Computer does not see flash drive after it is plued-in. Waht shall I do?
  • zealf00 Nov 18, 2008
    Windows XP and it is a staples 512kbyte flash drive
  • 928 Answers
First use a different USB device to make sure the drive is working
1. Try plugging the flashdrive in the back of the computer. ( This is because some USB ports in front are not able to give enough power to power on a USB device that does not have its own power)
2. If you plug in the flashdrive and windows does not prompt for a driver nor indicate that it detects something plugged in you should make sure you try option 1 first and if that does not solve it try another computer. If the same problem occurs then the drive is defective.
3.Check if it is detected via Drive managemetn under Computer management under programs then system tools. ( Do this only if the drive is detected at all) then assign a drive letter to the device that is detected.
Posted on Nov 18, 2008
    Master:
    Sergeant:
  • 449 Answers
Hi!!!
try to disable the firewall
    President:
  • 2,712 Answers
What is your OS, what is the make and model of the drive?
  • Swilin Sampson
    Swilin Sampson Nov 18, 2008
    Try the flash drive on another computer or USB port. If it is not detected there as well, then the drive is probably faulty. If however, it gets detected on the other PC, then try the following:
    The first action you should take to resolve a USB problem is to disable the Save Power option in the Device manager for the each of the USB Root Hub entries. Up to five entries called USB Root Hub can appear under Universal Serial Bus controllers. Open the Device Manager by entering devmgmt.msc in the Start => Start Search box. Open each of the USB Root Hub entries and disable the Save Power option under the Power Management tab by removing the check mark that enables it.
    Here
    is another possible fix that might work. Plug the memory stick into a USB port, right
    click with the mouse pointer over My Computer, in the window
    that comes up, click Manage and then Disk Management
    in the Computer Management window that come up. Is the memory
    stick recognised in Disk Management? - Because it will often
    show here even if it cannot be recognised in Windows. If it is not there, try
    using another USB port. If it appears there, right click the
    memory stick's drive letter under the Volume heading. Click on
    Change Drive Letter and Paths, click on the Change
    button and change it to, say, Z, or another letter towards the
    end of the alphabet. Click Yes when a warning comes up telling
    you what can happen if you change the drive letter, asking you if you want to
    go ahead with it. Doing that won't do any harm to the files on the memory stick.
    Close the Computer Management window and try to access the memory
    stick through My Computer.
I was formatting memory card and my capsity reduce by 1 gb
Check to see if you have partition. Type diskmgmt.msc in Search / Run.
Nov 21, 2012 | SanDisk 2GB microSD Memory Card
I got a new transcend USB jetflash drive 16GB, but my system not showing any response towards it, what shall i do..??? is to download a software for it...??
Flash drives do not need a drivers (plug and play). There are several possibilities:
1. Assumptions: USB port error, computer drivers normal, normal flash drive.
Solution: insert a flash drive into another USB port. If the USB port 1 is not detected, insert flash drive into a USB 2, USB 3 or USB 4.
2. Assumption: normal USB ports, computer driver error, a normal flash drive
Solution: reinstall the chipset drivers, or USB.
3. Assumption: normal USB port,
computer driver normal, flash drive is broken
Solution: try to insert the flash drive into another computer. If the flash drive is not detected, it means your flash drive is damaged.
Solution to determine the cause of damage:
1. If you have a USB mouse, use the mouse to check the damage to the USB port. Example: connect the mouse to the USB 1, USB 2, USB 3 or USB 4. If every USB port, mouse is detected, the conclusion normal USB port
2. To check your computer's drivers, right-click My Computer - Properties - Hardware - Device Manager
3. If points 1 and 2 are normal, the possibility of flash drive damaged.
Because the new flash drive, flash drive is most likely normal. Based on experience, cause damage to the flash drive is a USB port is dirty. The USB port is dirty, can cause short-circuit flash drive. The characteristics of short-circuit flash drive. When inserted into a USB flash drive (about 5 seconds), the temperature of the flash drive become extremely hot. If there are problems like this, immediately unplug the flash drive, to prevent permanent damage.
