Question about Dell UltraSharp 1701FP 17" Flat Panel LCD Monitor
Power on issue
My dell 1701fp monitor takes several dozen attempts sometimes to turn on. Sometimes more, some less. When finally on it seems fine. Each time i press the power button, the power light and screen flicker momentarily then go blank again. It is very frustrating as it can take ages to get on! Anyone know whats wrong?
  • Dell Master
  • 3,389 Answers
Bad CCFL lamps
if the monitor fails on 2 PCs, and both are in presentation mode
using say this app, the CCLF tubes are dead. or dim.
or inverter dead part of monitor PSU card inside.
https://downloads.tomsguide.com/Dont-Sleep,0301-28162.html
or a full blown PSU failure inside, the power lamp seem to imply that.
test the monitor on 2 PC
if fails buy a 2010 or newer monitor with LED back lamps
end the pain of CCFL for ever. that way.
Posted on Oct 28, 2018
    New Friend:
  • 27 Answers
I had the same thing happen recently.
I wish it was better news but It's a Capacitor that's burning out.
For myself, I just grabbed another monitor from my garage but I did look up the problem first and found video's on how to fix the problem.
It requires some soldering and a little talent along those lines.
I have no doubt I could do it, I just didn't feel like doing it then.
At the bottom of this post is one link to a DIY Fix it vid.
Another option is to find a used monitor.
Of course there are sites like E-Bay or Craig's that you could try but there is a recycle site that people give things away and take things on, called (freecycle).
This is a great site, I've used it in both directions many times with no problems.
NOTE: Use common sense.
I recommend that anytime your going to meet someone from the web you don't know that you take someone with you or at the very least tell someone exactly where you going and any other pertinent info.
Here are the 2 links I mentioned
https://www.freecycle.org/
https://www.youtube.com/watch?v=f3Nr7wAT84I
Posted on Dec 03, 2017
SOURCE: Monitor (Dell 1701FP) flickers, flashes and goes black
Hello, My name is Richard; I am part of Dells Online Community Outreach group. Solution 1 is good as the inverter may be going out. The inverter lights up the screen for the picture to be displayed, other wise you would only be able to see very dark shadows. In the end it would be a good idea to call our technical support at 1-800-822-8965 and find out if the monitor is still under warrantee. Or you can email me at customer_advocate@dell.com, place attention Richard in the subject line. We can assist you in determining what the issue is and help apply a solution. Regards, Richard
Posted on May 30, 2007
SOURCE: blinking monitor power button and flashing image
i bought a new acer 19" . i will try to change the capacitors and see how it works. if not, i will try the power inverter option. but my new lcd itself cost me 100$ after rebate. so paying 70 pounds for an inverter is unwise. previous poster, I am sure it is problem with monitor and not the connector coz it doesn't do the self diagnosis. thanks for all the responses so far.
Posted on Jun 12, 2007
Benimur
  • 6966 Answers
SOURCE: Dell SP2208WFP Flat Panel Monitor flickers out and goes black.
Hi again,
Any luck with the Dell people?
A favor if I may, at your convenience, would appreciate if you can rate our Live Session as you see it fit.
Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Posted on Aug 06, 2008
  • 4 Answers
I buy and sell these monitors (Dell E17FP) the problem is with the transisters (Q739, Q740, Q759, Q760) they short out and the monitor will just blink on and off. You have to desolder them and test them with a simple battery and light circuit. The reason they blow is because of the dirty solder joints by the transformers. If only on pair of backlights work the problem maybe transisters Q751, Q743. I home this answers your questions.
Posted on Sep 12, 2008
SOURCE: Monitor is black. Press power on monitor/screen shows for 1 sec
We have the same problem and think that the monitor may be getting too warm with staying on all of the time. Try to turn off the monitor when you arent using it. It might save you some time while you look for another monitor.
Posted on Dec 12, 2008
How do i test power on a dell flatscreen 1701fp. I have tested the power adapter and it is working and outputting the correct voltage. The monitor itself will not power on, I have disassembled and looked...
Since you cannot power on the monitor with the power switch on the monitor, then it can be the power supply or the logic board, or the inverter has shorted circuits so it makes the power supply go into shutdown mode.
