Question about Delphi MyFi SA10113 XM Radio Receiver with Home and Car Kit
My screen is blank...
Everythign seems to working on my device but there isn't anything on the screen. The light is on but no station information, no channel listings, etc. I can change the channel but I have to hope I typed it right because I'm operating blind. And I can't figure out who's singing! Please let me know what you think the deal is. Thanks...
  • 2 more comments
  • jan43 Dec 22, 2007
    Unit powers on and the screen lights up. I can change channels but can't see what channel is playing or anything else, Do not know how to resolve this problem.Can anyone help?
    Thanks
  • rtchewning Jan 09, 2008
    Screen Blank... Same issue as well... Unit powers on but only a back lighted screen with no information displayed. This happened once before when I first got the radio and after replacing the battery (battery recal) it started working again for some reason... Now it has gone out again... any help would be great for those that may have fixed this issue.
  • bluejean Mar 19, 2008
    The unit will turn on but screen is blank. I can change the channel with the remote but I can't see what channel I'm on. I've tried removing the battery and resetting the unit but no result. HELP! I'm traveling next week and I'm lost without it.
  • Anonymous Nov 16, 2008
    When in house my signal is fine, but outside walking or in the car the scrren is blank and there is not a signal.
    Also, do you know where I can take MyFi to get fixed?"
    Rose K
I emailed Delphi the other day about repair centers. They believe that service will be available soon. They say to check their website every so often for updates. www.shopdelphi.com/consumers/ In the meantime I really broke the radio so I can't check the battery contacts.
Posted on Jan 19, 2008
I had this same problem. I took out the lithium battery rubbed off the contacts and inserted it. Scrren came up clear as a bell and works fine now. I was also having a problem with the battery charging. Think what I did solved both problems.
  • expertdon Jan 19, 2008
    Take the battery out, clean contacts and reinsert it. I had same problem and now mine works fine.
Hi! My screen has gone blank on my wharfedale docking station and it isnt responding to anything! I'm not sure what's wrong with it?!
The first place I would look is to the screen lighting mechanism. To prove the display is actually working, you should be able to catch a reflection of very dim images on the screen in bright light.
Hope this is of some use to you.
~/Lee
May 24, 2015 | Computers & Internet
The LCD display screen is blank, back-light remains on. Powering off machine to power back on results in loud, abrasive rattle which seems to come from scanner. Unable to do anything with device.
When this happens the first thing you should do is check the connections to the LCD screen. However if it was working fine before this is most likely not necessary since they have to be connected properly to show anything. After that you would need to replace the LCD or the Logic board. If everything else is working properly then the problem is more than likely the LCD needs to be replaced.
Mar 12, 2014 | Brother MFC 6490CW InkJet Printer
( Dell xps m1530 laptop ) Monitor blank, powers up but screen won't come on.
It ISN'T the LCD screen. Since you diagnosed with an external VGA monitor, you now know the problem is the laptop.
(When you connect an external VGA monitor to a laptop, you are bypassing the Video Cable, and LCD screen. You are connected directly to the laptop )
The basic Windows files aren't being found. The boot files. This may mean a bad Harddrive.
Do you have the Restoration CD Disk? Laptop on insert it into the optical drive tray, close the tray.
When asked choose - Repair. (Non-Destructive Installation)
If a checkdisk is done, you have bad sectors on the harddrive.
There IS a special procedure in replacing a harddrive.
[ More information on Harddrives,
http://computer.howstuffworks.com/hard-disk.htm ]
Regards,
joecoolvette
Feb 26, 2012 | Dell XPS M1530 Laptop
The screen is blank but the light comes on
Seems like a damaged LCD strip or damaged LCD as a whole. will need replacement.
Mar 03, 2010 | Nokia N72 Cellular Phone
Screen is blank; can not see image with computer on
STEP: Toggle the Video Mode with the <Fn> and <F8> Keys
Additional Information
Press the <Fn> and <F8> keys to toggle the display mode between the video modes (LCD Only, Monitor Only, and Both).
STEP: Determine if an external monitor is being used.
Determine if an external monitor is connected to the docking station.
STEP: Determine if the video problem occurs outside of the docking station.
View the LCD panel on the system to determine if the same video issue occurs while the system is outside of the docking station.
STEP: Remove Any Docking Stations or Port Replicators From the Computer
STEP: Unplug All Accessories From the Laptop Computer
Unplug any accessories from the laptop computer, such as PCMCIA cards, external mice, external keyboards, external serial or parallel port devices, external monitors, external USB peripherals and port replicators.
Apr 23, 2009 | Computers & Internet
Blank Desktop When Plugging in USB to laptop from Dynadock
Windows Vista supports mirror mode only; XP supports extended mode and mirror mode. Visit dynadock.com for updated Windows XP and Vista software driver support.
Oct 24, 2008 | Toshiba Dynadock Port Replicator, Docking...
Docking station
Vivitar was purchased by Sakar and they do not support anything that Vivitar used to make or carry any of the products. I suggest looking on ebay to see if anyone is auctioning it. If not, Google it for something like "Vivitar DVR 390H docking station".
But to be honest, it probably is not the docking station. I have had the same problem, as many others have had, that the connector in the camera is the issue. This camera has TONS of design flaws.
Jul 02, 2008 | Vivitar DVR-390H Digital Camera
Blank screen
Dead or black pixels. Information about dead or black pixels on a lcd or computer display. ... Determining how many dead pixels are on the screen .
E-mail CHID: 5858 All it says is Error loading operating system on a black screen. Answer. This issue is often caused when the computers BIOS.
Read & Follow instructions/ Good Luck, Please dont for get to Vote/Thank You.
Dec 22, 2007 | Lenovo ThinkPad T61 Notebook
Delphi MyFi SA10113 XM Radio Receiver with Home and Car Kit Logo
203 people viewed this question
Top Delphi Audio Players & Recorders Experts
xxxxxx xxx
Marvin
Marvin
Colin Stickland
Colin Stickland
Are you a Delphi Audio Player and Recorder Expert? Answer questions, earn points and help others