I hope this information helps.
Oct 11, 2011 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
My transcend 8gb was write protected and i can't copy or save my files on it......
Transcend suggest that you must download and run the Recovery tool software from their download center (not compatible with JetFlash 210), this shall remove the write protection lock from your flash drive.
Normally caused by improper removal of flash drive, so it is imperative to use the "safely remove hardware" option before disconnecting their flash drive from the computer, this shall prevent the write protection problem.
Click here to look for the recovery tool, just type the model name and all the software associated with your unit will be shown..hope that helps.
Sep 01, 2011 | Computers & Internet
My usb drive fell down and someone stepped on it . And the pcb and other compnents came out from teh outer shell or covering . They are intact though. Now when i connect the usb drive to computer teh...
I had the same problem and it could be that the USB plug that enters in the socket has detached from the pcb. If that's the case try to weld it back with a heated nail.
Jun 13, 2010 | SanDisk Cruzer Micro 8GB USB 2.0 Flash...
I have a transcend 2gb pendrive but it has failed to work whenever i try to connect it to my computer , it displays usb device not recognized. Now what shall i do to fix this problem ???
Files on a flash drive can be corrupted if it is not removed from the USB port properly.
Before removing the flash drive click on the Safely Remove Hardware icon and then click on the flash drive you want to remove and then remove the flash drive when the computer message says it is Safe to remove.
To restore the flash drive you need to format the flash drive, but you will lose the data stored on the flash drive.
If you need the data on the flash drive these WEB sites may help: -
Data and Digital Photo Recovery
www.artplus.hr/adapps/eng/dpr.htm
www.CardRecovery.com
Jan 09, 2010 | Transcend T.sonic 610 MP3 Player
Icant see my usb flash drive in my computer
You can try this out:
After powering up your system, and you have plugged the flash drive, then Right-Click on my computer icon, select manage, then go to Disk Management Option.
On the Disk management option Page you should see ALL the drives installed on your system, including the hidden ones, so what you will just do is, try and locate the one representing your flash drive, and right click on it. then select "Change Drive letter and Paths", and give the drive any new, unique letter (i.e alphabet) different from the ones already on your system, and click on OK.
This should make your Flash Drive to be detected automatically.
Hope this helps you out.
Jul 15, 2009 | Transcend 8GB SSD, 2.5- Inch, IDE, SLC...
Casio TE-2400 PLU programming
Hi. You have been given the wrong instructions. That is why it is now all screwed up. Pricing is dead easy. You have condiments setup because you have set key features in prog 3 mode. It shouldn't be too hard to fix. We'll start with prices: Turn key to Program mode Type the price (no decimal point) Press a PLU (item button) to set the price to. Press SUBTOTAL To remove condiments, you need prog 3 mode. While key is on program, press 3 then SUBTOTAL. The display must change to "P3" Now press 0 (zero) then one of the PLUs that has condiments set. Press SUBTOTAL to finish. It may remove the tax status, so turn back to REG mode and test the PLU. If the tax has gone, then reprogram the tax setting for that PLU. Let me know if you get stuck. Mark
Jun 09, 2009 | Casio Parts Cash Register PC Desktop
Flash drive for 360 Xbox
Hello my name is Tim Ehrhart, You can download games to play off marketplace but they are downloaded to your hard drive and system and can not be transfered to a flash drive.
Mar 18, 2009 | Microsoft Xbox 360 Console
Laptop does not recognize the flash-drive after it's pluged in.
there are some reasons why it does not work.
1- You do not have correct drivers for the flash drive, and the computer will not recognize the product. simply update the driver for the flash drive and it will work. To do this go to the flash drive companies site and search for product driver updates
2- You have damaged your flash drive to the point where windows will not even recognize it. To prove this, plug multiple usb devices into the port and test if they work, and test the flash drive in different ports in your laptop and other PCs. If it is still not working, then it is faulty and will not work. Purchase a new one if this is the case
Hope This Helps
Nov 18, 2008 | Computers & Internet
Computers & Internet Logo
21 people viewed this question
Alun Cox
David Payne
David Payne
