Question about Black & Decker HPD18K - 2 High Performance Cordless Drill/Driver
Keyless chuck will not tighten down enough to hold bit
When drilling, the bit comes lose, when inserting the bit, I held the outer ring - felt the "click" that means it is tight. Started drilling, and drill bit slid inside drill , reset it, drill bit came out of drill and stayed in metal I was drilling.
    New Friend:
  • 55 Answers
What size bit are you using if it is real small it may be below the min sixe require for that chuck .If it is say 1/8 or larger it may be time for a new chuck .They are easy to replace open the chuck as far as you can there is a screw inside them most of them are left hand threads just back it out and tap the chuck loose with a hammer .Make sure you know the threads of your chuck when you buy the new one most are 1/2-20 but some can be 3/8-24 tpi
Posted on Dec 05, 2008
How to insert bit for Black and Decker 3/8 Variable Speed Reversing Drill.
Most new cordless drills don't have a key(keyless chuck). Put the drill in reverse and hold tight to the chuck barrel, pull trigger and the chuck will open. Opposite to close/tighten Best I can do with info provided
Apr 15, 2015 | Speed Drills
How do I remove the drill bit from a Makita6223D?
If your drill has the original keyless chuck on it, there are two plastic rings on the chuck. The outer ring should tighten and loosen by hand enough to hold the bit(s). The inner ring is to hold on to if the chuck gets overtightened. Chucks do wear and get corroded over time and can get locked in position. If you can't get it loose by hand, channel lock pliers can help. If the chuck is that bad you may need to replace it.
Mar 03, 2013 | Makita 9.6v Cordless Impact Driver 6903VD
Mybrand new RZ20 keyless chuck will not close around a bit.
If a large enough drill bit is inserted too far so it bottoms in the chuck, the jaws run into the bottomed shank and will not close beyond a certain point due to the interference. If you hold the drill bit out about 1/2 inch from the bottom, the jaws should close on the bit. I assume you have tested the chuck without a bit to verify they can close.
Feb 15, 2012 | Drills
I have a rotozip 20 and the new keyless chuck just does not work. Am I doung something wrong?
Try not inserting the bit all the way in until it bottoms- it should not bottom. Also make sure it is the correct size range for the bits you have.
Feb 10, 2012 | Bosch Drills
How do I take a bit out?
It is a keyless chuck. Put the drill in reverse (chuck should spin to the left when viewed from the back) and hold the main body area of the chuck with your hand while slowly running the drill. The chuck will open (unless it is broke) and release the bit. You do the opposite (slowing running the drill in forward) for tightening a bit in the chuck.
Jul 16, 2011 | Dewalt 18v Battery Hammer Drill Dcd950...
My black and decker 12v drill is 'locked". The area where you put the drill bits in won't loosen or tighten so it won't hold any bits. I have tried to manually loosen or tighten it too but nothing...
Try shooting some WD-40 lubricant into the 'chuck' and let it sit for awhile, then rotate the outer part of the chuck CCW to loosen the 'jaws'. If the chuck is a keyless type, just hold the chuck and turn the reversing switch to 'reverse', then gently apply power to the trigger--that should open the chuck jaws. You will likely find that a leather glove on the hand holding the chuck will help prevent a burned hand if you lose your grip. If it is a keyed--type chuck (there will be ring of gear teeth on the front edge of the chuck), then a key with a small gear near one end is required to turn the chuck open (turn the key CCW). Hope this helps!
Jan 25, 2011 | Garden
How do you get the bit out of the Craftsman 19.2? I just want to change it for a different bit.
I'm assuming this is a drill/driver but you did not indicate a model. If it's a keyless chuck, and most are, put the drill in reverse, hold the chuck housing near the body of the drill firmly and pull the trigger. the chuck jaws will open wide enough to remove the old bit and insert new one. To tighten, switch the drill into forward gear, hold the chuck and pull the trigger until the bit is firmly held in the jaws.
Dec 11, 2010 | General Hand Tools
How do I change a bit
This drill uses a keyless chuck. which means you have to hold onto the barrel by the end of the drill chuck. Then you need to put the drill in reverse to open the chuck to put a bit in. Insert a bit and then put the drill back into forward and hold chuck to tighten.
Nov 14, 2010 | Milwaukee Tool Milwaukee 0824 24 v18...
I have a craftsman electric drill model no. 315.10419, i would like to know how to loosen/tighten the chuck for the bits. it is not the regular notched tightener but has a pull down shaft similar to an...
I have the same drill and love it !! This series of Craftsman Drills are the first of the keyless chuck. To tighten or loosen the bit, simply pull back on the black ring tightly and hold it and simultaneously pull trigger to run drill foreward (to tighten bit). Reverse (to loosen bit). The chuck will make a loud clicking sound!! This is normal !
Jun 23, 2010 | Craftsman Drills
Never have used a keyless chuck b4- need to change bit, how do I do this? thanks
hi this should be reletively easy hold the end black bit with the sivler bit holde coming out not the black bit next to the yellow case on drill you hold the black part thats at end of drill by where the bit goes into not the black bit near the trigger hope i explain this ok.
Hold this bit tight then put drill in reverse then press trigger a couple of times it might be tight but shouldnt be that tight it wont undo.
1 put in reverse
2 hold black plastic piece near where drill bit goes into
3 press trigger few times
4 this should undo it allowing you to put a bit in
make sure its in reverse else you will just tighten it up more let me know if you need further assistance ok
Mar 05, 2008 | Dewalt 18 Volt Compact Drill Kit
Black & Decker HPD18K - 2 High Performance Cordless Drill/Driver Logo
522 people viewed this question
Top Black & Decker Drills Experts
JOHN LAPIER
Marvin
Marvin
Robert Monigold
Robert Monigold
Are you a Black & Decker Drill Expert? Answer questions, earn points and help others
