Question about Electrolux EOB6632 Electric Single Oven
Oven switches 'itself' off without the timer
The oven switches itself off after a non-consistant time ( anything between 10 & 40 mins )or temperature ( without the timer being activated ), the element,fan and light stop working although the 'Power' light remains on? It then switches itself back on after another non-consistant time (anything between 5 & 40 mins )
  • 7 more comments
  • Angie Martin
    Angie Martin Nov 04, 2007
    When grilling, the oven switches itself off, and will eventually switch itself back on. We don't know how to stop this happening - any advice would be great.
  • Miles T Dec 05, 2007
    Exactly the same problem
  • PAT_K Dec 06, 2007
    When the temperature is set (any temperature) and the time is set the oven switches itself off after 20 minutes. The element,fan and light stop working although the 'Power' light remains on? it does not switch back on.
  • Anonymous Dec 13, 2007
    oven knocking off when it gets to certain tempature ,when not set on timer ,light and fan also go off.
    comes back on by its self after so long !
  • mikewalker Jan 29, 2008
    Much the same problem, at first thought it was energy saving, but food doesnt cook!!
    Does anyone know what the problem is and how to fix it?
  • julianhodgso Jul 17, 2008
    I have exactly the same problem with the EOB6632. I have contacted Electrolux's customer services. If they come up with a fix I will post it here.
  • lcb501 Sep 14, 2008
    Same problem here.
    Any suggestions?
  • Anonymous Mar 18, 2014
    how does the automatic timer work
  • Anonymous Mar 25, 2014
    My oven on my westinghouse oven Saturn model 4u603w*40 is not switching on due I think to my fiddling with the timer which I wanted to use
I sorted it it is a simple solution, if you take the top of your oven you should see the problem...it will be big and black..dont spend a ortune getting it sorted i brought the part off ebay for less than a fiver.. just cant remember what it was called..very simple to fix though.  Mike
Posted on Jan 09, 2009
  • mikewalker Jan 09, 2009
    http://www.exsparetise.com/pdf/2007March... page 2 at the bottom is what you need.
    I found the link in my favourites its called a thermal cut out switch.
    email me leicester_boy1983@hotmail.com if you need any further help. thanks mike
Ihave the same problem i am an electrican and when i opened the top i found a small insulated plastic tube with two thermostats in side burned one of them was burned out,this assembll must be replaced with a new one ,they are all push on connections and are easy to replace turn the cooker switch off for obivious safety
Posted on Dec 05, 2007
AEG oven switches itself off after 35 mins
does it turn off after the oven has got upto temperature if it does it is probably that your thermostat has gone as this cuts off as a safety feature if your oven gets hotter than the thermo setting then it will shut off to protect from over heating or causing a fire hazzard with high temperature are you sure you havent changed the timer as well cus you can set a timer for your oven to switch on at certain time and to also switch off after a certain time if you still have the manuall have a look through the timer section if you do not have a manuall then check on your makers web site these should have a manuall online for you to check first i would check that the timer is not on if i can find you a manuall online i will post back hope this is some help.................
Nov 04, 2007 | Ovens
Can someone tell me where the Clean button is on a 12L proelectrix halogen oven is? All I can see is where the timer and temperature switches are!!
you dont have clean button you have turn temp down to 80 add water and wash up liquid and set timer for 5 min it tells you in manual next to hints and tips
Jan 02, 2011 | Ovens
When my oven is on for about 10 to 15 minutes it then turns itself off and beats reading the code F2
F2 error code usually relates to over temperature on the oven cleaning cycle, (where the temperature in the oven exceeds 990 degrees) This has obvious safety implications.
Normally it is caused by a faulty temperature sensor but can also be caused by 'stuck on' relay contacts in the 'oven clean' cycle controlller or a stalled cooling fan or air flow problem.
As with all electronic circuits sometimes the problem will disappear if you switch the power off for 30 mins thn rest the oven but if the problem persists you will need to have the oven sensor replaced.
