Question about Xerox WorkCentre XL2140df Laser Printer
HELP HELP HELP HELP NOW! We are making copys on a Xerox XL2140df and it is blinking a red squigly light..... it won't print.  Flashes E.. help us. We need the copies ASAP.
    Scholar:
  • 136 Answers
OK first don't panic, Second the Squikly line ( does it look like a lighting Bolt sort of ?
this means you have paper stuck somewhere and and it needs to be removed.,Open the cassette and remove paper then open the side door then the front door and remove paper that is stuck ( BE CAREFUL not to touch the GREEN ROLLER THING ) thats called a Drum, you do not want to scratch that ok.
Posted on Aug 04, 2009
My Xerox Phaser 6128MFP printer flashes red light after every print out....
First, when you put the paper in the tray make sure the paper holders on the side and back of the tray are positioned against the paper stack but not so much as to be snug.
Next, inside the compartment where the paper try is inserted look for a small plastic piece that hangs below the ceiling of the compartment. It should be near the front of the compartment hanging down and should swing freely backward.
Also, in the printer's paper tray settings make sure that tray is set to that size of paper you are using.
Apr 02, 2015 | Xerox Phaser 6128MFP AllInOne Laser...
Red blinking light on top. copier won't copy?
i don't know about ur problem clearly
plz clr problem tell me?
+8801723019697
Aug 08, 2011 | Xerox 8830 Copier
I have a xerox workcentre XL2130. It had a bad paper jam. I cleared it - now it has an error code E4. I've turned it off and on - hit the clear button - nothing is clearing it? Help! Thanks, Stacia
YOU STILL HAVE A PROBLEM IN THE PAPER PATH...
DOWNLOAD THE USER MANUAL
Clearing the Paper Path
- E-1, E-2, E-3, E-4, E-5
When a paper misfeed occurs the red misfeed indicator flashes
on the WorkCentre diagram, and an E status code will flash in
the Display Window. Paper misfeeds may occur in the areas
shown below. Follow the steps below to locate and clear the
misfeed.
Note: Ensure that the alternate paper tray is lowered
(XL2140df only).
Caution: Do not touch the shiny drum cartridge surface.
Scratches or smudges will result in poor copy quality.
Do not remove paper through the bypass. Unfused toner may
adhere in the area, resulting in smudged copies.
E-1
Steps 1-2 for XL2140df only
1. Lower the right Side Tray 2 Access Door.
2. Remove the misfed paper.
3. Close the Access Door.
If paper cannot be removed, open drawer (2) clear misfed paper.
4. Close the Side Cover.
E-2
1. Press the Release Latch to open the Side Cover.
Exit Area
Paper Feed Area
Fuser Area
Side Cover
35
- E-1, E-2, E-3, E-4, E-5 (continued)
Caution: Do not touch the shiny Drum Cartridge surface.
2. Carefully remove the misfed paper in the direction shown.
If paper cannot be reached, open the paper trays and remove
misfed paper.
E-3
Fuser Area
Warning: The fuser area is hot. Take care when removing
paper from the fuser area.
Note: Ensure that the Alternate Paper Tray is lowered
(XL2140df only).
1. Press the Release Lever to open the Side Cover.
2. Pull down on the fuser lever.
• This will release pressure on the paper.
Caution: Do not pull paper up through the fusing unit. Unfused toner
may adhere in the area, resulting in smudged copies.
3. Remove the sheet of paper in the direction shown.
E-4 and E-5 (2-sided Reverse Copy XL2140df only)
Exit Area
1. Pull down on the fuser lever.
2. Gently pull the paper out through the exit area.
36
3. If not accessible, turn the knob in the direction of the arrow
to move the paper to the exit area.
4. Gently pull the paper out through the exit area.
Feb 12, 2011 | Xerox WorkCentre XL2130f Laser Printer
Machine will not make copies
Your out of toner and the machine cant set up.
May 20, 2009 | Xerox Office Equipment & Supplies
Xerox Phaser 8560 display error
There is a known issue with that display. Call 1-800-835-6100 and tell Xerox you have a problem with the diaplay, They should replace it free.
Jan 26, 2009 | Xerox Phaser 8560MFP Laser Printer
Tonor along edge of paper on my Xerox WorkCentre XL2140df
I would think you just have another bad cartridge. have you simply tried shaking it side to side? May just be built up on one side, but those cartridges are notorious for going bad. You need to vacuum the machine out well also. That toner and developer get in all those little plastic supports and can cause toner to dump.I would say the chance of a bad cartridge again is about 95 percent.
The printing problem. Have you tried downloading the driver from the Xerox.com site? Or simply reloading the driver. Sounds like its corrupted somehow. And when you change the tray, you are clicking apply?
Dec 17, 2008 | Xerox WorkCentre XL2140df Laser Printer
Troubleshoot xerox workcentre xl2140df we have an error code E5?
An E-5 Normally comes from the paper path actuator that detcts the second side of a copy is hanging up.
In the fuser area there are some corrigated looking parts of the fuser exit guide that the actuator is most likely hitting or hanging up on.
You may have to take a pair of diagional cutters and snip a small section of that out.E-5 is a jam on duplex copies on that machine.
Jan 12, 2008 | Xerox WorkCentre XL2140df Laser Printer
Xerox WorkCentre XL2140df Laser Printer Logo
55 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
