does not stock it. any suggestions? I have a Genesis 1000 Weber says that they have very few manifolds available and they have now told me I have to wait 20 working days. Only one valve sticks and I asked if I could use WD-40. I was told that it was dangerous and needed to be replaced. Problem of course is that Weber has none in stock.
  • 63 Answers
SOURCE: low/weak flame on Weber Genesis Silver B Grill.
hi my name is mark, could be one of two things the regulator on the propane tank try gently tapping on regulator it could be sticking, and make sure the vent on regulator does not have a spiders web . or the orifices to the burners are restricted. check regulator some are ajustable, some are not. hope that helps. thanks for your question.
Posted on Mar 14, 2009
  • 512 Answers
SOURCE: Weber Silver Genesis C regulator purging gas after reset process
This could be caused by a couple of problems. First the regulator could be bad, or the tank is getting to hot. Which causes the relief valve to open and release pressure. This will happen when weather outside is hot.
Posted on Jun 17, 2009
venexcsd
  • 1185 Answers
SOURCE: Weber Genesis outdoor grill. The ignitor clicks
If you hold down the igniter can you smell the gas coming out of the burners.
Have you disconnected the pipe from the barbie to see if the bottle regulator is actually letting gas through.
Turning the gas on in free air with no one smoking or naked fllames near the pipe is ok
You just crack open the valve a turn or two and you should hear and smell it.
If there is gas coming out og the pipe and not out of the burners then the gas control valve in the barbie is at fault and needs replacing
Posted on Jun 27, 2009
  • 138 Answers
SOURCE: Have a Weber Genesis Silver. Gas is not flowing.
take off the grate[s] and the plate that covers the burner, find where the gas supply goes into the burner - use a compressed air source with a nozzle and blow out the burner and orifice - spiders and sometimes mud daubers love little spaces like this and will build a nest in 'em - even the slightest restriction will cause major headaches
Posted on Aug 16, 2009
  • 332 Answers
SOURCE: my weber genesis wont stay lit. i can light the
The new style2_bing.gif OPD valves have a small brass ring located in the female fitting on the LP tank. Over time this ring can work loose and then it does not allow the male fitting to fully depress the OPD valve thus reducing your gas flow
Using a small flat bladed screw driver tighten the small brass ring This should solve your problem
IF not you might want to remove the cap (white) on your regulator and try slowly adjusting the regulator, make small adjustments and try the BBQ My Weber if I set the front and back burners to MED I get right at 350 degrees in 60 degree outdoor temps. Adjusting the regulator will take some time to get it right but If it is not your tank it is most likely your regulator out of adjustment
Posted on Mar 31, 2010
Weber genesis silver B won't get hotter than 450
Yes diaphram could be split causing vent to pass gas .
Aug 08, 2012 | Weber Genesis Silver B Grill
Weber genesis
i would say you have a fulty regulator to save your self sone money
rather than buy name brand you can find them on other sites
i hope this helps you
May 24, 2012 | Weber Genesis Silver B Grill
I have been given a weber genesis silver barbecue with no manual on how to use it
There are several models of your grill depending on which years(s) it was manufactured. All are similar, but have different options. The link below is to the Silver B manufactured between 2002 & 2006.
http://help.weber.com/manuals/pdf_files_2011/Gas/Genesis%20SilverGoldPlatinum/GenesisSilverB%20OwnersGuides/Genesis_SilverB_LP_PremWswe_OwnersGuide_55259_050602.pdf
I hope this helps you and Happy Grilling!! Thanks for choosing FixYa.
Aug 08, 2011 | Weber Genesis Silver B Grill
I need to convert my weber genesis b to nat. gas. Have the hose. bought a replacement manifold part and installed but doesnt seem to work. STEVE 269-600-8111
Steve, you also need to change the burner(s) orifices to Natural Gas orifices. Natural gas won't work with Propane orifices.
Good luck and Happy Grilling!!
May 14, 2011 | Weber Genesis Silver B Grill
Bought a weber genesis 320 Problem with the Weber Genesis E-320 Propane Grill bought a weber genesis 320 in US and need to replace the hose / regulator that it fits to German LP gas cylinders. Which...
Normally, at least on an American grill hose/regulator assembly are a universal fit. And both ends of the hose have female couplings. I would think it would be the same on German Models too. For the connection to the grill, the hose coupling size is 3/8" ID.
May 08, 2011 | Weber Genesis E-320 Propane Grill
I need to convert my Weber Genesis Silver B grill from Natural gas(NG) to Propane (LP). It is as simple as replacing the NG manifold and valve assemble with the NG one BUT Weber wont sell it to me...
I would contact a propane distributor, They should be able to locate the part. I don't know where your at but the one in my area (Central Oregon is Ed Staub and Sons )
Nov 22, 2010 | Weber Genesis Silver B Grill
Kit for converting weber genesis silver c to natural gas
Some grills do not have conversion kits, if your grill is labeled as dual fuel you can contact weber and get a kit for it.
Dec 31, 2009 | Weber Genesis Silver C Grill
Jun 27, 2009 | Weber Genesis Silver B Grill
Weber Genesis Gas Valve will not turn
If the valve is stuck and wont budge, the only real solution is to have is replaced. Unfortunitly, Weber does not sell the valves separately and you would have to replace the entire manifold. Before going out to buy the parts, call Weber to see if your still under any warranty, even if your not they still sometimes send parts at no charge.
Feb 14, 2009 | Weber Genesis Silver B Grill
I have weber genesis 3 burner proppane grill. i switched it to nat.gas when it was new.the hottest it will get is 340 with all burners on high.
When you switched it out did you contact www.weber.com
to see if this can be done on this grill. Weber is different than a lot of other grills usually their larger models they can be converted but their smaller models can not. This might be something you need to check with the company.
I know with Weber that it doesn't consist of change out the hose and a orifice they also change out the manifold.. So please check with Weber for these answers.
Thank you,
Fireplace-girl
Apr 24, 2008 | Weber Genesis Silver C Grill
Grilling Logo
161 people viewed this question
Top Grilling Experts
Paul Carew
Gary Kenady
Gary Kenady
Marvin
Marvin
Are you a Grilling Expert? Answer questions, earn points and help others