This monitor uses 14vdc 3A power supply, so what you can do is to verify that you do have 14vdc at the DC input jack with monitor in the OFF mode, then try turn on the monitor to see if the 14vdc drops down to lower than 12vdc or so.
The inverter board has fuse also.
I do not have the pictures of the board for this monitor, but if you can post the pictures, then it will help a lot.
Does the inverter board look like this? http://www.badcaps.net/forum/attachment.php?attachmentid=12595&d=1259317517
At this point I will concentrate why the monitor will not turn on first, you can disconnect the ribbon cables attached to the inverter board and see if the monitor will power up.
http://s807.photobucket.com/albums/yy352/budm/DELL/
Aug 10, 2011 | Dell UltraSharp 1701FP 17" LCD Monitor
I have lost the original power supply for my dell 1701fp monitor. I have a power supply that I think may work as a substitute until I can replace the original. I need to know, what the acceptable voltage...
What ever you use, it must be REGULATED power supply that will maintain 14vdc output, rating at 3A. These regulated power supply can easily maintain the output voltage within +/- 5% with input AC voltage range from 100~240vac.
Linear regulator power supply may not work since it has slow response time to regulate the voltage.
http://www.amazon.com/dp/B002D1E8NE/ref=asc_df_B002D1E8NE1376531?smid=A3IZHOEADOGAP0&tag=dealtmp386264-20&linkCode=asn&creative=395105&creativeASIN=B002D1E8NE
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Or www.digikey.com, just make sure to use caps with low ESR, 105c, high ripple current and long life rating such as PANASONIC FM or FC series.
Please post back what you find.
Please leave rating if it helps.
Jan 06, 2011 | Dell UltraSharp 1701FP 17" LCD Monitor
Monitor will not turn on including power switch
I suspect the power supply for the monitor. Try a power supply from a working monitor. If you have a used computer store nearby, take your power supply to them and try it on another monitor.
There is no need to turn off a monitor using its power switch. Monitors automatically go into standby mode when they are not receiving a signal. In standby mode they use less than one cent of electricity per day. If saving electricity is your goal, raise the temperature in your home by a degree and run the air conditioning less.
May 17, 2009 | Dell Computers & Internet
Dell FP1504 Displaying very dark " Ithink this is backlight issue
If you are not a technician you can´t solve this problem because are to desasembly your device and check the Q7 and Q8 and C5 that components are on bad conditions and need to be replaced,I told you because i repaired one of these monitors for the same problem
May 08, 2009 | Dell UltraSharp 1504FP Monitor
Dell XPS 600 turns itself on to solid amber
Hi. the mother board seems to be having some initialization issues during boot up. this is common when the mother board is failing. i would check to make sure the battery on this board is working. if it is, the board my be ruined.
power board seems to be fine.
please rate and god bless.
Mar 17, 2009 | Dell XPS 600 PC Desktop
Dell D600 Wont turn on sometimes.
Reseat the harddrive (take out the screw and slide it in and out)
You can run diagnostics, during startup (just after Dell logo) press F12,then select Boot to Utility partition, or Diagnostic partition.
It may reveal you issue
Hope this helps
Feb 04, 2009 | Dell Latitude D600 Notebook
Dell 151fp is slow to get going, fine otherwise
You dell e151fp lcd monitor may have a bad/weak capacitor on power section(primary and secondary). Just change the buldge capacitor and use the Dick Smith ESR Meter to check the capacitor esr value. If you not sure all the above, you may go to this site to get the list of bad component on dell e151fp lcd monitor. Please visit here http://www.fastrepairguide.com/monitor-and-lcd-monitor-problem-solutions/repair-dell-e151fp-lcd-monitor-with-symptom-no.html
Sep 08, 2007 | Dell E151FP 15" Flat Panel LCD Monitor
Just to check - when the screen is black- can you see any image- in its un-illuminated state. To do this look sideways along the screen not straight at it. I suspect this is an inverter problem. Whether or not this is repairable I know not- depending on your local repair facilities Perhaps DELL can suggest a local agent.
May 16, 2007 | Dell UltraSharp 1701FP 17" Flat Panel LCD...
Dell UltraSharp 1701FP 17" Flat Panel LCD Monitor Logo
74 people viewed this question
Clive
Clive
Alun Cox