Jan 07, 2010 | GE Ovens
AEG 3032 Oven, no light, no main fan, no heat to grill or oven however the exhaust fan does operate when the grill/oven is switched on. The thermostat clicks when moved from 0 to a higher temperature but...
If you are sure the timer is set to manual and not auto , then I would say that it sounds like the selector switch is faulty or the thermostat is faulty, some times they are combined as one unit, and sometimes they are 2 separate switches.
You need to remove top cover of oven and have a look inside the control panel and see if there is anything obvious like a burnt wire or bad connection
If it is a combined unit, then sometimes the 2 parts of the unit become disengaged or the cam inside the switch breaks.
Plz rate my solution .
Thanks.
Jan 05, 2009 | AEG B1180-4 Electric Single Oven
Oven only works at max temp
The oven temp switch should be replaced.
This switch has a long tube which goes from the switch to the inside of the oven. The switch can be replace without much of a problem but, feeding the new tube down to the oven can be tricky sometimes. The old tube will come out but you have to find the same hole to put the new tube back through, sometimes this will go through insulation and you can't see the hole where the old tube came out. It's not hard to do just be aware of this problem.
Dec 16, 2008 | Ovens
How to use self cleaning oven
  • When using the self-cleaning feature on your oven, the temperature within the oven rises to an extremely high temperature, usually around1000 degrees. The oven will remain at this temperature for a set periodof time, often from 1 to 3 hours.
  • Self-cleaning ovens differ from traditional ovens in that they require a timer to control the amount oftime that the self-cleaning feature operates. They also require extrathermostatic controls to control the extremely high temperatures.
  • While the mechanisms inside aself-cleaning oven are quite complex, the concept behind aself-cleaning oven is fairly straight forward. The extremely hightemperatures incinerate dirt and debris from your oven, thus cleaningit for future use.
  • Safety is very important when using yourself-cleaning feature. You must ensure that the oven door is completelyclosed while the self-cleaning cycle is running. 1000 degreetemperatures are obviously extremely dangerous. Self-cleaning ovenswill come equipped with a secure oven door latch for this reason.
  • The crucial door locking system isinitially engaged to signal that you are ready to use the self-cleaningfeature. When the oven reaches a certain temperature, the door locksystem will ensure that the oven door cannot be opened until the cycleis complete and the temperature has returned to a manageable level.The result is a clean oven without the use of harsh oven cleaners orabrasives.
REMEMBER YOU ARE WORKING WITH 220 VOLTS - USE EXTREME CAUTION!!!
Nov 11, 2008 | Ovens
STOVES 720ef Oven Programme won't go off automatic
This is a solution - of sorts - but probably not the one that you were hoping for.
My Stoves 720EF oven developed the same fault.
I tried pressing the buttons in various combinations and I tried switching the power off and on, restting the timer and the clock, no joy.
I then tried getting hold of a copy of the manual and trying to fix it, no joy. Called up Stoves and booked a visit from a specialist service engineer, costing £75 +VAT for the call out, and was advised that the engineer would attempt to repair it but it might need a replacement circuit board, costing a further £110 plus VAT.
engineer arrived on the appointed day and was straight onto swapping out the circuit board - not much scope for "attempt to repair" - so that was about £190 plus VAT to fix it. job took about 25 mins and didnt seem to need anything beyond what any electrician (or electrically-expert DIYer) could do.
comes with a 12 month warranty - hopefully it will work without any issues !
If you have a regular electrician you might prefer to buy the board and get your electrician to do the job - or do it yourself, assuming that you are suitably skilled and qualified.
hope this helps
cheers
David
Nov 07, 2008 | Stoves 720EF Electric Double Oven
GE digital Timer Oven
most of the time turning the breaker off for a few min will be a temp. solution but it it comes back then the ERC which is the clock itself needs to be replaced
Nov 22, 2007 | GE JKP27 Electric Double Oven
Electrolux EOB6632 Electric Single Oven Logo
862 people viewed this question
Top Electrolux Ovens Experts
ashburton
Mack Baxter
Are you an Electrolux Oven Expert? Answer questions, earn points and help others
